Showing results for tags '6 x 4'.
Presenting my latest MOC US Truck T2 MkII with instructions some people came with a question I did not expect. Never the less is this question fare enough: what about the frame. Some people are interested in the frame or chassis only and why not, I can imagine... :-) So here they are, the instructions for only the frame of my latest MOC: US Truck T2 MkII Hopefully this helps for some people to buy the instructions, without a lot of unwanted information. It may be obvious, but to make sure, you could easily build this frame in for example black. Black parts are much more common and a lot of Technic builders who have earlier sets have plenty of black parts... Cheers and enjoy building..., Ingmar Spijkhoven This is only the frame of an earlier released model. A model of a US truck with LEGO® Power Functions®. This truck is revered to as US Truck T2 MkII which is a rebuild and revised version of US Truck T2 I finished back in 2009. Like with all my models this truck's frame is build in scale 1:17,5. This model features: solid axle suspension on all axles, PF powered driving with power transmitted independently to both rear axles, Ackermann geometry on steering axle, Servo powered steering, fully functional fifth wheel and 1 set of PF lights. To give you an idea how these instructions look like here is a preview. Creating these instructions both quick progress on your build as well as each step being easy to understand the same time were very important. Early in the building process you will see what is happening, what it is that you are building. You will be very excited from the moment you start till you finish the build of this chassis with a total number of parts of about 800 pieces. To achieve this a lot of floating items are used, with added arrows to show where these items are suppose to be. Together with a lot of so called call outs (the smaller windows within a step that shows the assembling of a smaller sub part of the build) together with multi part steps the build will be in a flow. Included you'll find a parts overview. You rather want to use the parts list shown at rebrickable.com! Both building instructions and a parts list are available!
