hello everyone,
i have a problem on 8110's front bridge.
It seems a bit excursion, and i havn't found where i was wrong.
i try to backout the black joint lever, it will be OK.
help~~~
Edited by flashtom
A bit difficult to understand what the issue is ... can you elaborate a little more?
First of all thank you.
8110's front bridge was deflection to right.
Not in center.
I don't know why.
The process was all follow by user guide step by step.
ok, probably I have the answer. The front "bridge" it's hold by a pin and an arm bush. Make sure the pin it's in the right hole...cos there are 2 holes close to each others.....if you put it the wrong one it will skid the all axle.
hello flashtom
not exactly sure why its not centered. im going to take a guess that your shocks have not been put on both the same way. check in book two were the shocks attach to the front of the chassis page 71 step 97. hope this helps, it may help with a few more pics
doug
Are you talking about the front axle being a little to the right side when the suspension is not compressed? If so, that is the way it is intended to be. The reason is to make the front axle stay in the center when the suspension is compressed.
Thank you.
That pin is in correct hole.
hello flashtom
doug
Thank you dear.
:D
  • 8 months later...
Hi, here is the solution to make the axle be in the most center place:
http://www.brickshelf.com/gallery/imanolB/unimog/p1120669.jpg
(used in the rear axle):
http://www.brickshelf.com/gallery/imanolB/unimog/p1120672.jpg
and the proof:
http://www.brickshelf.com/gallery/imanolB/unimog/p1120676.jpg
http://www.brickshelf.com/gallery/imanolB/unimog/p1120677.jpg
hope this works for you.
Edited by Blakbird
: removed massively oversized images.
ok, i have just post it on Unimog 8110 mods and improvements, should i delete my previous post?
