Showing results for tags '42029'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 8 results
  1. I got this set a few months ago and was immediately dissatisfied with it. So I decided to modify it, but just got around to posting it now. Special thanks to sm1995 for his tips and advice. The first thing to go was that atrocious front end. I gave it Madoca style headlights, LEDS, widened fenders, a more uniform color scheme, and filled in gaps. The winch is also manual now and uses Sariel's solution of manual control. I also missed an important part on the truck see if you can spot it. Now on to the rest of the truck. Cosmetically I did a lot. I raised the roof by one stud, and moved the front axle back one stud, and dropped the rear axle by one stud. I think all of these things really help the looks. On the inside, I tore out the gearbox and added IR control to it. Its powered by one XL and steering it controlled by an M motor which sits where the gearbox was. There is also an M motor in the original place for the set, but it only powers dumping through a red switch hidden behind a panel. The LEDs are also controlled by the switch which caused a lot of messy wiring underneath the bed. Overall I'm happy with how it turned out, but there are a lot of things I'd like to change: The dump bed is too long and the wheels stick out way too much. There are also a number of small rough spots which I would have like to have done better. As always feedback is very appreciated And finally a (blurry) bonus for all you Star Wars fans
  2. 42029 Lego Technic Customized Pickup Truck in highly modified form. Features include ultra-firm dual independent suspension. Motorized with Power Functions.
  3. hello, since a bit of time i decided to rebuilt some lego's, but i do not wanted to scrap my other rides;-) so i bought a 42029, because i think it is a fantastic truck to begin with:-) started from a stock 42029, i changed the length of the bed, put in a proper v8, rebuild front and rear fenders, put big 8110 wheels on it, make it rc. other things like a exhaust in the rear, the top ones still standing, it is powered by 2 l motors and the servo motor. next is the lenghtening of the cabin;-) here are some pics enjoy and comment;-)
  4. Hello, everyone! I built 4WD off road pickup truck being inspired by the set 42029. It is not a copy of actual truck, but some details look similar to Ford Raptor and Toyota Tundra which I referred to. Weight: 1570g Features, 4 wheel drive with 3 differentials 2 XL motors for driving Servo motor for steering Working V8 engine Working front and rear LED lights via power function switch Suspensions Front: independent Rear: live axle Openable hood, doors and glove box:) Lockable tailgate Detachable bull bar and roll bar Double wishbone front suspension is the same as 42029. Which means that front axle has a differential and CV joints without portal hub reduction. They cannot handle much torque for offroad driving. So I put portal hub on rear axle. Gear ratio is 3 : 1. That can handle enough torque. This setting enables central differential to act as torque vectoring diff. Front wheels recieve 25% of torque and rear wheels recieve 75%. Thus this Truck has good offroad capability. Three differentials and pairs of CV joints works smoothly, and they did not break or snap. You can change body color, and choose the type of battery box: 8878 or 8881. Video: Building instructions and more pictures: https://plus.google....64977943/albums I hope you will like it! Edit: I forgot exhaust tailpipe in all pictures. This is the final version!
  5. I use only parts from lego 42029, since I only have this set at the time.It might not be perfect, but with limited parts this is the best I can made out of it. Check out the video here: If you interested to build one I got a simple photo instruction at link below: http://www.yoshinydesign.blogspot.com/2015/01/lego-technic-42029-c-model-jeep-i-use.html It is an easy modification, it has the same chassis as A-model but shortened. same gearing mechanism as well, but back tipping mechanism was not use.
  6. Well I'm finally back! The footage in this video is at least 1-2 years old, and I've been working on this project for even longer. I'm slowly working on completing this build, but I need your input and suggestions! My work-in-progress Lego Technic Customized Pickup Truck 42029 is being motorized with Mindstorms Ev3. So far, I have much of the chassis built. Two Ev3 Large Motors are used for the drivetrain and one Ev3 Medium Motor for the steering. I also have it set up so that a Lego piston engine can run while the vehicle is driven.
  7. I made a C-Model out of the Customized Pickup Truck set. The details are posted here. I will add a video this weekend. Video now available.
  8. The Lego 42029 Customized Pickup truck is a Lego Technic set that was released in the second half of 2014. The set has 1063 pieces and retails for about 100 USD which seems a bit high. When the first images were leaked, the reactions were very mixed. Some people liked it others didn’t and the main complaint was that the set’s front end looks quite ugly. Honestly I wasn’t a fan of the whole second half of 2014 line up, but I decided to buy this set for the parts and do a review of it as I quite enjoy making reviews. Anyway lets get on to the actual review. The Box I apologize for the glare on the box, I'm not sure how to avoid that. The box is weirdly shaped as it is long and short in height. It feels full and has a pleasant weight to it which makes you think that the price was worth it. Here's what I mean about the shape. Compared to a model with similar parts, the box is not really square. Here's the back of the box. It displays the model's various functions, the possibility to motorize it, and the B model. The B model honestly looks terrible to me as it looks like a mess. Here's the contents of the box. There are 11 bags and once opened, the parts barely fit on my temporary, tiny table that I was using to build. The box also contains two instruction manuals( and no instructions for the B model as always) and an unsecured sticker sheet. Since the sheet wasn't secured, mine arrived with a large bend in it. This picture is after 5-10 minutes of trying to flatten it. The Build The build starts with the rear axle and the mini linear acuator for dumping. Not much is really going on right now. Some beams are placed diagonally to make a sort of truss which is kinda interesting. The other interesting thing is how the dump function works. Normally in Lego vehicles the linear acuator pushes the dump bed up as shown in this photo by Blakbird. Instead of using this basic pushing mechanism, the acuator in 42029 is mounted facing downward and fully opened in closed form. When you want it to dump, the acuator pulls the bed up instead of pushing. I'm not sure what benefit this gives, but it is an interesting way to make a mechanism. Anyway back to the build. The build then goes to the front of the chassis. At this stage, you get a feel for the size of the model, and to me it seemed a bit small at first. After that the build takes an odd step. In a model it makes more sense to build a complete chassis and then build the bodywork, but in this model the build ignores that the chassis is not finished, and moves on to the cab section. The cab looks alright, but the interior looks very half baked. The seats are too small for this model and they're blue... again . I'm really getting tired of seeing blue seats in models. It doesn't look realistic, and is it really that hard to make different colored seats? This trend has been used sparingly for many years, but then in 2009 it started to get used for most models. It's been 6 years of that now and I think its time for change. Anyway on to another overused Technic mechanic- the gearbox. The 42029 follows the time honored tradition of a function splitting gearbox. This iteration of it is quite simple with only two functions- a winch(again ), and a dump bed. The functions are controlled by the black bevel gear on the bottom, or from the 8 tooth gear on the right as that's where the M motor can be placed. The cab is attached and the model starts to resemble its final form. Next the engine is added. This was also a source of controversy as it was a V6. Most pickup trucks use a V8 so this was a bit odd. It's also not that hard to squeeze in 2 extra cylinders as evidenced by Sariel's motorization of it, so this seems to be laziness on TLG's part Another interesting thing I found was that the instructions displayed the old mold for engine blocks while my set included the new blocks. The odd thing is that my 42009 also has the newer style blocks and its from 2013, so I would think the 42029 instructions would include these new blocks as the set came out a full year after 42009. Next you have to build the front axle. I'm not a huge fan of these new hubs as there has to be so much space between the suspension arms. Also an interesting technique is used to limit the suspension. The white pieces, which are normally used in studded sets, block the arms from sagging under weight. Front axle mounted. At this point the steering also works and you could have a rolling chassis if you wanted to. And now the cliche winch piece is built. On a side note, I have 2 shelves of Legos. One shelf contains supercars and the rest is ordinary sets. Every single set I have built on that shelf has a winch or thread of some kind. They're all done differently, of course, but i just find winches boring. As a function they're quite boring unless its absolutely necessary such as the 42009 or 8258. Now here's another source of disappointment- the ugly front end. When you look at modern pickup trucks( especially American ones), they all have a feeling of power. The grilles are massive and are covered in chrome and the lights are large and boxy. Just look at the new Ford F-150. The 42029 looks so weak compared to these trucks. Instead of large boxy headlights it has bug eyed lights which are made from gearbox extenders. The grille also looks terrible. Its a mashup of red and grey parts which does anything but evoke a sense of power. I think they could have made it look a little better if they had replaced the red bushes in the grille with grey. Also look at those #3 connectors in grey. There was also some controversy about this as they look very out of place, and this was the perfect opportunity to bring back the rare #3 connectors in red. They brought back the red 5x11 panels in this set, so why couldn't they do they same for these connectors? I replaced mine just to see how it would look and it looks a lot cleaner. Overall the whole front area looks quite disappointing and feels sloppy. Anyway on to the rest of the build and there's not much left of it. The dumping bed is attached and a few other details are added and bam you're done. The dumping bed is an uncommon feature for a pickup truck, but it works well, and gives it a second function thus giving TLG an excuse to use another function splitting gearbox Here are the spare parts Completed model Here's a few pics of the finished model. I think the rear is simple and pretty well done Here's a side shot. With the high suspension, it feels more like a crawler to me than a pickup truck. The suspension is one of the best things about this model. It feels neither too soft or hard and is nice and bouncy. It also has amazing travel. The model's winch also works smoothly as with every other model with a winch. The set can also be motorized with the 8293 power functions set. All you need is an M motor, LEDs, a battery box, and a clutch gear. Motorizing it is quite easy and only takes a few minutes, but one should manage their cables properly, as I didn't pay much attention to the placement and it they stopped the bed from fully closing. I didn't care much for the motorization as it just put lights on the roof and motorized 2 functions. Unlike the 42024, this set doesn't really need the motorizing as the functions work at a reasonable speed, so I decided to not keep the motorization and advise you not to waste your money on the extra parts required to do the motorizing. I decided to take the set outside in order to match its rugged looks. Nice view of the V6 and its turbochargers? Not sure what the things are on top of the engine. Everything opened I also decided to give the dumping bed a practical test with birdseed and it worked well although the bed and parts of the chassis got quite dusty One flaw with the dumping is that the tailgate has to be opened manually. It doesn't make much sense to put a dumping function yet not have an easily opening tailgate. Personally I would have liked to see the tailgate use frictionless pins and some sort of manual locking mechanism. It would feel a bit more realistic at least to me. Final Thoughts The model doesn't have the greatest looks or the most realistic functions, but it has a great assortment of parts. Personally even though this set claims to be for older ages, I feel that it would appeal to younger children more due to its high ride height and quirky looks. It is also one of the most durable models that I have built. The suspension absorbs drops and it can be rolled over multiple times with no or minimal damage. At one point it accidentally fell off a sofa and it survived with only the roof lights and one steering link breaking. With all this sturdiness, its an interesting build as there is so much reinforcement and it is fun to see how they achieve this. The model is easy to break into chunks and has a lot of possibility for modification, so that's always good. Overall Build- 8/10 It's a fairly standard build, nothing too surprising, but it is fun to see how sturdiness can be achieved. Also there are a few interesting parts Looks- 4/10 Really TLG? This looks nothing like a modern pickup truck. I get that its "customized" but that gives no excuse to how half baked the looks are. The front end looks sloppy and the rear is just simple Parts 10/10 Steering arms, suspension, CV joints, ton of red parts, beams in black, dark bluish grey, etc. Its a great parts selection to build your own model. Functions 7/10 Lets see, it has great suspension, steering, a V6 , yet another winch , and a function splitter which really wasn't necessary. Price 7/10 At first glance the price looks alright, and you get the .10 cents per part ratio, however, it feels like it should have been priced a bit cheaper. Just look at the 42024- over 900 parts for 70.99. Now I understand that this model uses some more expensive parts and such, but i think it should really be priced at $85. That sounds like a more fair price since you have to pay an extra 30 to buy the kit that motorizes it. Final score 36/50 The set is a big pile of 'meh'. It could have been better, but its just average, and doesn't have much realism. It provides a ton of modification possibilities(Perhaps this was TLG's intent with this set hence the "Customized" name) and I would love to sit for hours and modify it into something better, but it also fills the function of expensive parts pack, and that's what I will probably be using mine for. In a perfect world where I had more money, I'd love to buy 2 of these and use one as a parts pack and modify the other one, but I guess I'll just have to modify this one and then break it for its parts. For now though its staying on my shelf just beckoning me to go and try to make it even more of a customized pickup truck. Thanks for reading my review. As always constructive feedback is appreciated and please voice how you feel about this set too.
