Hi,
To set a first bar here is a quick mashup of 8048 and 8261. It is a red grader (I couldn't quite get a good parts collection in yellow for this, plus I needed 6 the same wheels).
It's functions are:
pendular suspension on the front wheels
pendular suspension on the rear wheels
steering (both in the cab and with HOG)
The grader blade can be put in two positions up&down by tilting the axle with the black steering wheel on top. (In the down position the springs will keep it pushed against the floor)
The grader blade can rotate around the vertical axis (you have to turn the black steering wheel for that)
The grader blade can rotate around the horizontal axis (not adjustable, it will simply follow the ground)
The ripper in the back can be put in two positions with a little lever at the back: up&down. (In the down position the springs will keep it pushed against the floor)
Part usage: 387 / 512 (198+314) (none of the extra parts used)
Allthough the grader blade isn't operated like the real thing, the play value is actually quite nice I think.
As usual comments and questions are appreciated,
Jeroen
It looks really cool, but I do agree with Alasdair Ryan - the springs areforcing the blade up and not down as it would seem more reasonable...
Actually they are forcing the blade both up and down. It is a bi-stable knee-mechanism: in the up position the springs hold the blade up, while in the down position they push the blade down (they must be connected to the blue 3L pin just above the springs).
I already built 95% of the model in real bricks and it really works :tongue: .
I knew we are barking at the wrong tree :-) Great idea and a really strong candidate, I guess we'll have to wait a bit more... I expect many more entries... even mine perhapse :-)
Hi,
Here is an update after a week of further tinkering:
I have added one more function, namely a functional fake engine. Unfortunately I didn't have enough gears to connect it to all wheels, so there is only one wheel that drives the engine.
I have now used 421 / 512 parts (so I still have 91 parts left... which amazes me if I look it into the box. There seem to be way less parts left... *huh* )
There is room for another cilinder block, so maybe I'll attempt to make a 3-cilinder fake engine.
Edit: I just realized I have added mirrors too, so that accounts for another 8 parts in use... Still not in th 90% reuse though...
Edited by Jeroen Ottens
Here is the final model:
It features:
- Steering : HoG + steering in the cab
- Pendular suspension on the front axle
- Pendular suspension on the rear axle
- Grader blade with the following articulation possibilities:
- up/down (operated by pushing the rod forward or backward. It has a spring loaded knee-jack mechanism to keep it either up or down)
- tilt around the vertical axis (operated by turning the wheel on the rod)
- tilt around the horizontal axis (to make it follow the ground. Not a real life feature, but great for playability)
- Ripper at the back (also with a spring loaded knee jack mechanism to keep it either up or down)
- 2 cilinder fake engine driven by one of the wheels (not enough gears in the set to connect all wheels, but it is an easy mod :wink: )
A picture from the bottomside:
And a picture from the leftover parts:
Comments are welcome as always
I love it!!! I didn't saw many, but this is the best looking grader I've seen, whatever the scale. Was hoping for some more photos though.
Here is another photo. Is there any particular detail you want to see?
That knee-jack was one of the details I wanted to see, so you read my mind :-) Perhapse the front with the blade from top angle, if it is not too much that I'm asking :-) Thx,
Best regards, miha
Edited by MajklSpajkl
Best regards, miha
Here you go:
The ripper in the two positions:
The blade in the up/down position:
And finally the blade as seen from the top in the extreme positions + the middle:
