Awesome tool!
Only a shame a lot of colors are not available at certain bricks but the tool still uses them.
As example on 1x2 bricks in red-trans doesn't exist.
Any way to make a fix for this? I am importing the LDR into stud.io and it gives that error :(
Yes, you are right - and there will be others - I choose colours that look nice digitally but they may not exist physically (but there should be something similar(ish)!)  Limiting the colours and bricks and to exact physical brick and colour combinations is on my to-do list!
The colours are defined in the function "selectColourAndHues" , where a dictionary "colourAndHues" in that function sets the variety of hues for each of the named colours and the first number in the list of values for each named colour is always trans (so 36 is trans red, 38 is trans orange etc).  Adding "transparency = False" at the very start of the function will exclude all transparent bricks and manipulating the dictionary "colourAndHues" will allow you limit the colour options but even then you would ideally need to cross check any selected colour with the actual brick part which subsequently has that colour applied to it against bricklink's physical parts and colours - this would take me some time to figure out but I am thinking about it!
Edited by pennyforge
On 12/9/2019 at 9:04 PM, Philo said:
That i didnt know, i imported the created file into stud.io
@pennyforge
Thanks, it has no hurry for me, but was wondering if it was possible :)
Thanks anyway for the awesome tool! :)
Edited by kokkie20
Hi @Philo
So you'll need to install a version of python 3 - I'm using 3.7.1 but any version after 3.7 should be OK
https://www.python.org/downloads/
then you'll need to install numpy (a python library for dealing with big numbers and matrices) and pillow (a python library for manipulating images).  Once you've installed python you can type the following commands into a cmd window to install numpy and pillow.
pip install numpy
pip install pillow
Sometimes though pip does not automatically get added into your path variable (after installing python) so you need to specify the full path to the pip.exe file in the cmd window which is usually
C:\[Directory for Python37]\Scripts\pip install numpy
C:\[Directory for Python37]\Scripts\pip install pillow
Once numpy and pillow have been installed you should be able to run the leg-o-letters.py python file which will ask you if you want to add your own text/font size/colours etc
Hope that helps - if not let me know
N
Hi @pennyforge, very interesting tool.
If you edit the first post to create a comprehensive presentation page, including the detailed instruction you wrote in the following posts, I will add it to the Section Index.
