Showing results for tags '0 Gauge track'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Over the last couple of weeks I have been designing a Lego 16mm Scale Narrow Gauge Locomotive based on Roundhouse Engineering Live Steam Locomotive 'Lady Anne', the Lego version is 5 Inches Wide, 6 inches high and 13 inches long, the narrow gauge locomotive is powered by Lego Power Functions XL Motor, Battery Box and Receiver which the Locomotive Body fits over The locomotive body can be separated from the locomotive chassis to allow access to the Lego Power Function Battery Box to turn the power on or change the batteries when needed or to adjust or fix the gearing if something goes wrong. To set the Big Ben Bricks XL train wheels exactly at 32mm Gauge I had to put 3 Nylon Washers between the Lego Technic bricks and the Big Ben Bricks XL train wheels, I used 18 nylon washers, the washers were brought from Modelfixings. The information below shows the dimensions of the nylon washers I used. Thread Size MF Ref Inside Diameter (mm) Outside Diameter (mm) Thickness (mm) M5 MF-NW05 5.3 11 1.0 The Lego 16mm scale Lady Anne narrow gauge locomotive model is not finished, the coal bunkers on the tanks need to be finished, the lids to the water tanks need to be added, the cylinders and the connecting rod to the coupling rod need to be added, the rear coal bunker needs to be added, plus other details like pipes, outlining and naming plate, working front and rear lamps. I may be adding Brandbright Centre Buffer Coupling which will be permantly fixed to the locomotive by drill a hole in the spot where the current buffer, this is so I can try to pull some 16mm coaching stock with my Lego 16mm scale Lady Anne narrow gauge locomotiv. A back view of the Lego 16mm scale Lady Anne narrow gauge locomotive body, the holes in the back are for Lego Technic Pin with Stop Bush (Part 32054) which bolts the locomotive body to the locomotive chassis. A front view of the Lego 16mm scale Lady Anne narrow gauge locomotive body, the Dish 8 x 8 Inverted (Radar) has to be removed allowing me access to Technic Pin with Stop Bush (Part 32054) which bolts the locomotive body to the locomotive chassis. A top view of Lego 16mm Scale Lady Anne Narrow Gauge Locomotive showing the boiler and the unfinished tank tops (coal bunker and water tanks lids to be added). A another top view of the Lego 16mm Scale Lady Anne Narrow Gauge Locomotive, the cab roof is temporary as the bricks I will be using have not arrived, and the back small round brick is where the whistle will be once I have the rights color bricks. A view of the Lego 16mm Scale Lady Anne Narrow Gauge Locomotive chassis showing the Lego Power Functions XL Motor, Battery Box and Receiver. Another view of the Lego 16mm Scale Lady Anne Narrow Gauge Locomotive chassis showing how wide the Locomotive is compared to the 0 gauge track. Side view of the Lego 16mm Scale Lady Anne Narrow Gauge Locomotive chassis showing the red coupling rod (Lego Technic Liftarm, 15 L). A back view of the Lego 16mm Scale Lady Anne Narrow Gauge Locomotive chassis showing the red buffer plate with the single buffer which will be replaced by a Brandbright Central coupling buffer (90 % of 16mm narrow gauge locomotives and rolling stock have a single central buffer with a hook for a 3 length chain to be attached). Another back view of the Lego 16mm Scale Lady Anne Narrow Gauge Locomotive chassis showing the rear buffer, Lego Power Functions XL Motor and the wire channel (used to keep the wire tidy and away from the gearing and allowing easy fitting of the Lego 16mm Scale Lady Anne Narrow Gauge Locomotive body. A front view of the Lego 16mm Scale Lady Anne Narrow Gauge Locomotive chassis A view of the bottom of the Lego 16mm Scale Lady Anne Narrow Gauge Locomotive chassis showing the wheels correctly set at 32mm gauge A closeup view of the bottom of the Lego 16mm Scale Lady Anne Narrow Gauge Locomotive chassis showing the coupling rods and six Technic Gear - 24 Tooth which allow me to get the coupling rods working ( might be replaced by Big Ben Bricks Medium Train Blind Driver). A close up view of the bottom of the Lego 16mm Scale Lady Anne Narrow Gauge Locomotive chassis, showing some of nylon washers I got from modelfixings, the washers allow me to set the wheels to 32mm gauge. One of the nylon washers I use. close up view of the Lego 16mm Scale Lady Anne Narrow Gauge Locomotive chassis showing the front end of the locomotive chassis with the two Lego Technic Pins with Stop Bush (Part 32054) are in a Lego 1x4 Technic brick which is the same height as the Lego Technic brick in the front of the locomotive body. close up view of the Lego 16mm Scale Lady Anne Narrow Gauge Locomotive chassis showing the read end of the locomotive chassis with the two Lego Technic Pins with Stop Bush (Part 32054) are in two Lego 1x1 Technic brick which is the same height as the Lego Technic bricks in the rear of the locomotive body. Youtube Video of Lego 16mm Scale Lady Anne Narrow Gauge Locomotive Running Link
