Showing results for tags '42154'.
Hey all, we'd like to present another alternate build from the Lego 42154-1 Ford GT set. This was the best I could do out of the Ford GT! Honestly, I'd just like to hear if you guys liked it :) A 1/12 Scale Technic Ferrari F40. When designing this model, we wanted to preserve the Ferrari's iconic features and looks to make it a worthy replica of the famous sports car. The limited parts available in the Ford GT set proved challenging, making a functional car that looks accurate and performs as a good display piece. I want to say that when designing the model we built it to act as a shelf princess with some extra features.Our Instagram for more photos: InstagramNow let's dive into the features Features: Accurate and detailed F40 V8 Engine (working) RWD Suspension on both front and rear axles (limited in the front) HOG steering Interior with steering wheel and seats Opening doors Accurate F40 exhaust design 1/12 Scale (same scale as Ford GT) Tilting Hood Pop up Headlights A tilting Rear section that exposes the engine, rear suspension and exhaust Full independent suspension
Hey everyone!The time has come for us to reveal a special alternate build for the 42156 Ford GT! We have rebuilt it to be a VOLVO iron knight.VOLVO IRON KNIGHT BACKGROUNDWithout further ado let's go into what the Iron Knight is. The Volvo Iron Knight is a race truck specially designed by the Volvo racing team that was specifically designed to be an absolute beast. The truck featured 4 turbochargers released 2,400 Horsepower and 4,425 pound-feet of torque. It used a dual-clutch system that is also included in most of Volvo's trucks but the whole body was redesigned to be a light, lean record-breaking machine! Features of our VOLVO IRON KNIGHT A realistic working V6 engine Iron Knight's unique exhaust and detailing RWD Rear solid axle suspension Front independent suspension HOG (Hand of God) Steering for front wheels Smooth drivetrain Racing Minimalist Interior Iron Knight lights Opening the front Grille to reveal the steering And it of course is only built from parts included in the LEGO 42154 FORD GT Suspension and SteeringThe IRON KNIGHT uses a solid axle in the rear and independent front suspension which is steered. The rear axle drives the V6 engine in the back of the truck. For looks, we decided to keep the model levelled for those who want a more aesthetic display of the model, this means that the rear solid axle suspension has limited suspension capabilities in its current state. This can easily be changed by doing a quick modification we are going to release to those who want this option on our website. The suspension modification simply moves the connection point of the rear suspension pieces down 1 stud! It's very simple and effective.....
- 2 replies
- alternate build
- volvo
(and 2 more)
Tagged with:
Hi Folks! I'm back with another alternate build this time. I've had the Ford GT for a while, and had this idea quite soon, but could only get around to actually build it recently. As usual, I wanted to build something of an off-roader, as I'm more into them than sports cars. Also, I wanted to see if some alternative suspension is buildable from these parts. A buggy seemed a good material for that, as they usually have independent front and triangulated trailing arm rear suspension, something I rarely see in lego form. And the color scheme and fender parts made this set perfect for the Red Bull SMG buggy. Carlos Sainz used to race this buggy in the Dakar Rally. He just recently won the 2024 Dakar Rally at the age of 61 (with and Audi E-tron :D). So this can also be considered kind of a tribute to his older car :) Features: Bouncy, high travel suspension, double wishbone independent front, independent triangulated trailing arm rear Mid-rear mounted V6 fake engine driven from rear wheels HoG steering on the roof, easily detachable for display Doors openable upwards Here is a video to showcase it all: Some more details on the design. Chassis and suspension The design started with the rear suspension. I have only recently seen such a trailing arm suspension in real life, and made me interested how to make it in lego form. Mounting the wheel hub on a triangular arm in a stable way was actually easier than I thought. The tricky part is the drivetrain, as it is perpendicular to the swinging direction of the trailing arm, and hence the length of the driveshaft needs to change a bit during travel to follow the movement of the trailing arm. That all could have been replicated nicely if TLG didn't make the driveshaft a single piece in the Ford GT, but instead two parts that could slide in and out, but well, they don't seem to think about reusability in different contexts (it is still a mystery to me why they made it a single piece). But anyway, the change in angle is small enough here to allow it to work for a manual model even with the single part in the set. Anyways, after the rear suspension seemed doable, I tried to build a chassis to connect it to the front axle, and this is where I got slowed down. The main structural part in this set is the 3x19 frame, but that was impossible to use here on the sides as in the A model, because it was too long to fit in, as the rear suspension protrudes to the front quite a bit. At the same time, I needed it to connect the front suspension in a stable way. Also, this model being an off-roader should sit quite a bit higher than a sports car to have ground clearance, but should not be too high either. So I had little space left for framing. Furthermore, the engine placement is also difficult, because the set does not contain enough gears to route it elsewhere (higher) but to a low mid-rear position as in the A model. After a lot of juggling, I managed to use two large frames in a flat position that results in a stable connection to the front and sides of the car. It helped a lot when I realized that the H frame around the differential does not need a super solid connection to the middle chassis, because the rear suspension is not connected to the center, so it does not bear any load :) Also, I had to leave a big hole on the floor to be able to place the seats low enough, and in the end the 15x11 frame turned out to be quite useful, going around the seats. The next difficult area was the front suspension, because due to the larger ground clearance required, I had very limited space to work with, into which I also had to fit some down-gearing to make the HoG easier to use (same way as on A model). But luckily, the range of travel turned out to be good, though it was hard to place it all under the hood. Here is the complete chassis: Bodywork and interior The interior contains sporty seats placed as low as possible, along with a simple dashboard. Fun fact: TLG made the steering wheel in this model just a tiny bit wider than 4 units (whose idea was that?), so it does not fit exactly in front of the 4 wide seats (I had to offset it half a stud in order not to collide with the door panel, which is right next to the seat). On the exterior, the most challenging part was the hood and the front fenders, both because of the shaping of all the curved surfaces, and because the very front is just hanging in the air, so I had to make the connection from the center firm enough to hold it, while avoiding it to collide with the front suspension. It went through about five iterations until I arrived to this one. The hood is unfortunately sitting a bit too high, I could not lower it any more, but it's not too bad. One thing I wanted to emphasize is the air vents? on the sides. Also, I managed to make something of an openable door (rather window), not sure how the original opens, but I have seen something similar on buggies like this, and this was doable from the available parts. The stickers were made by Forwart Sticker. The model originally got finished for a car exhibition in Hungary, so I decided to have them made because it does elevate the looks quite a bit I think. Here are some photos of the finished model. More images are available on my Bricksafe. Building instructions are available on Rebrickable. Let me know how you like it! Cheers, Viktor
Hello Eurobrickers, let me allow to share a new creation with some insights made from LEGO Technic set 42154 Ford GT as an alternate build. The idea behind When the 42154 Ford GT came out with its inventory in March 2023, I was impressed by the earth blue colour and had immediately a Lamborghini Lanzador in mind to build with this pieces. I was sure that this model is doable with the given parts, but unfortunately this vehicle is an upcoming electronic car with no engine. Skip the engine and functionality only for design? Nope, not this time so I decided not to make this model and was working on some sketches for a Koenigsegg Gemera instead but that car did not convinced me at all so I decided to finally skip (pause) 42154. To be honest, I found the inventory of the set very special with many odd part numbers, but was impressed by the large amount of connectors used and blue axle pins and also red 2L axles. In February 2024, I stumbled over pictures of the Dodge Viper GTS in second generation, manufactured since 1996 and directly felt in love with this car. To reuse the headlight parts and white parts for stripes seems to be a good option and I finally got keen with the inventory of the 42154 set to make first sketches. In the beginning of March 2024, the project for the Dodge Viper was official born and the finished model ends up with impressive 1430 parts used only from the set 42154 Ford GT. Model features 1:11 scale HoG linkage-steering suspension in front and back engine with moving pistons openable doors on both sides realistic openable hood with lock detailed interior measures 41cm x 18cm x 11.5cm Model impressions Model details Both doors of the model can be opened to see the interior. Pedals are made for the driver with existing parts. The car is controlled from the back with a knob that is responsible for steering the front wheels with a linkage system. The hood opens up to 60 degrees and can be locked to safely stay in position while playing and displaying the model... ...and easily unlocked to close. Opening the hood reveals the engine that is driven directly by the rear wheels through differential. As common for B-model compromises and limited parts, this Dodge Viper uses (only) a V6-engine under the hood instead a V10 - sorry folks. It was very hard to fit all the functionality (engine + steering + suspension) under the hood in tiny space, but everything works well as suspected. Made with DieCast For the first time I used a Diecast-model and also many pictures from it. Here are some pictures for comparison: If you like what you see, feel free to support my work and to build your own Dodge Viper from your 42154 donor set. Instructions and more info can be found here Happy building!
Hey everyone, here is my newest creation... An 850hp supercharged BOAT!!!! AKA the Dodge Challenger SRT Demon!!!!! It is made using the parts from both 42154 and 42126. I liked this car and wanted to design a model that would highlight a similar and recognisable look! Please let me know what you think about it! Some photos and features: Front and rear View \ Wheelie function which is accessed using the orange key Doors, boot and hood can all be opened Please enjoy a video I made: https://youtu.be/TNrUjsT_23U?feature=shared Now on rebrickable: https://rebrickable.com/mocs/MOC-171570/CrazyKreations/dodge-challenger-srt-demon/#details
