Showing results for tags '5004419'.
A Faithful Tribute This is a follow up to the very successful 5002812 – Classic Spaceman Minifigure from 2014 and 5003082 – Classic Pirate Minifigure from 2015. It was no surprised that LEGO was going to continue this rather special trend of celebrating classic themes through these exclusive promos. This set is a direct homage and tribute to 6012 - Siege Cart; a small impulse LEGO Castle set released exactly 30 years ago. Unintentionally this promo becomes even more special as it’s released a few weeks after the passing of Daniel August Krentz, a retired LEGO designer who worked at LEGO between mid-1970s until 2000. Daniel is known to many us as the designer of 375 – Castle. Packaging The primary aspect of the box design is very reminiscent of most of the boxes between 1960 – 1965; the white studs covering the entire box and the LEGO logo in the top left. The box doesn’t scream attention to the contents much like the current products do, instead they show a small and simple vignette of the set with an extract of the booklet included and the 2016 stamp. Other nice details of the packaging include the LEGO System logo from 1950s on three sides. To open the box, you have to slide open the drawer on the right hand side which contains the pieces and booklet. Not only does the contents of the product reflect the classic sets, it’s also presented through the packaging and experience as you open the box which is one of the many reasons why this series is clearly a success. These easily have the best packaging of any LEGO product alongside Architecture, LEGO Ideas and the two exclusive Technic sets (41999 & 42056.) Booklet The booklet starts off with the simple instructions to build the Minifigure and model. It follows up by documenting the classic LEGO Castle sets through a timeline starting with the origins leading up to 2016’s Nexo Knights. Which follows a similar pattern with the previous two promos in this series. With the future instalments I can only guess it will be a similar scenario by promoting a new theme / sub-theme that links back to a classic LEGO theme. Surprisingly this also comes with a sticker sheet / postcard; the stickers are images of Minifigures represented throughout the Castle themes as well as the two LEGO logos. On the reverse side it’s a typical postcard design with a ‘castle / knights’ twist! I wish it was just a postcard with an awesome print showcasing this set instead of the stickers which slightly decreases the exclusivity of this promo. Minifigure The Minifigure is a near replica of the official castle sets, the difference being the weapon of choice; the long axe is a rather odd choice, perhaps an alternative weapon such as a bow and quiver could have been included instead. The printing is fantastic, both on the torso and the shield. I really appreciate that the torso or printing wasn’t over done or didn’t represent the ‘classic’ torso. That’s was one aspect that took away from previous promo (5003082 - Classic Pirate Minifigure.) Model The only noticeable difference between this model and the one included with 6012 - Siege Cart is the use of brown slopes over plates for the front bow shape, my guess is they weren’t available in the 80s. Besides that, pretty much every detail and feature from the original model has been replicated into this model, including the shield attachment at the front! Much like the printing they’ve stayed faithful and not over done the details to bring the design into modern day. Final Analysis / Conclusion Comparing this promo to the previous two; it’s easily the superior of the three! Not only does it reflect and celebrate the classic castle theme it also gives a faithful reproduction to a classic set: 6012 - Siege Cart; rather than including a random assembly of parts as did ‘5003082 - Classic Pirate Minifigure from 2015. It’s a perfect example of what a faithful homage and promotional product should be! 9.5 / 10 In the memory of Daniel August Krentz (1937 – 2016.)
- 21 replies
