Like a lot of CMF figures, I get inspired simply by the figures themselves - the ideas seem to just pop in your head when you see the figures, and this was no different. So I wanted to build a mountain for the mountain climber and Yeti; at the same time, I wanted to make a brick based tunnel for my winter village trains. So, without further ado, I present my entry for the contest; "Yeti Mountain."
DSCF2023 by FredJH, on Flickr
DSCF2028 by FredJH, on Flickr
If I have the time, I will post the mountain in the village itself, with trains going through, but the problem is I needed to modify it (two studs wider in order to fit trains better), making it 18x16, so I do not want judging to be based on the modified version, but the version I am showing here (16x16).
This is 16x16? Wow, amazing detail packed into such a small space!
Good luck in the contest! Though I thought it had to be Winter MARKET themed...
-Sci
Edited by CM4S
No... probably not! I was planning this anyway, though, so I figured I'd make it for the rules.
Don't worry, you're not the only one. :tongue: Still, great MOC nonetheless.
-Sci
