Showing results for tags '10241'.
10241 Maersk Line Triple-E Ages 12+. 1,518 pieces. Build the Maersk ‘Triple-E’ container vessel – a true giant of the seas! US $149.99 - CA $179.99 - DE 129.99 € - UK 109.99 £ - DK 1199.00 DKK Presenting the largest ship in the world – the record-breaking Maersk ‘Triple-E.’ Built from over 1,500 bricks, the model recreates the real vessel in amazing detail. Our LEGO® designers have included rare colors such as medium azur, dark red, sand blue and sand green. There are rotating gold-colored screw blades leading to the brick-built twin propeller engines, which you can view through the window built into the port side of the ship. You can even customize it by adding or removing the containers. This authentic set includes a display stand and fact plaque with detailed information about the ship and, as a finishing touch, there’s the gold coin that is added under the mast of all Maersk Line ships for good luck on their voyages. This model is perfect for LEGO fans! Features include rotating gold-colored propeller blades, brick-built twin 8-cylinder engines, viewing window into the engine compartment, adjustable rudders, detachable lifeboats, removable containers, rotating crane arms and a special ‘good luck’ coin Includes rare medium azur, dark red, sand blue and sand green colored elements Play with the model on carpeted surfaces or mount the model on the display stand Building instructions also include interesting facts about the real ship Includes 1,518 bricks Ship (mounted on stand) measures over 8” (21cm) high, 25” (65cm) long and 3” (9cm) wide Available for sale directly through LEGO® beginning January 2014 via shop.LEGO.com, LEGO® Stores or via phone: US Contact Center 1-800-453-4652 CA (English) Contact Center 1-800-453-4652 CA (French) Contact Center 1-877-518-5346 European Contact Center 00-800-5346-1111 All pictures are clickable for high-resolution versions Plaque Engine Engine in situ Lifeboat Bow Mast Stern Rear view
