Zerobricks Posted June 6, 2014 Posted June 6, 2014 (edited) After completing the first bridge layer I came up with an idea for a better bridge design: With this updated design the bridge was made longer, stronger and more car-freindly. The bad side was that it was heavier, so I had to come up with a new, more powerfull bridge laying truck. The new truck once again uses only M motors for all 3 functions The same motor that steers also propels the winch. To stop the steering mecahnism from breaking apart while winchin I used a white clutch gear: Because of the large forces involved in lifting the extended bridge the only solution that worked was a simple lever and a winch. Here's the finished model: And a small blooper: Edited June 6, 2014 by Zblj Quote
Nazgarot Posted June 6, 2014 Posted June 6, 2014 Surprisingly strong. Very nice concept and model! -ED- Quote
skriblez Posted June 6, 2014 Posted June 6, 2014 Nice bridge work. Did the Fox break the beams when it fell down? Quote
Zerobricks Posted June 7, 2014 Author Posted June 7, 2014 Thanks guys! Yeah the beams broke when fox fell on the slipped bridge. Fox had a bit of fixing to do, but nothing broken unlike the bridge. Quote
emilstorm Posted June 7, 2014 Posted June 7, 2014 Quite brilliant, i imagine it's one of those builds where you are a little surprised it works I would not have thought it would be so strong. Quote
Zerobricks Posted June 7, 2014 Author Posted June 7, 2014 (edited) Quite brilliant, i imagine it's one of those builds where you are a little surprised it works I would not have thought it would be so strong. The biggest problem was making a lifting mecahnism for the bridge. You can imagine the torque you need to raise the extended bridge. I tried LA's, worm gears and turntables, but nothing beats a simple lever and a winch. Edited June 7, 2014 by Zblj Quote
Zerobricks Posted June 7, 2014 Author Posted June 7, 2014 The Fox = Destroyer of bridges! Yeah its too fat Still I think the bridge did well, seing it weighs only some 500 grams, and the fox 10X MORE Quote
