Showing results for tags '42068'.
Third B-model of the 2H2017 is yet another "vehicle" (so helpful of LEGO to tell us that, now nobody will mistake it for a building ;) ). While it's the smallest of the three, I think it's quite interesting and good-looking, even if many of A-model's pieces are left unused and the functions are largely similar to those of the A-model.
The smallest of the 2H2017 Technic set is, in most aspects, a pleasant surprise. I was expecting something dead simple, but got something ambitious and complex instead, with a brilliant steering system and 2 boom functions that can be easily motorized. Additionally, I like how normal and realistic it looks compared to 42070 and 42069. It's a pretty, functional, well-designed set and it's delightful to steer. On the underside, 42068 contains literally zero new pieces or pieces in new colors, leaving you little reason to buy it - chances are, you can build it with the pieces you already own. And some parts feel like a few corners have been cut.
Hello everyone, I have started this form today because i could not find one anywhere else on Eurobricks. So, this is the place for anyone to discuss the mysterious Lego technic set 42067... To start this off i would like to re-point out something Jim pointed out about the 42070 in his review. he mentioned that the lower corners of the front that say TOW 067. Hmm very suspicious... Chase
This form has been moved.
I'd like to share with a quartet of c-models which are based on A-models from 2018-19. There has been no model since the Racing Yacht and Heavy Duty Forklift that had that special something to make me want to buy it (the Car Transporter came very close). I typically stick to buying the low/mid range sets and now have around 20. I enjoy the challenge of C-model creation as you can see on bricksafe, and using Rebrickable.com I looked at which of the 2018-19 line-up I could enjoy the building experience for using bricks from my existing sets. I initially was going to make the First Responder from the Airport Rescue Vehicle but the similarities with the B-model for this set ruled it out. Turning the Racing Yacht into the Powerboat was a logical next step. I tried to follow the instructions for 42089 making substitutions and skipping sections as required. Once that was done, I went back over the model with the remaining pieces to try and find a way to complete it whilst keeping the vibe of the parent model. This process made me very familiar with the instructions for 42089 such that I tried again with the Heavy Lift Helicopter and Airport Rescue Vehicle. Having woken up my brain to the possibilities, I went back to Rebrickable.com to look for a bigger challenge. Comments in reviews about the chassis for the Rally Racer put me onto the 24 Hours Race Car being a good candidate. This followed the same basic process as before but this time need much bigger reworks. I often realised the piece I really need to complete the bodywork of the model had been used elsewhere in the chassis, and a swap would be needed. I'm pretty pleased with the outcome. This idea of recreating an A-model as a C-model is not new (https://rebrickable.com/users/klimax/mocs/ has a number of examples). More pictures of each model can be found on Bricksafe (https://bricksafe.com/pages/TheKitchenScientist). This version of the Rally Car has kept the suspension and HOG steering but lost the opening front/rear. I managed to add steering via the steering wheel. The brick built 3-cylinder engine is not linked to the wheels but turns with the propeller. Using a worm gear I was able to link the propeller to the wheels but there was no engine this time. This model had all the parts to recreate the engine/wheels/propeller functionality but lacked some of the panels needed to keep it power-boaty. As a compromise I took the arm mechanism from the Airport Rescue Vehicle and mounted in the extended boat.
