Posted March 3, 201410 yr So, 75034 Death Star Troopers just started showing up in Milwaukee, WI, U.S.A.. yah! I purchased two. Then, I remembered this scene in the Star Wars I wanted to build. Just for fun. First, some off the center with an angle hing at 18 degrees. Copy, Paste, Connect... The loop can connect to a base plate at the bottom and top. A wall can be made so the can rest the top on the bottom for more support. Build a control area. Note: added safety rail. Put all the parts together Copy, Paste, loop....and you get. Test fire beam OOPS! Melted safety rail. Now, I know why they do not have a safety rail in the movie. Side view Note: Bottom and top are 48x48 base plates and the side is covered with 48x30 plates area. Other side has a door. Side walls connect to top and bottom base plate Painted red so you can see connections. Hope you like it. I had fun building.
March 3, 201410 yr Thats a very well done scene! regarding to the title of your topic, you dont need name it free build unless its a SoNE (Shadows of Nar Eurobricka) but you can if you want anyway , keep up the great building.
March 4, 201410 yr Good work with the LDD design. With the rail added now, I certainly hope your troopers won't be leaning all day. These troopers will have a safe and comfortable job knowing they're helping to secure an orderly and peaceful future for the mighty Empire.
March 4, 201410 yr Author Good work with the LDD design. With the rail added now, I certainly hope your troopers won't be leaning all day. These troopers will have a safe and comfortable job knowing they're helping to secure an orderly and peaceful future for the mighty Empire. Note: Rail melted in test fire of beam. The rail sticks out too far.into the beam. No leaning or you will get in the beams way. As far as the topic of the post, I was sleepy when posting and had no clue as what to tag it. Should have been [iSBSNP] I Should Be Sleeping Not Posting. [MOC][LLD] Might be better.
