Showing results for tags '2030'.
Under the radar, but LEGO revealed an update about replacing the ABS brick both in their 2016 Responsibility Report and a LEGO Batman Movie article here: The prototypes as featured in the Responsibility Report: So, what do you think of the progress? Mods: If this should be merged with a previous thread, please do so. I didn't want to bump a three-year-old topic.
- 38 replies
- 2030
- sustainable
- (and 4 more)
So this was posted on my local LUG's Facebook page today. It'll be quite the shift for such a large consumer of plastic! http://www.plasticsnews.com/article/20140218/NEWS/140219915/lego-looking-for-a-sustainable-replacement-for-abs 'Lego A/S is setting a target to use a sustainable resin in its signature bricks by 2030, replacing ABS. The search for that new resin will not be easy, though, said Allan Rasmussen, senior project manager for Lego. Not only must the selected material be able to meet the same characteristics as the locking building blocks, they must also blend seamlessly with bricks already in children’s hands. “I need to find a material that is just as good as this one,” Rasmussen said. “I need to find a material that will be just as good in 50 years, because these are passed down from generation to generation.” Speaking at Innovation Takes Root 2014 in Orlando on Feb. 18, Rasmussen said the sustainability quest is in its early stages, but the Danish company already has tested some bricks using an impact modified polylactic acid are “very, very close.” A problem with a post-molding “creep,” however, means that a few weeks after they are molded the bricks do not click and stick together as well as they should.' Any thoughts, comments, or reactions?
