Showing results for tags '42108'.
Yes, I'm little late to the party. But let me show what I wanted to make for the contest; The initial idea for this model arosed back in 2021. There was a contest here at Eurobricks, about making stlldess version of classic sets: I always liked the 8855 set, with its movable modules. Read more about 8855 at Blakbird's Technicopedia @Blakbird And then I realized that 42108 has trans Red and Green tiles. Perfect colours for navigation lights on an yellow aircraft, don't you think? With Yellow being the main colour, and black being second one used in 42108, I decided that I'll raise the bar and I'll make that studles version as an alternate model. Here's the initial sketch; As usual, many other things interrupted that, and I have finished the model year after contest ended, in June 2022. And now I have finally found time to make instructions and proper presentation. Here's the final model along its predecessor: Direct size comparison: So, let's start with the fake engine. A flat-twin one, connected directly to a 3 blade rotor. Can be put in motion either by pushing the blades or by turning the knob under tha cab. And speaking about the underneath, this aircraft has both floats and landing gear so it can be operated from either land or water: All doors, including service hatches, can be opened. Model features movable ailerons and elevators controlled via a flightstick at the top of the plane. There's also a t12 gear that controls the rudder. Video: With a wingspan of 80 studs, I had problems with taking comparison pictures of this model :D There are also two buoys; Leftover parts: This model has been designed to be hang under the ceiling. The rope provided with the set can be used for doing that. Instructions: https://rebrickable.com/mocs/MOC-130569/M_longer/42108-seaplane/#details Image gallery: https://bricksafe.com/pages/M_longer/42108-alt/seaplane
Hello! Recently I built an alternative model using only parts from set 42108. It is a roto-telehandler, mainly based on JCB Hydraload. All functions are manual: - boom raise/lower - fork tilt - turret rotation - 4 wheels steering - stabilizers There are 2 attachments: fork and hook. It is in the same scale as my other models (1.21) and instructions can be found here: https://rebrickable.com/mocs/MOC-43871/technicprojects/jcb-roto-telehandler/?inventory=1#comments Functions summary: I hope you like it!
Hello folks, I wondered why there is no official alternate build for the 42108 Mobile Crane (sometimes lovely called Yellow Parts Pack), so I decided to create this cool American Tow Truck as an alternate model. This alternate uses 1172 parts from the main model. Spare parts are not needed. The dimensions of the truck are as follow: 52 cm (L) x 15 cm (W) x 18 cm (H) with extended wheel lift (20.5 in x 5,9 in x 7 in) The model reaches a total height of 40 cm (15,7 in) with fully extended arm. In scale, it fits the 42078 Mack Anthem or 42098 Car Transporter very well with those tires. The functions are as follow: HOG-Steering workable 6-cylinder inline engine with nice clicking-sound under the hood openable hood with locking function both doors can be opened raising/lowering the boom - operable on both sides of the model extendable arm working winch with locking function extendible wheel lift Because the lag of differential in the main model, the inline engine is just driven by one wheel and not by the entire axle. The playability of the American Tow Truck is just great. You can use either the wheel lift to hook and tow cars or other trucks, or you can use the giant boom to rescue some crashed vehicles with the strong winch. The model is based on a real American Tow Truck. Here are some pictures of the model you easily can build on rebrickable: With realease of 42107 and some rare panels in red, this model can be build to 100% in red instead of yellow. Blue, black and white are also possible with a few changes. Since 42115 and the release of lime panels and connectors, this truck can be fully build in lime instead yellow with some minor changes. instruction The instruction comes in high quality and clear images for builders with an age of atleast 10 years. With 5 parts per step, the instruction is very easy to follow and has 234 total pages with a total of 347 steps. The model is divided into several submodels and steps with different camera views as common for modern Technic sets. Rendering the rope was a bit tricky because it counts not as a part, but the instruction steps are very clear and understandable to deal with it. And the best thing is: You do not need to make or release the nodes on the rope - you can use the rope with nodes on both ends from the main model as it is. Here are some random example pages of the instruction: You can find this MOC with building instruction on rebrickable: here Finally a cool 360 degress view and review
Hi guys, i'm a new to world of LEGO but i'm so addicted after my first year of recording reviews. I know that many people don't like my work because I've found a local seller who sold me these sets earlier. Hope videos bellow will help you. Do not hesitate to ask for some specific information, i'll try to answer to every request. LEGO 42109 Top Gear Rally Car Testing speed, slope, strenght and more. Speedbuild and new differential review: LEGO 42108 Mobile Crane LEGO 42106 Stunt Show Truck and Bike, LEGO 42104 Race Truck LEGO 42103 Dragster LEGO 42102 Mini CLAAS XERION LEGO 42101 Buggy LEGO 42107 Absolutely no information about these sets. maybe cancelled? Unboxing video and parts lists
- 26 replies
- mobile crane
- lego 2020
- (and 9 more)
