Showing results for tags '4999'.
A LEGO Wind Turbine MOC and MOD of the LEGO Vestas Wind Turbine 4999. The original 4999 sets are not only hard to find today but expensive so we worked with what we had in our inventory and bricklinked most of the key structural parts which were the 9 x White Slope, Curved 8 x 6 x 2 Double part #45411 and Curved 8 x 6 x 2 Inverted Double part #45410. Since we were starting from scratch we changed the original scene of the restaurant into a modern seaside house. The modern and modest seaside house features minimal interiors with PF lights for both interior and exterior Here's a full overview video of our LEGO Wind Turbine MOC in detail with all it's Power Functions in action. Enjoy!
As any competent player of city building games would tell you, it's important to get the utilities in place before you start inviting people to come live in your city. I've gone ahead and started the process by building my own modified (improved) version of the promotional Vestas wind turbine model, set #4999: The biggest change is that I've nearly doubled the height of the tower in order to bring the blades into scale with the tower; the Vestas turbine is quite short, at least compared to the wind farms I see here in Wyoming. From the look of it, the towers are a bit more than twice as tall as the blade radius; currently in these images I'm waiting on one more segment in order to bring the turbine up to full height. I also did some work in and around the nacelle, hub, and blades in order to remove gaps and increase the color uniformity in exposed areas, as well as make some small shape changes. The very last addition I made was that of a service door at the base of the tower to allow for workers to enter the turbine for maintenance and such. In the context of my layout, the turbine was built and installed by the 'Mikroelectric' utility company, which services the town and the surrounding areas. I'm hoping to make some custom window cling-style signage to complete the green stripe down the side of the turbine nacelle with the Mikroelectric logo. Most of the gap-filling happened at the little back door that allows access to the motor. Currently in order to power it, I have to hang a battery box out the back. I made the tip of the hub a bit pointier, and smoothed out some of the gaps at the root of the blades. There's even steps leading up to the access door. They're a little off-kilter from how it fits onto the baseplate, but once the tower is mounted onto a MILS-style module it won't matter - and the tower will be a lot less wobbly.
