My recent build is this suburban passenger train. It is not a replica of any real rolling stock, though the design and livery are roughly based on UK train operator South West Trains.
The train is an electric multiple unit, consisting of three units. A driver's cab is located at both ends of the train. Unlike the model mentioned above which draws electricity from third rail this train picks it up from overhead line.
The train is 96 studs long. Counting also the bumpers and coupling magnets which protrude slightly beyond the construction, the entire length is 99 studs.
The driver's cab is virtually completely snoted. Actually this technique left a slight aesthetic flaw – cutouts at the end of the roof above the cabin.
Front end
The interior of the front car with segregated driver's cab. The same design is employed in the rear car, with the only difference being the fourth passenger seat which is missing here beacause of the placement of the battery box.
Though the train appears to be supplied with energy from external source it still needs some standard PF components for independent motion. The IR receiver and battery box are placed in two different cars which allows easier masking of the compoments and better utilization of the passenger compartments. The motor is placed under the middle car.
The interior of the middle car
The pantograph is not completely my invention but I used the design that has already appeared in some creations here on Eurobricks.
This is a nice train design with an interesting (lively) colour scheme. The idea to segregate the battery box and IR receiver is great, as it leads to more room for the minifigs to sit in both cars. Also, the snoted cabin is a nice touch to round up the front design, specially seeing that the original train is pretty ''box-y''. Nice work.
Edited by Redhead1982
No doubt, this is an excellent 6W passanger train, however, I add some suggestions to improve it.
For example, the pantograph design is well known and nice, but the lower part is missing (for me). Using a T-shaped bar and one more 4-5L hose per pantograph will improve a lot. The other part I don't like so much are the doors. As I see, all the doors are 2 studs wide, it can be replaced with five plates in SNOT. SNOT can easely made by blue brick 1×1 with one stud on side, a red plate - 1×2 trans clear brick - red tile combination could improve the look of the doors.
Of course, these are little things, but think about it. :)
It does indeed look a lot like the trains run by South West Trains, (They come to my home station.) but I should say that at least the ones that travel on the South West Trains route from my home to London and back do not have pantographs at all as they pick up the current from a third rail that runs along the ground next to the wheels, we don't have any overhead cables down here in the deepest south. Other than that it pretty much captures the essence of the trains.
I often bemoan that nearly all the modern LEGO trains based on European ones have pantographs as for me unless I travel a long way i do not see them at all.
Hey, I really like those a lot. I especially like the color stripes and the fact that you strung cantenary. Do you have any pics of the cantenary going around curves? Thanks for sharing.
I used to feel that way too, but the pantograph is easily removed and the trains still look great. The Horizon Express would look a little odd in this fashion however, IMO.
Joe
It, unfortunately, reminds me too much of my years commuting into London. ( :ugh: x 1,000,000)
But it does look good - the colour scheme is spot on and I like the SNOT front, although I think Ashi Valkoinen may have a good point about the doors
Thanks for sharing it with us!
@all: Thanks.
I already used this technique for the driver's cabin door, slightly discernible in fifth picture. Your suggestion is definitely in the place so I might use it for the train doors too.
Unfortunately no, though I've been tempted to build them along one curve at least. As the curves are quite tight I would have to stack them relatively close together and that would consume lots of certain bricks.
As it is intended to be a part of a display (sometime in the future probably) I put the pantographs in as my addition to the basic design of an EMU, since very few displays of lego trains I saw actually had both pantographs and overhead lines. Though adding a third rail to the track to re-create a power source wouldn't be difficult on straight tracks, but would probably have to be done with some flex elements to make the way around the curves and points.
It looks nice and has a definitely commuter train feel to it. Although the colours are right I'm not sure that the layout of the colours matches any South West Trains livery that I've seen and you have missed the most important part of any model of a UK train - The yellow front and rear which is a requirement of UK trains.
Cheers
Rog
This looks great especially the front and catenary. All you need to do is fill it with 3000 minifigs and it will be a perfect replica of a rush-hour train to London.
True- reminds me of my train rides to London from Colchester 20 yours ago... fun days. :sceptic:
Kivi, I think this is great. :thumbup:
