Milan Posted June 6, 2010 Posted June 6, 2010 (edited) Hello I want to present my newest moc JCB JS115 tracked excavator... ...yes, yes, another excavator...but I just cant help it! JS115 is the smallest JCB tracked excavator, there are smaller machines, but they are different range (micro and midi) and they does not appeal to me at the moment. LINK to the real machine. Why the smallest excavator? Because my previous one, the JS360 was very big and heavy, and therefore not able to move and operates easily under its own weight smoothly as I want, not to mention under some load. So I wanted to create smaller one, which will be able to realistically represent model of a excavator. Goals during construction: Realistic functions, Modelling realistic body carefully using official PDF file, Scale exactly 1:13 Efficient use of the motors This model has to be very agile and nifty, so I made few drastic moves, like getting rid of the gears (the whole model has just 5 gears) and simplified cylinders. Also, It has to have realistic moves, meaning speed of the arm and the tracks. So, to fully utilitise the PF motors, I have connected them directly to the sprocket wheels and cylinders. That is how its done on real machine, except it uses Hydrostatic motors directly on sprocket wheels, which are fed by pump. On the model this concept would be unrealistic since it does provide greater speed of movement of the tracks and arm, unless operator uses Speed Remote controller That way, operator choses one of the 7 speeds, and the model becomes very precise and realistic digging tool and can accelerate gradually or make very delicate moves with the arm. 1:13 scale The model was developed for a week or two on a computer to make sure almost every bit of it is scaled down in a proper way. I wanted to achieve the perfect look, as the real machine, meaning "big bubble" look. Reference was PDF file from official JCB webpage, every single line of the machine is scaled down. It was of great importance to me, to have exact scaled replica. As you can see, this machine has a little bit unusual look compared to the bigger brothers, it looks like it is unstable or just like a toy, or it looks like tracks are too short, but thats why it had so big impact on me, and even it does not look like that, it can provide good digging performance and it has 12 tonnes. Functions: Drive left track-XL Drive right track-XL Superstructure slew-M Arm up and down-2Ms Dipper-M Bucket-M Tracks: Is 26 studs wide. H shaped frame in few layers does great job in providing stable platform. One XL provides torque for each track, in 1 to 5 reduction so this model has great power to weight ratio. Everything here is symmetrical. Each side has side rollers (like on real machine) which keep the weight off the wheel sprockets. I had to rebuild the whole undercarriage 5 times to achieve the stage I am fully satisfied with. It was very tricky. Turntable: Is 14 studs wide. This was the most difficult section to create. Hardest part was to make it so small and sturdy. It has to have big turntable part in the center, then worm gear on it, then ring of black rollers around it, then it has to have room for PF cables from undercarriage motors, then vertical bracing beams (which holds the boom and frame of the superstructure)...and all of this has to be sandwiched between tiles underneath for smooth rotation and superstructure above it, and placing all that between tracks, which is narrow ...connecting all that and make it sturdy was a nightmare, but I have done it. Superstructure: The cool part! It is 24 studs wide. As you can see on the pictures, this machine is full of curves...at the back there is that sloped section, and at the top there are rounded edges. I have enjoyed modeling that on my model. The most difficult part was that tail part, because it has 1x3 slopes at the top, black section in the middle, and 1x2 slopes at the bottom...and all that is tilled. It looks simple from the outside, but inside it was nightmare to make it...I don't care, it was a fun. The best part is that it is high exactly like the real machine just in 1:13 scale! Strength comes from the Technic bricks at the bottom of the superstructure, but it was constructed that way that all the pressure from the boom and the cylinders are delivered to the turntable and its vertical bracing beams. It took me a few rebuilds to achieve that. I also wanted for superstructure to have some details like openable hatch at the back, where the engine is mounted...in this case there is new LEGO rechargeable battery which is great as it can be charged without removing it from the model. At the sides of the body there are two openable storage areas, where are chains, tools and other misc on one side and oil filters and fan on the other. Cabin: Is 8 studs wide. It is the same size as on previous excavator, they are the same size on the real machine, too, but it get a mayor facelift, basically it is built from scratch. Once again it has flexible tubes and slopes done in SNOT. It has internal gadgets at the right side. Cabin is completely separated from the superstructure (it is connected to the frame with 4 pins, and can easily be removed for any reason, Arm: Due to scale and the small size of the real excavator, the arm in 1:13 scale is just 3studs wide. It was hard to find a perfect mounting points for the arm and its cylinders, because that points has to be heavily braced. I managed to achieve relatively realistic range of movements. The arm is strong enough that it can bear the whole load of the machine on itself, as well to perform wheelie on each side. Arm can withstand 500 gr, and the superstructure still can rotate. Cylinders: As simple as possible...M motors connected directly on LAs...and it is effective, it has power to operate the arm in a very agile way, and it can lift any side on the excavator while digging. Buckets: As on real excavator, depending on the ground thickness, there are few buckets available, so on this model 4 bucket were adopted for the arm. There is big bucket 18x10, medium bucket 8x6, small bucket 10x4, small bucket 4x4 and brick-built bucket. Stickers Were made by me, from PDF files, printed using LEGO color scheme. I have always wanted to make a model with full details, using stickers. I like them, as they provide realistic look of the real machine. Controller: Behind the scenes: I have always wanted to build tracked excavator that, hopefully, will be good enouh to compete with the greatest excavator of all time, the JCB JS220, made by Jennifer Clark. I think that her work affirmed my passion for the excavators, and pushed me in building more realistic and more complex models. So, my aim with this model is to try to achieve realistic look and technical possibilities of her model. My model is excatly 50 percent bigger than her, but since my JCB is much smaller in real world, both models are relatively similar in size. Also LEGO is going to present their newest excavator, 8043. It looks great and I wanted to make my own excavator that will be very close in size. So, that was just one push more to invest more time in my model. I think that I can call this model my Ultimate Tracked Excavator and my best MOC ever! VIDEO http://www.youtube.com/watch?v=nVVnxHSUCJs Edited February 11, 2013 by Milan Quote
efferman Posted June 6, 2010 Posted June 6, 2010 gorgeous look, gorgeus mechanics. iam very impressed Quote
dhc6twinotter Posted June 6, 2010 Posted June 6, 2010 Excellent build! I like how you built the turntable and the railing! Quote
paul_delahaye Posted June 6, 2010 Posted June 6, 2010 Love it, just think it needs a bigger bucket! Quote
Zerobricks Posted June 6, 2010 Posted June 6, 2010 Great looking, functional and fast! Its really one of the best models! Did you use stickers on the cab? Quote
Blakbird Posted June 6, 2010 Posted June 6, 2010 A truly stunning MOC in design and function. Kudos to you. This would not look out of place next to Jennifer's JCB JS220 and is a fitting successor. Quote
Milan Posted June 7, 2010 Author Posted June 7, 2010 Thanks, guys! paul delahaye: Actually, this bucket is a little bit bigger than it should be, but that is the closest one. Just take a look at the top picture of the real machine, how small the real bucket is. Zblj: Yes, I used one yellow strip to create that JCB color shape. By the way, only the bottom part of the cab is yellow, the rest is all black. Quote
Jurgen Krooshoop Posted June 7, 2010 Posted June 7, 2010 I absolutely don't mind you making another excavator, because yours are just sooooooo pretty. Quote
Countdown Posted June 9, 2010 Posted June 9, 2010 Awesome, Love the turntable, and the LAs directly coupled to the PF-motors; simple yet very ingeneous and effective. It's scaled perfectly and looks like a million bucks! Congrats! -Nick Quote
Daiman Posted June 10, 2010 Posted June 10, 2010 This is a massive piece and not to mention a great post for details. I pass the local CAT workshop everyday where they build similar machines and I must say yours is straight off the block. Yum Yum and please more to come. D. Quote
Frequency Posted June 15, 2010 Posted June 15, 2010 looks awesome the only thing i wasn't sure of after the story and video was is there another controller for controlling the two XL motors that run the tracks? as the two controllers in the diagram run 4 functions (slew, bucket, dipper, boom) leaving left and right tracks would have to operate seperately Quote
Milan Posted June 17, 2010 Author Posted June 17, 2010 looks awesome the only thing i wasn't sure of after the story and video was is there another controller for controlling the two XL motors that run the tracks? as the two controllers in the diagram run 4 functions (slew, bucket, dipper, boom) leaving left and right tracks would have to operate seperately Thanks, Yes there is another bigger controller, LEGO speed remote, which allows the excavator to gradually accelerate and deaccelerate, which looks great. For purpose of the video, I used normal controller, as the video exceeds YouTube 10min limit. Few more pictures: Quote
lombardini003 Posted March 22, 2015 Posted March 22, 2015 Beautiful moc. Can you give us a closer clear picture of your controller. Thank you. Quote
sm1995 Posted March 22, 2015 Posted March 22, 2015 This is truly superb, I have a really hard time believing that that's made out of Lego. Quote
BusterHaus Posted March 22, 2015 Posted March 22, 2015 What a beautiful MOC. Any reason why the cables were not routed inside the arm? It's a minor distraction, it doesn't diminish the kudos this project deserves. Quote
Technic-Kobaltz Posted March 22, 2015 Posted March 22, 2015 The cables look good to me, they represent the hydraulic hose on the real machine. Quote
Milan Posted March 22, 2015 Author Posted March 22, 2015 Wow, my 6 year old Moc is in action again! :) Lombardini, sadly, i dont have any pictures of the controller, but it is standard controller with attachment for 2 plane operations. I will find it on net and post it here; Video is again online: Beware, video is 6 years old, long and low res :) Quote
