Showing results for tags '5 Speed'.
2015 Predator Supercar Full Article HERE Specs & Features - L x W x H (studs): 59 x 31 x 13 - # of parts: undisclosed at the moment (Anyone wants to take a guess?) - The heart of the car consists of a V8 engine; - A vertical positioned gearbox is located right behind the engine and transfers its power directly to the rear wheels; - the 6 different speeds (5+R) can be manually selected with the gearstick between the seats and has a one to one mechanical connection to the gearbox with some linkages; - All wheels are suspended independently with double wishbones; - The front wheels are steered through either steering wheel or HOG and include ackermann geometry; - Front axle also has positive caster angle and kingpin inclination. Bump steer is minimized due to the low location of the steering rod; - Gullwing doors which can be controlled from directly above the airintakes on the side and include a wormwheel configuration; - Bonnet and engine cover can be opened as well, but this is done manually and they have a built-in limitation of their respective opening angle. They stay open due to friction. Looks like Nate has some new teasers up for his new supercar design... No doubt this will be awesome..! "A New Revalation" "After many months of development a new beast is soon to be unleashed! Remember the chassis for a new supercar that was presented here a few months ago? Well, the long wait is almost over and a new Predator is on its way. Many iterarations later and updated with the latest arrival of new parts it's bigger, meaner and more accurate than ever before! A few titbits to wet your appetite: the model is roughly the same size as the recently launched 42039 24-hour racer. But the similarities do not end there. Both use for example the exact same amount of panels, both are powered by a mid engine V8, and then there are a few other features that share some similarity. But that's where the comparison ends, and although on paper they seem similar, in reality they are completely different! All will be revealed soon..."
