Showing results for tags '10265'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 6 results
  1. Dodge Viper - 10265 c-model I made my first attempt to the Viper before building the Hummer. I wanted to use the white stripes offered by the 10265 set. I must admit that the Viper is one of the most iconic cars that use these painting. The problem is that it has an extremely slim silhouette, and the Mustang parts are much more suitable for the construction of an angular body. The final model is the result of 5 approaches. On the fourth, I had the model almost finished and all I had to do was construct a rear diffuser out of the scraps. It was not without a slight remodeling of the rear bumper, which left me with a few additional parts, which I knew would be very useful in the front. This way I demolished half of the car and it was a good decision. Thanks to this, the model has definitely gained stability. There are a few delicate details, but there is no risk that any of them falling off when you grab onto any part of the vehicle. The fairly low profile of the whole and the desire to reproduce the engine dummy in a decent way, eliminated the possibility of installing a torsion axle, which takes up so much space on this scale that it would have a negative impact on the appearance. Technical info Rebuild of the set 10265 Ford Mustang Model: Dodge Viper Parts: 984 - also used extra parts Height: 10,5 studs (8 bricks and 2 plates) Width: 16 studs (17.5 studs with mirrors) Lenght: 38 studs Functions: Opening doors and hood. Instruction: 298 steps on 189 pages. Flickr Brickshelf Instagram Rebrickable
  2. Set 10265 probably needs no introduction to anyone. A fantastic model with a great ratio of the quality and quantity of pieces to the price. Initially, I bought it with the idea of placing it on a shelf. Until the firas popped out with his rebuild version of the Mustang current generation. Despite a few shortcomings, his model definitely makes a wow effect, given that it's a rebuild of this shortcoming. I had quite a lot of ideas for making another car and all of them became a nightmare for me. I completely couldn't reconcile the quick-end bricks with the sensible look. For example, when building a BMW M3 E46, after using about 80% of the parts, I had only half the car. Fortunately, I quickly abandoned Shelby Cobra, discovering that someone had already built a pretty cool one. There was also supposed to be a Dodge Viper, but then it seemed impossible to reproduce them from the available bricks. I am currently doing a second try on the Viper and this time it should wiek. However, I was a bit disappointed that I couldn't make a constructing anything sensible. The smaller scale turned out to be beneficial. Instead of the standard width of 16 studs, I focused on something at 14, or maybe 12. I considered a few off-roaders and finally I choose Hummer H1. A supposedly smaller model should solve the limited supply of parts. Unfortunately not with the car body. Doors and root i was made from rest of scraps. On this scale, it was also a problem to mount a torsion axle. Copied one from set dropped out because it is too wide. I managed to slim it down a bit, but it had a negative impact on the stability of whole the structure, not to mention the visual values. I gave it up and ended up with a dummy engine and shock absorbers. The cabin is also quite conventional. Fortunately, the model itself resembles the original from the outside, and nobody has any problems with recognizing what kind of car it is. The whole thing is stable and the model can be moved forward and backward. Real level expert. Technical info: Rebuild od the set 10265 Creator Expert Ford Mustang Model: Hummer H1 Parts: 773 - also used extra parts Height: 13 studs (9 bricks and 2 plates) Width: 14 studs (15.5 studs with footrests) Lenght: 28 studs Functions: All doors, hood and tailgate are open. Moving wheels. Instruction: 197 steps on 142 pages. Instagram Flickr Brickshelf Rebrickable
  3. MOC #64 Ford Mustang GT500CR Classic video is published now. I designed this Mustang when #10265 coming out, but I didn't satisfy some detail of it. So I put it aside and work on other projects instead. Finally, I picked it up again to complete it. I also expanded my virtual Lego city. You can see what I added in the video :D
  4. After my 2 pick-up alternates, I returned to set 10265 twice more but this time to create 2 vehicles heavily inspired by iconic and classic sportscars from the 1960's in which Ford also played a key role, the GT40 and the Shelby Cobra which both fit perfectly with the 1967 Mustang. First the GT40 famous for winning Lemans. The GT40 was first built in England, but the later version in the US. GT04 main by Nathanael Kuipers, on Flickr The model features working steering wheel, opening doors, and engine cover with an engine that can be removed and displayed separately. GT04 open by Nathanael Kuipers, on Flickr Next is the Cobra Roadster, also a car that originated in the UK, but which Shelby with the help of Ford imported to the US. There it was equipped with a much larger engine that also required other changes to the chassis and suspension. I built this specific model for the TLCB Lock-down competition Cobra Roadster by Nathanael Kuipers, on Flickr This was a tricky model to render in bricks due to all its curves. Cobra Roadster rear by Nathanael Kuipers, on Flickr As with the GT40, this model features a working steering wheel and opening doors. Both front and rear open too. Cobra Roadster open by Nathanael Kuipers, on Flickr If you're interested to read more about the development or would like to see more pictures of either vehicle, please consider to have a look at my website NKubate.com. Thanks for looking!
  5. MOC #27 Classic Cadillac Convertible Stop Motion Speed Build Plus a Love Story My other MOC models: [MOC] Lada VAZ-2105 [MOC] Subaru WRX [MOC] Classic Cadillac Convertible [MOC] Toyota 6th Gen. HiAce Van [MOC] James Bond Aston Martin DB5 [MOC] Toytoa HiAce van [MOC] Toyota GT86 [MOC] Office Desk [MOC] Ferrari F355 [MOC] Toyota AE86 Coupe (2018 version) in Initial D Animation [MOC] Police Motorcycle #2 [MOC] Sport Bike Stop Motion Speed Build [MOC] New York City Police (NYPD) Car [MOC] Lego Mini Cooper [MOC] Japan Tokyo Taxi vol.1 東京無線タクシー [MOC] Ice Cream Truck [MOC] LEGO California Highway Patrol [MOC] LEGO Police Car [MOC] Police Motorcycle [MOC] New York City Taxi / Cab [MOC] LEGO NYC News Stand [MOC] New York City Transit Bus [MOC] Newspaper Rack [MOC] Coke/Beverage Cooler Initial D AE86 Racer AC Transit Bus AC Transit Bus Short Version Ice Cream Van
  6. I built 2 pickup alternates from Creator Expert sets. The first one is from the 10265 Mustang set, and to keep within the theme and time period I decided to go for a Ford F100 from 1970. The model includes steering by HoG, opening bonnet, doors and tailgate, a detailed interior and engine. Once done I thought why not try to build a pickup model from the 10252 Volkswagen Beetle too? So that's just what I did with this vintage American pickup truck somewhere from the 1930's. It has similar features as the 10265 alternate except for the steering function, which was not possible. Some pictures: Pickup trucks from 10252 and 10265 by Nathanael Kuipers, on Flickr 10265 Pickup Truck by Nathanael Kuipers, on Flickr Pickup Truck guts by Nathanael Kuipers, on Flickr 10252 Vintage pickup truck by Nathanael Kuipers, on Flickr 10252 Pickup truck rear by Nathanael Kuipers, on Flickr More information and pictures for model 10252 and 10265 at NKubate.com. In case you want to build your own copy building instructions are available at Rebrickable.com
