My first thought for a title was: 'Useless Technic Parts', but let's not be too negative.
In any event, the topic is: What parts do you have many of, and no matter how hard you've tried, you can't use them in any MOC.
Of course many of the Bionicle parts qualify, but let us stick to strictly Technic. The two I can think of are the rubber band holders, and I do have a large collection of those. Anything else?
Edited by DrJB
Yeah, I too have a couple of those rubber band holders, never used them for anything=)
Especially when I came back into Technic a couple years ago, and discovered bricklink, I bought a whole lot of parts that seemed useful/cool at the time, but I since never used once in a creation.
For example:
Steering Arm 6.5 - Not used, since the &L ones are more versatile
This Dual Clip 1 x 3 Triangle
The Technic Gearbox Half - Had a lot of ideas for this one, but they all turned out to be awkward and stupid
I have several of these Rectangular Technic Bricks (in various sizes) - never used, but that's probably because I build almost exclusively in studless
Also, although I bought a lot of the fairly new Technic I-Beam 3 x 5 parts, I have not once used them in a MOC :blush:
I have never used the dampened shock absorber on any moc. I haven't even tried.
32181c03.jpg?0
I haven't used the rubber band holders either, and I never even considered those parts. I think I've tossed most of mine.
32181c03.jpg?0
I ahve used them for opening doors / bonnets fro cars.
I have also used them as prop pieces on mechs .
Hah Majkl, exactly the same here. Most of these Bionicle/Hero Factory parts are gathering dust here.
Same, I gave most of my bionicles to one of my friends that likes using them. Though the ball joints are useful for complex angles.
Edited by Tommy Styrvoky
I've bought several those pieces:
http://www.bricklink...tem.asp?P=89651
http://www.bricklink...tem.asp?P=60176
http://www.bricklink...tem.asp?P=64276
http://www.bricklink...tem.asp?P=50923
I meant to use them for custom suspension arms as I saw nicjasno to use them. Haven't touched them for almost two years now :-)
I have few of those as well but I (personally) do not consider them technic ... They are for poseable figures such as Bionicle and Factory ... kinda like if you like building dolls out of Lego, then those are the parts for you :).
Hmm I also dont use the old 6,5 suspension arms anymore... And I am kind of giving up on the old panels. Other than that I use most modern pieces except for the slizer/bionicle stuff.
Anything else?
Liftarms, never use them (plus a plethora of modern parts) ..
Edit : I do use the thin types sometimes (allthough I prefer the plate version, like 4264) and I like parts such as 2825/2905 etc
Yes, I'm wierd old school :laugh:
Edited by 1974
I have many Mindstorms parts that I no longer use, plus studded pieces, and 40 toothed gears. And 14 tooth gears. Come to think of it, I barely use any old style pieces at all. I don't use Technic plates either.
To be fair, I dislike old studded parts from the 80's, so I don't use such parts. With the exception of some plates, and trans-clear and trans-colored plates as vehicle lights, I only use modern studless parts.
Even though I agree with Bionicle pieces being rather useless in normal circumstances, I think that these pieces look really useful but I have never really found a use them.
That's exactly what everyone says whenever these three (especially the last one) are brought up :wink: Yet noone seems to have found a proper use for them so far. The first one was used in 8421 to strengthen the boom tip though.
Edited by jantjeuh
I used the third one in my (still WIP) Liebherr LTM11200. It is used to brace the connection between the upperstructure and the (two-way adjustable) arm that holds the (one-way adjustable) operator cabin. It was an almost perfect fit for the connection I wanted to make. (Three functions going through + a lot of mechanical torque + very limited space --> one-piece solution).
This is actually also a very nice piece that I only used once (in my F14 Tomcat):
44137.gif?0
The second one (above) was used by mahjqa in one of his vehicles, the metal grudge. A very clever use though.
Above post beat me to it by mere seconds ...
Edited by DrJB
