Gilberto_Aguilera Posted February 15, 2015 Posted February 15, 2015 Hello gents, in this topic we would discuss modding options to redesign the avengers age of Ultron Hulkbuster, i would advise all those who have the model and have already modded it to thoroughly describe the process. We advide to only use pieces from the set, but if you do have to use another piece, please do specify the piece number and colour so the rest of us can then purchase it if we wish to follow your steps. Furthermore i advise please not to be greedy, this topic is about sharing, so we can all have a good definitive hulkbuster. So please if you have a good design then don't hog the design. Quote
Scarilian Posted February 15, 2015 Posted February 15, 2015 (edited) - a normal Lego figure is 4 Lego heads high - Hulk is 7 Lego heads high - A hulkbuster should be just about 10 heads high Judging via the Lego head scale on the above image that makes the body around 5 heads with the legs and arms being 5 heads in length Edited February 15, 2015 by Scarilian Quote
Gilberto_Aguilera Posted February 15, 2015 Author Posted February 15, 2015 I agree, and i think the current hulkbuster needs to be a ton smaller seeing as how hulk is as big as hulkbusters legs Quote
Sir Gareth Posted February 15, 2015 Posted February 15, 2015 (edited) To be in scale with a minifigure, the Hulkbuster should be ~ 8 cm tall, or the height of two minifigs. To be in scale with the Hulk, the Hulkbuster should be ~ 9 cm tall. For reference, a minifigure is 4 cm tall and the Hulk is 7 cm. Edited February 15, 2015 by Sir Gareth Quote
Scarilian Posted February 16, 2015 Posted February 16, 2015 (edited) Scale images (Only image of a PNG hulkbuster that we have... so used that. Obviously the real head should be thinner and smaller) Edited February 16, 2015 by Scarilian Quote
Gilberto_Aguilera Posted February 16, 2015 Author Posted February 16, 2015 Looks good, what pieces can be used again for the new redesign? I think the head from the set of great, and maybe even the hands, but modded and without the stud shooters Quote
Rabbidpanda48 Posted February 19, 2015 Posted February 19, 2015 (edited) I did find this (NOT MINE) https://www.flickr.c...07/15963642550/ which seems to be scaled correctly and could be used as a starting point or i guess a "learning point" to get ideas from Edited February 19, 2015 by Rabbidpanda48 Quote
Gilberto_Aguilera Posted February 22, 2015 Author Posted February 22, 2015 I did find this (NOT MINE) https://www.flickr.c...07/15963642550/ which seems to be scaled correctly and could be used as a starting point or i guess a "learning point" to get ideas from Oh wow, that looks really good. Ross from MGFCustoms is also doing one, much like the rhino he had done last year, so we could take ideas from both of those. Quote
legofanatic12 Posted February 23, 2015 Posted February 23, 2015 (edited) Scale images The Hulkbuster in the right reminds me of Big Hero 6 Baymax in Iron Man design. Edited February 23, 2015 by LuxorV Please do not quote images from the same page. Thank you. Quote
Krikkit Posted February 23, 2015 Posted February 23, 2015 I thonk that a mobile frame zero frame might scale well. Quote
mrbean Posted March 9, 2015 Posted March 9, 2015 Came across this small scale hulkbuster. instructions http://yolo.tistory.com/213 Quote
asher125 Posted March 11, 2015 Posted March 11, 2015 Came across this small scale hulkbuster. https://www.flickr.c...04/16551802588/ This is probably a limitation of the LEGO scale, but in most models I've seen the waist and hips are disproportionately small and sparse compared to the torso and head region. That Hulkbuster definitely needs a thicker waist. If I had the pieces, I would add another set of torso flaps that go down to the hips. Quote
Tracytron Posted October 17, 2016 Posted October 17, 2016 On 10/03/2015 at 0:43 AM, mrbean said: Came across this small scale hulkbuster. instructions http://yolo.tistory.com/213 I have the official set does it need any extra parts? Quote
