Since I was last active, I have enrolled in the 16mm Association of Narrow Gauge Models and with the next year will be build two models railways of which one will be a Lego model railway and a model Railway at 16 mm scale using SM32 track to represent 2ft narrow gauge track, while looking at Locomotives options as I still need to buy or build my 16mm scale locomotive, this gave me a idea, why not try to build a Lego 0 Gauge scale version of my LNER A3 Flying Scotsman Steam Locomotive which the design could be used to develop a 16mm scale locomotive using 32mm track to run on.
Over the last view days I started to mess in Ml cad and LDD 4 to see if a chassis which will be able to run on 0 Gauge track, the proof of concept design was finished in LDD 4 this morning at 10 AM UK time
The model when built will have a chassis frame 3 studs wide allow the locomotive wheels to be set a 32 mm Gauge to be able to run on 0 Gauge track, I also have worked out how to motorized the locomotive, the body I will build at 7 studs as this seems to a match for 0 Gauge Locomotive width.
View of the new chassis frame with the gears set up allowing a easy way to motorize the locomotive.
View of the new chassis frame showing the 3 stud wide frame and the distance between the frames and the trains wheels which need to be set like this to be able for the wheels to be set at 32 mm Gauge.
The next step is to build a physical model and do a test once the Peco 0 Gauge track which I have ordered from Ehattons arrives in the post.
