VOTING THREAD Warzone 13: Katoren Breakout
32 members have voted
  1. 1. Who won the Katoren Breakthrough?
    • High Council
      11
    • Ulandus
      2
    • Desert King
      19
  2. 2. Which was the best HIGH COUNCIL MOC?
    • Little John
      12
    • Bregir
      20
  3. 3. Which was the second best HIGH COUNCIL MOC?
    • Little John
      20
    • Bregir
      12
  4. 4. Which was the best ULANDUS MOC?
    • Garmadon
      19
    • Kai NRG
      13
  5. 5. Which was the second best ULANDUS MOC?
    • Garmadon
      11
    • Kai NRG
      21
  6. 6. Which was the best DESERT KING MOC?
    • LordDan
    • Umbra-Manis
    • Jacob Nion
      16
    • MassEditor
      9
    • Robuko
      2
    • MKJoshA
      3
    • Dr. Cogg
  7. 7. Which was the second best DESERT KING MOC?
    • LordDan
    • Umbra-Manis
    • Jacob Nion
      11
    • MassEditor
      16
    • Robuko
      2
    • MKJoshA
    • Dr. Cogg
  8. 8. Which was the third best DESERT KING MOC?
    • LordDan
      4
    • Umbra-Manis
      2
    • Jacob Nion
      3
    • MassEditor
      5
    • Robuko
      7
    • MKJoshA
      9
    • Dr. Cogg
      2
  9. 9. Which was the fourth best DESERT KING MOC?
    • LordDan
      9
    • Umbra-Manis
    • Jacob Nion
    • MassEditor
    • Robuko
      8
    • MKJoshA
      10
    • Dr. Cogg
      3
  10. 10. Which was the fifth best DESERT KING MOC?
    • LordDan
      10
    • Umbra-Manis
      4
    • Jacob Nion
      2
    • MassEditor
    • Robuko
      6
    • MKJoshA
      4
    • Dr. Cogg
      5
Who Can Vote: EVERYONE
How to Vote: Look at all the MOCs from each side. First, determine which side won this battle. You should base your opinion on a couple different factors:
A)Build quality amongst all MOCs
B)Number of MOCs of quality [Please remember that Ulandus has a numbers disadvantage here]
C) Story of the MOC
D) Fit to the Warzone. If you are not familiar with the requirements of the warzone, please at least read the “mini-challenge,” “restrictions,” and “Judging” sections listed below.
You can weigh these in any order, or add your own categories. Please consider the three above in your decision though. You may want to clarify or lobby for your favorites in this thread, but you don’t have to write anything if you don’t want to.
Next, pick an answer to each question in the poll.
In the second three questions it will ask you to pick your favorite MOC from each side. Please judge on quality of MOC and its story. You can add other qualifications to your own judging process if you would like.
Finally, submit your vote.
Voting ends May 5
Warzone 11: Katoren Breakout
Who Can Participate: Everyone
Terrain: The Road to Qarkyr is not without its perils, but as the desert gives way to mountains, travelers find relief in this region. Water sources are not as scarce, small hamlets dot the roadside, and the foliage, soil of different hues, and wildlife can be quite pretty in the high desert that stretches towards the Rakath Mountains.
History / story: Not much happens in this region, it is mostly known as the road between Qarkyr and Katoren. There were no major battles, no notable citizens, nor nothing of value found in the soil, besides the spare small oil pocket. Mostly, the region has been used to travel through. Until now. Aymeri, Lord of Katoren, is one of the last lords holding out for the High Council, in and increasingly Desert King friendly region of the map. The Desert King has cut his supplies lines, and now Katoren risks losing the ability to feed its people. Although a small town, they are a proud people and will not give up without a fight. Which led Aymeri to his plan – the breakout. The easiest way to supply the city would be to quickly advance his forces along a swath of land to the nearest High Council held territory. However, the map is not his friend in this plan. His advisors devised a way that Katoren troops could take and hold a pathway to the sea, but it would require taking Qarkyr too. Lord Aymeri has confidence in High Council support if he can just get to Qarkyr… and there lies the problem. The land in zone F13 must be crossed. The DK and Ulandus spies have already sniffed a whiff of this plan, and since they cannot use their larger armies within the walls of Qarkyr, they have both turned them on this stretch of land to the west of the city. It is here that Aymeri and his allies must first defeat two armies, and then set their sights on Qarkyr and beyond that, the sea.
Mini-challenge: Although it began a forced march for the High Council troops, it soon became a pitched battle between three armies. But Aymeri knew this was coming. Before leaving Katoren, he had many of the houses disassembled for building materials and had his engineers, led by the famed Kaliphlin master engineer Sergio Jarrett(who just so happened to be in the area when the war broke out), craft movable fortifications. This would give the High Council an upper hand over the two other armies who were closing in on them. He also split his forces into stronger light platoons assigned to each of the moving fortresses. He confiscated every ox and horse within his land and assigned each to a team. High Council Builders should depict a scene where these mobile defensive fortifications are used in combat to repel enemies from one or both of the other two sides. Ulandus and Desert King should depict their soldiers overtaking one of these mobile defenses.
Special Category: Best high desert foliage (covered in blood…) As this battle happens in the sparse high desert, there should not be any structures besides the mobile defenses. The foliage, rocks, differing hard dirt and sand patterns should be the real star of the show… but there happens to be a battle upon them currently, so they should be splattered in blood and gore, but still retain their natural beauty somehow… The voters will choose the best depiction of High Desert Foliage with combat stains… (you can depict foliage without stains on it too, just need at least some that has been tainted by battle. The winner of this category will be crowned “Enricher of the Soil” of Kaliphlin.
Best Transformer: It is not required that your MOC can actually transform from mobile to a stationary defense platform by natural movement – but if it doesn’t, you can enter this category (no taking apart more than a few pieces and putting it back together in a different formation.) You may also submit additional pictures / video of the MOC in your thread. Judges of the entire zone will be asked NOT to judge the results of the zone on the ability of MOCs to transform, but to judge this as an entirely different category. Winner of this category becomes the current“The Historican Master of Transforms,” and will keep that title until another transformer challenge comes up in the future (there won’t be another in this challenge at least. )
Restrictions: 32x16, with limited overhang. Must have an irregular base.
Due Date: April 26th
High Council Entries:
LittleJohn - Aymeri's Mobile Fort
Bregir - Not just another "Ship of the Desert"
17090195969_20f3979610_c.jpgW
Ulandus Entries:
Garmadon - Why!? If you haven't put it together backwards!
Kai NRG - Getting Around the HC
Desert King Entries:
Lord Dan - Cleaning Up the Mess
Umbra-Manis - Reversal of Fortune
Jacob Nion - Katoren Ambush
MassEditor - A Treacherous Road
Robuko - A Katoren Barbecue
MKJoshA - Prairie John
Dr. Cogg - All-in-one Wagon
Edited by SkaForHire
Best high desert foliage (covered in blood…): Dr. Cogg
Best Transformer: Kai
Bloodiest sand: Jacob
Best Transform: Dr Cogg, although my favourite fortress was Bregir's
Thank you :blush:
Jacob for bloodiest sand.
Dr Cogg for best transform.
Honourable mention to Bregir, whose build was hands down my favourite of this warzone!
I am very honoured, mylord! *bows*
Very sorry about that Bregir! Got you fixed up!
No probs - and :thumbup: for you for helping Ska out!
Jacob Nixon for the "enricher" mini-challenge, that gigantic pool of blood is just too good.
Dr. Cogg for "best transformer", hands down.
I'll echo the comments about Bregir's mobile fort--I think it was definitely the overall best entry here.
MassEditor for best blood, although that shot was not shown here.
Garmadon for best transform.
I agree about Bregir's build; the idea for the shape was just brilliant!
