I present my new MOC, MOD
Mercedes Arocs SILENT EAGLE Flight Simulator.
Model was built for a competition on LUGPol.pl (polish AFOL forum).
dscn6976.jpg_thumb.jpg dscn6990.jpg_thumb.jpg dscn7001.jpg_thumb.jpg dscn6997.jpg_thumb.jpg
It is a flight simulator that can sometimes be found in amusement parks or at various air shows. But it is not based on any particular model.
The original chassis is extended by a few studs between the axles to accommodate an additional pump in the compressor and gear drive for a second pair of outriggers behind the rear axle. Behind the Arocs cabin I installed servo and Ir to a control model . Everything above the chassis is already my design.
dscn7008.jpg_thumb.jpg dscn7027.jpg_thumb.jpg dscn7049.jpg_thumb.jpg dscn7054.jpg_thumb.jpg
It is full motion flight simulation platform with 6 small pneumatic cylinders each individually connected to a switch. The simulator is manually controlled from the cab. It is powered from its own compressor, two small pumps, airtank and PF XL motor.
Additionally simulator is equipped with a new narrow long cylinder to open the door. It also has LED imitating projector and white panel acting as a screen.
dscn76690.jpg_thumb.jpg dscn76694.jpg_thumb.jpg dscn7056.jpg_thumb.jpg dscn7100.jpg_thumb.jpg
Two independent pneumatic systems are there to support vehicle outriggers does not lose pressure while playing simulator .
LEDs are also in front and rear lights and running automatically when motion model.
Weight 3.9 kg
Length 61 cm
Width 17 cm
Height 24 cm
2 x PF L motor propulsion
1 x PF servo steering
1 x PF L motor mechanical functions
1 x PF XL motor simulator compressor
3 x PF swiches
4 x PF Led
6 meters of pneumatic hoses
http://www.brickshelf.com/cgi-bin/gallery.cgi?f=559347
Movie
Edited by Samolot
I'm glad this made it to its own thread. When I first saw it I was gob smacked..then I saw it again and still amazed. The flight sim is unreal. Black really suits the truck. The detail you have manged and the play-ability makes this one of the best mocs I've come across.Awesome work. :wub:
This looks beautiful. The decals and custom colored parts really stand out, and the simulator platform is a clever design as well. Where did you get the trans-yellow tubes?
Hello thanks for all positive feedback.
There are no custom colored parts in this build, only pneumatic cylinders are covered with stickers.
Trans-yellow tubes are silicone fuel tubes and I bought them in the RC model shop.
