As part of this thread on designing a working EMD Unit, I had also designed a version of the Swiss Railways AM 843 unit.
Currently only in LDD until some more bricks arrive (always the way) - but there is sufficient space to also fit a motorised bogey, IR unit and Rechargable Battery.
nice one there, This is the only Diesel I like here in Switzerland, and you got shape and color spot on.
Where do you fit the battery pak? Replace the nicely detailed diesel engine or is there some more hidden space?
Battery fits at the front - closes to you in the image. Just. It is tight but the space is there.
Motor replaces the front bogeys - use the PF ones from the Cargo Train.
IR unit fits the other side of the cab... before the 6 valve EMD unit.
