This model is a direct evolution of the wolf.
Here's a lil something I've been cooking up so far in LDD:
So far the lower part should be functional.
The legs are built in such manner, they are always parallel to the ground/each other.
The four LAs are for lifting and lowering the entire machine:
In order to walk the special system of cams is set in suc hammer that the legs are always 180 degrees apart:
In order to steer and help by walking each of the feet also has a turntable in order to rotate the whole model in its...erm toes?
And to keep the model balanced the (here not connected) 9L links tilt the upcomming body in such manner the weight is aways at the extended leg.
The tilting is controlled by forward moving functions of the legs and cannot be out of sync:
So far I used 5M motors for 3 functions:
1M motor to walk
2M motors to lift both legs
2M motor to rotate feet - they dont have to be independent as usually there is always one feet on the ground
I still plan to use 5 more M motors for:
1M motor for rotating the upper superstructure
2M motors to lift/lower arms
2M motors for the arms upcoming functions (grab/shoot)
So what'ya guys think?
  • Replies 65
I'm pretty sure the 3L half beams (marked with orange arrows) will have too much stress applied to them, especially if you are planning to add battery boxes and 5 more motors on top. They'll either flex the axle or slip off it.
From my experience there the joints on large bipeds require a lot of reinforcement. The alternative is to build as light as possible, which limits the number of functions you can have.
Looking forward to see it, but I have to agree with BusterHaus .
My God! Where on earth do you start with a build like this?
I can't wait to see the finished result :sweet:
I don't know how I missed your incredible Cheetah until now. It's an astonishing build. Hats off to you Zblj :thumbup::thumbup::thumbup:
Best of luck, but after only admittedly a cursory review of the model, I think that there will be too much weight on the actuators for any real functioning.
I think that too, I will need more gearing, 1:1 ratio for 2 LA's isnt going to be enough... Will keep you guys updated.
There are 2 more motors coming. Lifting and leg rotation will be common for both sides. The legs are incredibly stiff, thanks to the LA's which are rock solid. I just hope the body will provide enough counterweight for walking.
How will you ensure transversal moving of the centre of gravitiy, or is it possible, that this puppy will not fall when one leg is lifted and the centre of gravity doesn't move to the oposite side?
Otherwise - good progress so far :)
Cheers
The center of gravity is linked to the leg movement so when one leg moves down the upper body tilts in a way to help shift the center of gravity. At the moment the body is not yet finished and doesnt have the full mass, but the shift is effective enough for this puppy to walk already:
Edited by Zblj
