Showing results for tags '911'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 19 results
  1. It's been a while since I posted a personal MOC here, so it's about time to fix that! After the competition we had in Cluj in Romania last year, I decided to make an AWD version for my next competition car and to include the lessons I learned from the Sterrato, Mustang GTEX and others. For this version I used a single BuWizz motor to drive the model, which is realistically placed behind the rear axle. It drives a 28 tooth reinforced differential via a 12 tooth bevel gear from the fast, inner motor axle: Rear differential also drives and axle that in turn drives the normal differential in the front, providing front wheels with power. An L motor steers the front wheel to the maximum angle CV joints can provide, 25°. Exterior is loosely based on the 911 Dakar edition, though some details had to be omitted/recolored due to lack of small panels in white color: I also had to simplify the rear section a bit in order to fit the motor, but it still features details such as LED bar, lights, exhaust and a skid plate: Dimensions: 29 x 12,5 x 8,5 cm Part count: 595 pcs (actually very low for a motorized model at this scale) Weight: 650 grams Thanks to the redesigned front axle which uses the normal diff, I also managed to increase ground clearance to almost a stud, allowing the model to be driven over rough terrain as you can see here: As usual, the LDD file of the model can be downloaded here (remember to update LDD first): https://bricksafe.com/files/Zblj/116-porsche-911-dakar/1 to 16 Dakar 911.lxf While not the fastest or most powerful 1:16 model I've ever built, it sure is one of the, toughest, reliable, robust and simply fun ones to drive so far. To conclude, I'm also really happy with the looks, thankfully Porsches are quite easy to build with Technic and I think it's a good representation. Even kids recognized it as a Porsche while recording the video, which I think is a good sign.
  2. This is the second mod I have done to Lego's 42056 Porsche 911 GT3 RS set. I used the same height lift as I used on my previous Porsche mod and moved forward the bottom arms in the front and the rear of the chassis to add negative camber. The car was able to roll without the body on, but once I put it on, it couldn't roll. This means the car is now purely a display model. As much as a JDM fanboy I am, I'm kind of upset with the result of the car not moving, but at least I'm glad that I stanced this car anyways just for the fun of it. Although, quote automotive YouTuber GasKings, the camber angle does seem a bit too much on here like "a baby giraffe taking its first steps." So, what do you think of this mod I have done? Is it CamberGang worthy? I think it looks neat, but I would like to get rid of the camber (and the height lift) so I can roll this car around again. Here's some more pictures of the car I took. Thanks as always for checking this out, and I hope you'll stick around for my next builds.
  3. This is Lego's 42056 Porsche 911 GT3 RS set with some unique rallycross-inspired features I added making it the perfect sports car to drive in the snow. Features Suspension system raised to make the car about two studs higher Wheels and tires from the 42037 Formula Off-Roader Mudflaps LED light bar Front off-road lights Rear bash bars Optional snowplow that attaches to the front The lights are fake and don't turn on, and all of the other lime-colored pieces are from the 42037 set as well. I had a lot of fun making this. I just had to switch of the area of the springs to change the height for the rear without any pieces needed, but for the front, I had to remove the entire Porsche's body to make the lift there using a variety of pieces. Overall, I'm proud that a got the result I wanted, which was making the Porsche 911 GT3 RS higher (so it wouldn't bottom out) and equipping it with off-road features so I could have fun with this set in the winter. It does need to drive in snow only about an inch high so I could move it without getting stuck (and so the plow can move the snow too). I recommend to anyone who has the Porsche set to try these mods out for themselves this winter! Here's some more pictures of the car and a desktop wallpaper that I created wishing everyone at EuroBricks Happy Holidays!
  4. Ambulance building instructions Parts list
  5. As soon as the Porsche contest began, I knew Dug and I would be in this contest. It began with a trip to his work where he was fixing a 1973 Porsche. It was on a hoist and he was explaining how the rear suspension with the torsion bars work. I didn't think it was possible, but we found a way to create torsion bars for the front and rear suspension. 75 studs long x 31 wide x 21 high. This is the first car we have created to scale. This creation comes with Hidden battery, motors wiring tucked, 1:7 scale, trailing arm, torsion bar rear suspension, realistic interior, wide body, 1973 Porsche RS custom race inspired body, spare tire and vn in original location, working fan on motor, 2xl for drive, 1 servo for steering. Flicker: http://flic.kr/s/aHskAQ6Li7 Extended Version: Porsche Contest: IMG_8074 by lachlan cameron, on Flickr Classic rear flow IMG_8056 by lachlan cameron, on Flickr Agressive front lip IMG_8147 by lachlan cameron, on Flickr Whale tail IMG_20160729_140645 by lachlan cameron, on Flickr Side Profile IMG_8129 by lachlan cameron, on Flickr Realistic Suspension with torsion bars. Very effective, and only required the use of 1 shock per wheel IMG_7942 by lachlan cameron, on Flickr IMG_8216 by lachlan cameron, on Flickr IMG_20160729_140543 by lachlan cameron, on Flickr IMG_20160729_140701 by lachlan cameron, on Flickr Bucket Seats IMG_8183 by lachlan cameron, on Flickr
  6. Hi Here is my dream Porsche. It features and combines 3 of my favorite things of Porsche: The front V8 TT engine and front bumper of Panamera Turbo S The 911 shape The RSR look and feel The result is this. Hope you (and judges ) like it Features. 1:10 Scale RWD and Fake V8 engine 4 Speed Gearbox with remote stick Independent suspension in the 4 wheels Working Steering Wheel (No HOG) Openable hood and doors (With lock system) Adjustable seats with gears Big Spoiler (Like the RSR models) Miscellaneous things like hand bag, lights etc. *Surprise feature* Removable V8 engine and transmission like a car About the last feature, well, I'll show it later in another pics and video. (I haven't had time to take more pics) Here are the pics of the last feature Making this function was the most difficult of the model, because it must be work smooth in every gear and I must find the proper joint points in the gearbox to the chassis. Also it must be easy to remove without bending or forcing the rest of the car. After many tests, I achieved it. More pics of the car This photo scream for the bigger Steering wheel (Sadly I don't have it yet) More pics and video will come soon The full gallery https://www.flickr.com/photos/137229326@N08/albums/72157668154949314 Video. The car was completed some days ago, but I decided to post it as my 100 post here, in the greatest Lego community
  7. My porsche in less than 50 km steering mode so far... I won´t finish it but it will be funny try it... Great mode for easy parking. http://www.youtube.com/watch?v=e3BMUcXSgqU&feature=youtu.be '>http://www.youtube.com/watch?v=OfU6ndAW4uE&feature=youtu.be
  8. So, this is the set TBB already dubbed a "breathtaking perfection" (because it's pretty, you know) and a whole lot of people will buy it just for looks. Unfortunately, I see a Technic badge in there, and Technic line used to be about something more than just looks. That's why I'm going to review it considering its functions, and to put it shortly, when it comes to functions the 42056 feels like a slap to your face. Sorry TBB, someone has to do the ugly job of raining on your parade. This is literally the most expensive set in the entire Technic line, a set which is being promoted by Lego as if their lives depended on it. It's literally being announced as "ultimate supercar" and "art of engineering". Well, bad news. The art of engineering 2016 edition looks like that: - no PF in sight, literally no electronics, nor an easy way to make this set RC - dead simple suspension that has been done dozens of times. Were you wishing for something fancy, maybe McPherson struts, Ackermann steering, caster angle? Too bad, the suspension is the same as in $60 sets. - dead simple steering with new wheel hubs added only so Lego could pretend there are brakes. All these fancy new wheel hubs and fancy new wheels still don't turn in the center like 8448 set's wheels do. - Lego could give us working brakes. Lego could at least give us a realistically looking calipers and maybe some nice brake discs. Instead, Lego gave us a 1x4 tile with a sticker. - a transmission that takes half of a chassis, then works poorly and doesn't really do anything useful Seriously, for $300, which is the money that will buy you e.g. both new Claas tractor and Volvo excavator, you get a bunch of beams, panels and gears. Note how short the parts list is. What this money gets you is a big, great-looking car that is only really good for display. Functions? Steering with a lot of backlash, ridiculously simple suspension and transmission whose main job is making grinding sounds. Yeah, really, the transmission has so much friction in it, Lego actually threw a 24t clutch gear in there to let the wheels rotate when transmission locks up from abundance of friction. Someone had this weird idea to make a 4-speed sequential transmission and then add a separate forward/reverse selector to it, resulting in up to TWENTY gear wheels being active at the same time. And the best part? Well, there are two: first, the transmission only affects the piston engine, and you can't really see it because it's all covered up under the body. So the only real job for transmission is to change the frequency of the grinding sounds. Second, the transmission's speeds are actually messed up because as Crowkillers has noticed, someone put two gear wheels wrong in the instructions. Thus, for a paltry $300 you get a transmission that goes 1-3-2-4. Art of engineering indeed. The biggest problem with the 42056 is the price. Consider 42055: it's bigger and has PF, yet its price-per-piece is much lower. If Porsche had the same price-per-piece, it would cost around $192 - a not unreasonable comparison since these sets are released at the same time. So what's the extra $100 for? Just the Porsche license and a fancy box? For that kind of money you can get a proper RC car from an established manufacturer, with high performance motors and waterproof electronics. Yet Lego expects you to cough it up for something that can, um, look pretty (if you don't mind the gaping holes, that is). Pros: - really big, impressive and exquisitely looking unless you hate orange - finally it's not red again - the box and instructions are so good, they make UCS sets look like something you drew in class when you were 10 - a lot of new useful pieces, including the wheels - superb "starter pack" for those who want to build their own supercars Cons: - this is a $300 set with roughly $192 worth of Lego pieces - the "art of engineering" can't hold a candle to the 8880 - seriously, there's barely any function in this set that works flawlessly or makes actual sense. But hey, you get a luggage compartment and a bag with Porsche logo so who cares, right? - there's no PF nor an easy way to add PF - size, weight and limited functionality make it more of a display model - instructions come with an error - there's no B-model - $300 for what? Some comparisons:
  9. I never imagined I would say this, but as of today I am the proud owner of a Porsche 911 GT3 RS. How cool is that?! Waiting for this set to arrive seemed to take ages, so I was definitely on cloud nine when the set finally arrived. The 911 is one of the oldest sports cars on the market. It's lineage dates back to 1963, which is quite impressive! Since the production of the 911 there have been lots of different versions, like the Carrera, Carrera S, Targa, Turbo, R, GT1, GT2, GT2 RS, GT3 and GT3 RS. The GT3 RS can be easily recognized by the race-inspired inlets in the front wheel arches. Due to legislation there's a grill in the inlets. It can be removed during track days, which will improve the downforce. The LEGO Technic Porsche 911 GT3 RS is a 1:8 scale model and is 17 cm high, 57 cm long, and 25 cm wide. It has been designed by Andrew Woodman and Uwe Wabra. When TLG started the initial drafts in 2013, the Porsche 911 GT3 RS project remained top secret. Therefore TLG had to build the first LEGO version using photos of the camouflaged prototype of the original from the internet. The first LEGO prototype was ready in a matter of weeks. Like every sports car with the Porsche emblem on the hood, the LEGO version of the Porsche 911 GT3 RS also combines design, performance, and functionality. Still concealed in black-and-white foil as a mystery model at the Nuremberg toy fair late January, the color of the characteristic bodywork has now been revealed and shines in bright orange. Thus, it corresponds to the special coating of the original sports car in lava orange authentically. With the right skills you can get the GT3 RS around the Nürburgring in 7 minutes and 20 seconds. Factory driver Brendon Hartley took it for a spin on the Nardo circuit in Italy. The video can be found here. When you talk about a genuine sports car, you immediately talk about performance, which is pretty impressive, to say the least. Let's take a look at the specs: Horsepower: 368 kW or 500 pk (at 8.250 rpm) 0 - 100 km/h: 3,3 sec 0 - 200 km/h: 10,9 sec Top Track Speed: 310 km/h or 193 mph Price: around 250.000 euro (no extras, Dutch price) If you are interested in buying (or configuring) your own 911 GT3 RS, you can click here and indulge yourself. Instead of buying or configuring we will be building a Porsche 911 GT3 RS today. That's something not a lot of people could say, until now! Although I must admit that even though this version is a fraction of the price of the real car, it still has a pretty heavy price tag. Forking out 300 euros for a collection of ABS isn't something everyone will understand. Before we start I like to point out some of the questions which have arisen. For example; why is this set rated 16+ while the Mercedes is 12-16 year? Is the price tag of 300 euros justified? Does this model replicate some of the real world mechanics? Does the luxury packaging add any value to this set? These are just some of the questions I will be answering in this review. This review will have a different setup than my regular reviews. Since this sets focuses on the entire experience instead of the model alone, I will try to share this experience in my review. Instead of opening the box, discussing the parts and taking you through the build, like I usually do, I like to focus on the different aspects of the set and model. When it comes to the model, I will try to compare it with it's real life counterpart. TLG made a teaser for this set using the word Ultimate. There will be little discussion about the real Porsche's association with this word. But will it's LEGO counterpart live up to the expectations?! I think it's time to move onto the interesting part and find out whether this LEGO Technic set also deserves the predicate Ultimate. PICTURES Pictures can be clicked to view hi-res versions. More pictures can be found in my Flickr album. DISCLAIMER This set has been provided by the CEE Team of TLG. It's not my goal to promote this set. It's my goal to give you an honest opinion about it. Therefor, the opinion in this review is my own and is in no way linked to TLG. Number: 42056 Title: Porsche 911 GT3 RS Theme: Technic Released: 2016 Part Count: 2704 Box Weight: 4,8 kg (approx) Box Dimensions: 47,1 cm x 37,3 cm x 14,7 Set Price (MSRP): € 300 Price per Part: € 0,111 Links: Brickset, Bricklink Will this be a Limited Edition set? No, it will be as limited as other Technic sets. Which is also stated in the press release: The exclusive LEGO set of the exceptional sports car, which has been developed in close conjunction with Porsche AG, will initially be available at shop.LEGO.com from June 1st, 2016, as well as in the 13 LEGO stores throughout Germany and Austria. It will be available in other stores from August 1st, 2016. This means that when you are reading this review, the set is already available, which is usually not the case with other Technic sets. The box is a key feature of this set. Instead of a regular Technic box, this set is packaged like the 41999 - Crawler Exclusive Edition. The term Exclusive indicates that we are dealing with a special set, which is obviously the case for the Porsche as well. The following question (asked by JGW3000) is more than justified: Since the box presentation is a key feature of this set, perhaps Jim can comment on packaging and outer packing used to protect the box, so we can determine if we should go to a LEGO store or risk mail order in order to purchase this. In my Review of the 42043 - Mercedes Arocs I explained that my box was severely damaged. Obviously that's something you don't want to happen when you are buying a 300 euro Ultimate LEGO Technic set, with exclusive packaging. Lo and behold; the box arrived in pristine condition. The set box snugly fits inside the outer box, which avoids taking damage too easily. I am very pleased with the condition my set arrived in. I don't think getting the set in a physical store will guarantee a better condition. Thumbs up for shipping it this way. I hereby present, the Porsche 911 GT3 RS...in a box! It's way more luxurious than a regular LEGO box. Black and orange obviously work very well together. The bright color, combined with some post-crop vignetting really makes the Porsche stand out. I can honestly say that the box makes you anxious to open it. A LEGO box has seldomly made me feel more exhilarated before opening it. This is definitely a plus. This box is pretty big and feels massive. Since it's filled with additional boxes it feels very sturdy and doesn't dent easily. Since it's filled to the brim, the box isn't much larger than the box of the 41999. The width and height are the same. It's a bit deeper though, which can be seen in the image below. FRONT SIDE The front side of the box shows the model itself, along with the Porsche emblem and the set information. In case you are wondering what the 18 means in the upper right corner; that's not 18, but 1:8, the approximate scale of the model. It also states that this set is 16+, which is rather unusual. Hopefully we can answer Allanp's question at the end of this review: What makes this set carry the 16+ symbol? It isn't the largest or the most complex set to date, so why the 16+ age thing? BACK SIDE The backside of the box shows a top down view picture of the Porsche, along with four key features (interior, suspension, engine, upholstery). INSIDE The reason the box feels so sturdy is that it is literally filled to the brim. I can't think of any other Technic set which was filled like this. In the old days TLG used an inlay, but they never entirely filled a box like they did now. Showing the rims instead of packing them inside the box is a nice touch. The way the book and rims are being presented, is an indication that you are in for a treat. Another bonus is visible on the inside of the cover. It shows the history of the 911 from the original 911 (911) to the 2011 911 (991). The box contains: 1 x Book 1 x Sticker sheet 4 x Box with parts 1 x Box with rims and tires Each of the smaller boxes depicts what you will be building during that phase. I sure hope we will be building more than just an engine, seats, hood and a spoiler After discussing the box, the book definitely needs our attention. It's presented as the center piece of the contents and it's an absolute eye-catcher. The book packs a whopping 580 pages (including the front and back cover), which is unprecedented (not having seen the 2016 2H BWE instruction manual). Being designed as a coffee table book, it doesn't simply provide the building instructions. It also contains an abundance of historic information about the Porsche 911 and of it's LEGO counterpart's design process. Comments have been made that this book makes the set more expensive, which is debatable. Around 40 pages have been devoted to this additional information, which boils down to around 7% of the book. Maybe I'm simplifying the calculation, but this means this book can't be more than 7% more expensive than regular instructions would have cost. While we are on the subject of a coffee table book, TLG could have gone the extra mile and provide a hardcover book. This surely would have increased the costs, but you would get something in return. I'm not saying they should have, I'm saying they could have. Personally I think this book is fine, since it only contains about 7% additional information (concentrated at the beginning). It would have been a different case, if it contained more information throughout the book. Riffling through some pages of the book, we even see the previously mentioned Brendon Hartley making an appearance (top right image). The first step in the construction of your 911 GT3 RS is to build the drivetrain, complete with dual clutch gearbox (PDK), paddle shifters, suspension and the heart of the 911 GT3 RS, the 4.0 flat 6 engine. When you have completed all the steps in box 1 you will be able to test out all the functions and see how they work. Reading this means we are working on the fun part of the vehicle. Which immediately raises the question; is all the functionality of the car built during this phase? The first box contains 11 numbered bags. It even contains the new fender pieces, two printed and four unprinted. Will we be using these already in the first phase? Below are two images showing the new (and orange) parts contained in the first box. New pieces are the orange fender pieces, flex axles, the 3L axle with stop (color coded brown), new wheel hubs, changeover catches, suspension with red finish, panels and a tile with a unique code (supposedly to unlock online content). Instead of taking you through the build, I will discuss the different technical aspects of the real vehicle and compare them to it's LEGO counterpart. The single most interesting part about this set is the gearbox, which you start building early on. The picture below shows where the lever, to change the selected gear mode (Drive, Neutral or Reverse), will be placed (between the two blue 3L pins). As you can see, selecting Reverse simply changes the direction of the gears. Does this mean we have the same number of gears in Reverse as we have in Drive? Yes, it does! It’s the year 1983. In the new 956 Group C racing car, Porsche is putting a double-clutch transmission – Porsche Doppelkupplung (PDK) – through the rigors of motorsport for the first time. PDK offers a crucial advantage: the driver can keep the accelerator pedal depressed and change gear easily by using buttons on the steering wheel, even in the corners. This is how it works. PDK is essentially two gearboxes in one and thus requires two clutches. This double-clutch arrangement provides an alternating, non-positive connection between the two half gearboxes and the engine by means of two separate input shafts. During a gear change, therefore, one clutch simply opens and the other closes at the same time, enabling gear changes to take place within milliseconds. Highly responsive and particularly sporty. More information can be found here In the picture below we can see how TLG implemented the double clutch mechanism. There's a clutch at the top and one at the bottom. This is obviously a simplified interpretation of the real PDK. How about making your own four wheel drive Porsche? Does the transmission have an output that could be sent to the front easily, like 8448's (asked by Lego Nerd)? The red changeover catch is probably placed for stability (you will connect a liftarm to it later on), but it also provides a possibility to turn this into a 4WD car. Of course, you would need two additional differentials, one between the front wheels, and one in the gearbox between the front and rear axles. What's the point of having clutch gear inside all this? (asked by Allanp) Unlike in a real car, there's no stop after the highest or lowest gear, meaning that you can switch the car from 4th to 1st gear and from 1st back to 4th. That's one of the reasons the clutch gear is used, since the axles/gearbox will generate a lot of resistance/strain at some point. Another reason is that it's there to prevent possible damage to the gears if two speeds get temporarily engaged at the same time while rolling it. Or possibly if rolling in neutral and engaging drive while in first gear. Here's a video of the gear changing sequence. I have temporarily attached an axle to demonstrate the gearbox. Obviously you will not be shifting gears by turning a gear. You will be shifting this car, using the flappy paddle gearbox! How cool is that! The paddles are integrated in the steering assembly, which is shown below. The right paddle shifts the car into a higher gear, while the left one switches down. Here you can see the steering and shifting assembly attached to the chassis. The video below demonstrates shifting with the flappy paddles. Bear in mind that the subassembly is not yet properly secured, so there's some movement, which will be gone when the chassis has been finished. How am I supposed to shift gears by the way? As you can see there's no convenient position to operate the paddles. You need to grab the bushes and elastic bands to operate the gearbox. I can hardly imagine there's no better solution for this. Extending the axle by 1L would probably have done the trick. This feels somewhat cumbersome. The best solution would have been to design custom flappy paddles, but I understand this decision can't be taken lightly. What I don't understand is that TLG didn't provide an extra set of elastic bands. The bands will wear out after a few years on the shelf, rendering them useless. Providing a spare set would have been a nice gesture. Onto a more delicate matter. Some of you might have heard or read the rumors about this set being potentially flawed. Before jumping to conclusions, let's take look at the supposed flaws of the gearbox. First of all, the gear sequence is incorrect. Instead of switching from 1st to 2nd to 3rd to 4th, it's shifting from 1st to 3rd to 2nd to 4th. Say what?! I talked to Paul (Boratko, Crowkillers) about this possible issue, and without seeing any picture he immediately figured out that some of the gears must have been switched. As it turns out, there's indeed a mistake in the building instructions, or in the design, but I reckon it's not the latter. The video below demonstrates the incorrect sequence: I can (more or less) understand why this mistake has been made. What I can't understand is that this has not been caught before production. Quality control guys most likely aren't petrol heads, like some of the AFOLs. Let's take a look at what's wrong. On the left you will see the assembly when you follow the building instructions. On the right you see how it needs to be built. The grey 16T Gear and the black 12T Double Bevel Gear need to switch sides. the center gears are placed correctly. Here's a short video of how to apply the fix. The mistake has been made on page 267, 268 and 269 of the manual. So make sure to apply this fix when you reach that stage. After this fix, the sequence of the gearbox has been corrected. The gearbox is now shifting in the proper sequence, which can be seen in the following video: So it's all good now?! Well, not exactly. There's an even more pressing matter which we need to discuss. Occasionally the gearbox seems to stall completely. Take a look at the video and see what happens: Since you are not supposed to hook up a motor near the fake engine, the white clutch gear can't do it's job to prevent stalling. However, the main question is; why does the gearbox stall completely? And why does it stall so often? One of the reasons can be that the fins on the new red driving rings are slightly too thick. This will increase the change of the gears getting stuck. However, it happens quite often so I am not sure whether this is the case. The majority of the people building this set will probably never notice this flaw, since the clutch gear will hide the gearbox issues. But this set being The Ultimate, you'd expect the gearbox to function properly. The gearbox being the single most important technical function in the car, I am baffled by the fact that the mistake in the building instruction has not been caught, and that the actual gearbox itself seems to be flawed. Next time TLG better contact Paul before releasing another supercar This issue has been communicated to TLG, so let's wait for them to come with an official statement. Comparing the Porsche to the 42039 - 24 Hours Race Car we can see that the width from the end of the wishbones (where the ball joints connect) is 23L versus 19L. The Porsche itself is actually 4 studs wider than the 42039, two on each side. Compared to the steering assembly of the 42039. You notice the gear rack is much smaller, yet the turning radius is better. Two of half pins are limiting the turning radius of the Porsche. Removing them will slightly improve the radius, but the wheels might slightly touch the inside of the chassis, especially when the suspension is compressed. Here you can see the steering linkage, a pretty straightforward mechanism. Fitted as standard, the new rear axle steering with sport tuning combines performance and everyday driveability. An electromechanical adjustment system at each rear wheel enables the steering angle to be adapted based on the current driving situation, steering input and vehicle speed. The advantage for day-to-day driving: during low-speed maneuvers, the system steers the rear wheels in the opposite direction to that of the front wheels. This has the virtual effect of shortening the wheelbase. The turning circle is reduced to make it easier to park. The advantage for sporty driving: during high-speed maneuvers, the system steers the rear wheels in the same direction as that of the front wheels. Driving stability is increased by the virtual extension of the wheelbase and agility is enhanced by the simultaneous steering of the front and rear axles, especially during overtaking maneuvers on the racetrack. One of the coolest feature about the real 911 GT3 RS is the fact that it has rear axle steering. It even alternates between steering modes! At low speed it counter steers (to improve the turning radius) and at high speed it steers in the same direction (to increase driving stability). That's so incredibly cool. And it's definitely something we expect to see in The Ultimate supercar TLG is releasing. Unfortunately they haven't. I am very disappointed to conclude that there's no real axle steering at all. Not even counter steering rear wheels, which would have sufficed. Obviously having both modes would be super duper awesome, but at least give us the counter steering mode. Not sure why TLG hasn't implemented this feature. They might have felt the need to do both of them. But omitting rear axle steering altogether is a huge letdown for me. RECTIFICATION I need to rectify something. According to this interview on the Top Gear site, Porsche vetoed the inclusion of the rearsteer. Obviously Uwe was able to recreate this mechanism. Makes you wonder why it wasn't included. This electronic active damping system offers continuous adjustment of the damping force on each wheel based on the current driving situation and your driving style. At the press of a button, you can select between two different modes. ‘Normal’ mode is designed for sporty driving on public roads and on wet racetracks. ‘Sport’ mode is specially tuned for maximum lateral acceleration and offers the best possible traction on the track. To continue with cool features, or letdowns, the 911 GT3 RS has, what's called PASM (Porsche Active Suspension Management). This basically boils down to ride hight adjustment, which is another potential cool feature to incorporate into the model. Unfortunately, like the rear axle steering, this feature has been omitted too. The engine of the new 911 GT3 RS sits just above the tarmac. At the rear end, of course. With its low center of gravity, it was predestined for motorsport. Indeed, this water-cooled six-cylinder unit with four valves per cylinder, VarioCam and dry-sump lubrication with a separate engine oil tank could not be more ideally equipped for its role. The engine draws its power from a capacity of 4.0 liters. This equates to a power output per liter of 92 kW (125 hp), and acceleration that simply knows no limits: the sprint from 0 to 60 mph is completed in a mere 3.1 seconds. The real Porsche has been fitted with a 4.0 liter 6-cylinder boxer engine, while its LEGO counterpart is fitted with a flat 6 engine. The difference between a boxer and a flat engine, is the movement of the pistons. The boxer engine has horizontally opposed pistons (when one piston moves in, the opposite piston moves out), while the flat engine has pistons on each side moving in and out simultaneously. More information about flat engines can be found here. Edit: Techniccrack pointed out that it's exactly the other way around. So the boxer engine has pistons moving in and out simultaneously. Thanks for pointing this out. While the engine in the LEGO version isn't realistically correct, I certainly don't mind TLG choosing this solution. It would have been cool to see new engine parts, but it's perfectly understandable that TLG used the currently available parts. After 323 steps (of 856) you have finished 38% of the model, resulting in the chassis. If there's no additional technical functionality (which seems that way) this means that 62% of the build consists of adding body and interior parts. Constructing the gearbox is interesting, but the overall build of the chassis is a bit underwhelming. The engine has been completely covered by panels and other parts, which is true to the original Porsche. But it does prevent you from seeing the pistons move at different speeds when shifting gears. The calipers are looking rather rectangular. Makes you wonder if it would have been better to use black parts combined with a rounded sticker. This would have reflected the actual shape better. Another option would be to create a custom part, but we obviously TLG can't keep designing new parts. It's cool that they included the calipers in the first place. The rear side has double shock absorbers, while the front uses a single absorber (per side). The back of the car is very heavy compared to the front, so this is good decision. Another aspect which has been discussed is the color vomit in the interior. I don't really mind using colors in the interior (like UCS Star Wars sets), as long as the different colors aren't clearly visible. Clearly visible are the blue pins (especially two of them in the gear box (D/N/R selector). Shouldn't these pins be black? More on this later. During production of the real 911 GT3 RS there is a stage called 'the marriage', where the drivetrain is connected to the body of the car. In this box you build the floor plan of the 911 GT3 RS, complete with seats and roll cage, before placing it over the drivetrain in a similar way to the production of the real 911 GT3 RS. The second box contains 9 numbered bags. The orange parts, including a 11L liftarm and axle connectors, which I already spotted in the Maze set. For me this was an indication that the Porsche would be released in Orange. The floor plan of the car is built separately from the car, in a modular fashion. Note that the body can't be easily detached from the chassis after completing the model, so it's not a real modular build. Here's a video demonstrating the marriage: After the marriage, and adding the seats, the car looks like this. At this stage you have completed 531 steps (of 856) or 62%. I really enjoyed building the second box. Placing the floor plan over the drivetrain is gives you a sense of building a real car. Clearly visible is the roll cage behind the seats. In box 3 you start to assemble the body of your 911 GT3 RS. Starting with the rear of the car and then onto the build of the iconic hood, now with distinctive shaping. Then it's the roof, again with distinctive shaping indicating the lightweight magnesium design only found on the newest 911 GT3 RS. The third box contains 4 numbered bags. Since you will be building the body, this box mainly contains an abundance of orange parts, including lots of panels. This set contains the full range of available panels in orange, except the 5x11 Panel. If I counted correctly this set contains 31 black, 59 orange and 2 grey panels, resulting in a grand total of 92 panels! It also includes 18 frames, which is quite a lot. At the end of box 3 you have finished 79% of the car (679 of 856). It is starting to look like a real Porsche! I absolutely love the new-ish 13x3 Curved Panels. They work really well on this model. Thumbs up for the part designer who designed this part! Now you build the front before adding the distinctive wheel arches with air outlets only found on the 911 GT3 RS. Next you add the massive, motorsport inspired, adjustable rear wing before finishing off your 911 GT3 RS by adding the doors and the exclusive wheels. Like box 3, this box also contains 4 numbered bags. Also containing mostly orange parts and panels. This leaves us with a finished car...okay, almost finished. Next stop, wheels & tires. 20 inches at the front axle, 21 inches at the rear axle. For a wheel size combination, that’s a first in the 911 model range. The larger footprint makes another improvement to dynamic performance. The wheels are made from a forged alloy and feature a platinum-colored paint finish. The central locking device bearing the ‘RS’ logo is derived from motorsport. Compared with the conventional five-bolt wheel connection, it offers enhanced performance thanks to the reduction in rotating masses. And, of course, it ensures a faster wheel change, which is vital when you’re in the pit and the clock is ticking. The tire sizes on the new 911 GT3 RS are nothing short of impressive: 265/35 ZR 20 on 9.5 J x 20 at the front, 325/30 ZR 21 on 12.5 J x 21 at the rear. The last box contains the rims and tires (stored inside the box). As you can see the LEGO wheels have the same size for both the front and the rear wheels. I think this is a perfectly understandable choice. Different sizes would have been hardly noticeable, but it would have added significant costs. Great thing about these rims is, that they are custom designed rims for the GT3 RS. Another great technical specification is that the offset inside the rims reflects the real rims, resulting in a better steering geometry. The printed RS emblems on the 1x1 tile add a nice touch. What size of construction can fit inside the new wheels for when making custom steering and suspension geometries? 5x3? 7x3? 7x5? How deep are they? (asked by Allanp) Can you tell me if they fit on the portal hubs? (asked by Zblj) Hopefully the following images will answer both questions. The portal hub is touching the rims, so it's not possible to fit them without spacers. The image below shows how far the frame is protruding from the rim. Let's talk rims and tires! From left to right (links to Bricklink for easy reference): 42039 - 24 Hours Race Car (and 10 others) 42000 - Grand Prix Racer or 8146 - Nitro Muscle 42056 - Porsche 911 GT3 RS 8674 - Ferrari F1 Racer 1:8 42030 - Volvo L350F or 8110 - Unimog or 76023 - Tumbler 8466 - 4x4 Off Roader or 5659 - Power Puller This picture shows which wheels will fit nicely under the new wheel arch panels. Front view of all the rims. As you can see the Ferrari F1 tires are slightly wider and almost the same height. The Ferrari tires have a slightly higher profile than the Porsche tires. Hopefully this image will give you some reference as to how the different rims compare to each other. This clearly shows the depth of the different rims. After adding the wheels, you have finished your very own Porsche 911 GT3 RS! Let me start by saying that I absolutely love the looks of this car. It sure is a 911 GT3 RS, no doubt about it. I have read some criticism that the car doesn't look good from certain angles. I beg to differ. Taking in account that we are still talking about a LEGO model, I think this car looks magnificent. There's a gap between the headlights and bumper, which people have complained about. Admittedly, it would have looked better when the transparent dishes would be positioned half a stud deeper and half a stud lower, but I'm not too bothered with it. Here are several pictures showing how the model will look after approximately 10 hours of building time. I love the front view of the car, with the black gear racks in the front bumper/spoiler. And I love how the hood worked out, but that's because I love them curved panels Back of the car looks pretty decent too, although I am not really sure about the rear lights. On the other hand; these kind of shapes are hard to capture in a Technic model. EXTRA FEATURES We have spoken about the technical functions of this model, but obviously there are some extra features as well. These are depicted in the picture below: Open hood/bonnet Open trunk/boot Open doors Adjusting the spoiler (regulate downforce) A bag for storing your racing gear COLORS Take a look at the image below to see some of the color choices TLG has made. What's catching our eye, is that the decision has been made to use a Black 2L axle in the door handle, instead of the usual red one. Kudos for TLG! However, in the rear wheel arch they used a tan frictionless pin and a blue friction pin. Maybe I am missing something, but why did TLG use the tan frictionless pin?! There are no rotating parts in that assembly? Furthermore; wouldn't it have been a great opportunity to use black 3L friction pins throughout the model. This would acknowledge the fact that it's a 16+ set and it would have made bodywork look way better. This would also solve the blue gearbox pins issue. And while we're at it, throw in black axle pins, as the icing on the cake. I understand the regular color policy, but this set being a 16+ set, and the Ultimate, and blabla, well....you catch my drift. 16+ AGE INDICATION This is the right moment to continue the discussion about the 16+ age indication. Asked by Allanp: What makes this set carry the 16+ symbol? It isn't the largest or the most complex set to date, so why the 16+ age thing? To be honest; I am not entirely sure. The build isn't that complex to justify the 16+ indication. My best guess it has something to do with the set being more of a display set than a play set. If it were a real 16+ set, all axles and pins would have been black and the instructions would have had a lot less steps. There's probably a good reason for it, but at the moment I can't explain why this set it 16+. COMPARISON WITH 42039 The picture below shows a comparison with the 42039 - 24 Hours Race car. While it's only 4L wider, you can see it's much longer. The next two pictures show the entire bill of material. A lot of discussion has been going on about the price. It is pretty steep, there's no denying that. But does this set justify spending 300 euros? I have tried to come up with a fair calculation, without any prejudice. Basically it's the same car as the 42039 (24 Hours Race Car), only bigger. Meaning it doesn't have Power Functions, Electronics or Pneumatics. Nor does it have an abundance of very special parts (some new molds and colors, which I will account for later). Both cars use lots of panels to make them look nice (don't get me wrong, I love panels). In my opinion a comparison with the 42039 is justified. I can even add the 42000 Grand Prix Racer to the equation. Also a car, more or less same scale as the Porsche, no Power Functions, Pneumatics, whatsoever. So let's do the math. The 24 Hours Race Car has an MSRP (Manufacturer's Suggested Retail Price) of 100 euro (same goes for the 42000). The Porsche has an MSRP of 300 euro, which makes it three times more expensive. The 42039 has 1219 parts (1141 for the Grand Prix Racer), so the Porsche should have around 3657 (or 3423 parts). Let's take the average, round it down and make it 3500 parts. 3500 versus 2704 parts. Something doesn't add up. Why am I missing around 800 parts?! Based on the 42039 and 42000, a Technic set like this should end up with a price per part around 8,5 cents (the average of 8,2 and 8,8 cents). Meaning the Porsche should have cost around 230 euro, but it doesn't. So, the conclusion of this little calculation is that you are paying 70 euro for added value. What can be considered added value? A nice book, special box (and packaging), new rims, and an official Porsche license. I don't think that counting the book as added value is fair, since any set of around 3000 parts will have a pretty thick book. The book actually contains around 40 pages without instructions. So around 7% percent of the book is added value. This seems negligible when it comes to printing costs. This leaves you with the box (including extra packaging) and the license. We've probably all seen the video where you see the packaging process, which is mostly done manually. Let's say the box and extra packaging adds another 10 euro. Still 60 euro to allot. For those of you who haven't seen the video; LEGO Technic Porsche 911 GT3 RS Sneak Peek from LEGO Factory in Kladno: Some new molds have been created (rims, fenders, panels) and a lot of parts in orange for the first time. Imagine this this eats up another 10 euro per set. This leaves you with 50 euros for the Porsche license. Maybe I underestimate the new rims/molds, booklet or packaging. That could very well be the case. But it's a fact that this model is relatively more expensive than the 42039 or 42000. Simple mathematics, no more, no less. I'll let you decide whether the added value is worth paying the extra bucks Almost at the end of my review, it's time to summarize how I feel about this set. Usually I am not overly critical. I acknowledge the fact that at the end of the day, LEGO is a toy. However, this is a different ball game. Being a 16+ set and TLG calling it The Ultimate made it clear that this set means serious business. UCS TECHNIC First of all I am really pleased to see TLG venturing into the Technic realms of what's commonly referred to as Ultimate Collector Series in the Star Wars theme. We've seen hints about this being the first in a new series, so I surely hope to see more models like the Porsche. UNBOXING EXPERIENCE When the set arrived I was on cloud nine. This is more than your run of the mill Technic set, so I was really excited to get building. This excitement continued during the unboxing phase. The box has a deluxe appearance and it's filled with nicely packed goodies. All in black and orange, which absolutely looks stunning. THE BOOK The books which has been included contains some cool additional information about the Porsche. Mainly before the start of the build though. The vast majority contains building instructions. Being a coffee table book, a hardcover would have been cool. It's no biggie that it's not though. THE BUILD The technical part of the build is concentrated in the first box, meaning that after 38% of the build you are done with the functional parts, leaving 62% of the build adding cosmetics. This is somewhat underwhelming. I really enjoyed 'the marriage' phase though, which gives you the feeling that you are actually building a car. TECHNICAL FEATURES Unfortunately, when it comes to technical accuracy there's a lot left to be desired. No active suspension management or rear axle steering. So two of the most interesting potential features have been omitted. Being the Ultimate it would have been cool to see both, or at least one of, these functions implemented in the model. GEARBOX The flappy paddle gearbox is supposed to be the star of the show. It's absolutely cool that TLG has implemented this feature. However, the mistake in the building instructions leaves you with an incorrect shifting sequence. This issue will most likely be corrected in a later version and/or an errata will be provided. I am not sure whether TLG will address the gearbox locking issue. This being a display model, I don't think this issue will be noticeable for the majority of the builders. The fact that Reverse has the same number of gears as the Drive mode is not accurate, but for me this is an acceptable choice. The flappy paddles could have been implemented in a way that you can actually operate the paddles, without touching the rubber bands constantly. PRINTED PARTS The RS 1x1 round tiles on the rims have been printed, which is nice! Makes you wonder why the 1x1 tile on the steering wheel (with Porsche emblem) hasn't been printed. It's plus that the wheel arches have been printed. This ensures the model still looking good after a decade on the shelf. At that time the rubber bands will be petrified and will most likely break when operating the gearbox. Therefor, it would have been great if TLG provided an extra set of elastic bands, for future use. PIN COLORS TLG has used a black 2L axle in the door handle, which definitely looks better than red ones. However, they haven't included 3L black pins. Instead they still used the blue ones. If you decide to use black 2L axles, why not use 3L black pins in several places. WOW FACTOR I showed it to some friends (non AFOLs) and the only interesting thing to show is the gearbox. Which actually doesn't really present well, since you don't see what's happening. You don't even see the pistons moving faster. Basically there's not much to demonstrate, other than it's an impressively big model. A very good looking, yet slightly boring, model. PRICE I have devoted an entire chapter on the price of this model, of which the conclusion was that you pay around 70 euros for added value. It depends on the type of LEGO buyer or builder you are (and the size of your wallet) whether this is justified. The price tag of 300 euro seems a bit steep for what you get in return, so I can imagine some of you will wait for a nice deal to emerge. CONCLUSION TLG definitely brings a unique experience, and I really like the looks of the model. However, the feeling that this "could have been" a better set predominates. That being said, I still think it's a must have for every LEGO Technic car enthusiast. It looks cool when you put it on display. And it offers lots of possibilities to modify. Or like brunojj1 phrased it: Seems to me like the Porsche delivers a perfect base for MODing and MOCing variations such as B-models or PF upgrades to make it a real ULTIMATE. If you are looking for the perfect set, you better look further. If you are looking for a unique Technic set with great potential, this is the set for you! ...and with this bombshell it's time to end Leaves us with the scores. 9 DESIGN This definitely is a 911 GT3 RS! 8 BUILDING EXPERIENCE Build itself is okay, the total experience adds a point. 5 FEATURES It lacks two functions and the major function is flawed. 6 PLAYABILITY This being a display model, it's virtually non-playable. 9 PARTS New rims, entire range of orange panels and new orange parts. 7 VALUE FOR MONEY Depends on your budget, purpose to buy it and other motives. 7,3 COULD HAVE BEEN BETTER I really wish TLG would have been more clear about the embargo rules. Pictures and videos were popping up everywhere on the Internet, while the review embargo stated the 1st of June. Additionally, the set already seemed to be available at some locations. Other than that, I still enjoyed the ride and I'd like to thank TLG for providing me this set! Thanks you for reading this review. All pictures can be found in my album.
  10. Hello everyone, I am really glad to present you my new MOC, a replica of the Porsche 911 GT2 RS. My goal was to built a fast and good looking car, so it has not that much technique inside of it (it just uses one single gear for steering :) ). This model is RC and has the following features: Rear wheel drive powered by 2x Buggy-Motors (top speed is around 12-13 kp/h, in ludicrous mode 14-15 kp/h) Steering powered by a servomotor Working rear lights Independent wheel suspension Opening doors and detailed interior and exterior The car is powerd by Buwizz, so it has plenty of power. Dimensions: length: 35,5 cm | 46 studs / width: 15 cm | 19 studs / height: 11,2 cm | 14 studs Scale: 1:12 The model is relatively small compared to the Lamborghini Sian. Important Picture from the bottom ;). I made some 3D printed wheels and panels for the car. The car with normal lego wheels. You can find more pictures (including some from the building progress) at: https://bricksafe.com/pages/Lukes_Brick_Studio/porsche-911-gt2-rs Comments, suggestions and questions are always appreciated. See you.
  11. Hello everyone, hope you are doing well. I have recently re-visited a model which I started building years ago when I first dove in the world of lego technic. I have made some final adjustments and the model is now complete. It's my pleasure to share it here: 911S 2.4L from the 70's - 1800+ parts - 1:10 scale - air-cooled flat six - 4 speed manual gearbox (an adaptation of the gearbox found on @Charbel's Volcano supercar) - working steering wheel - independent rear suspension - macpherson strut front suspension (courtesy of Gergely's Technic Models on Youtube) - openable doors, bonnet, and engine cover What do you think? P.S.:This MOC shares ~70% of the parts with set 42096 - Porsche 911 RSR. And I have also make sure no blue pins are visible outside. If you are interested, instruction is available here And with the orange F150 fenders available, I'm thinking about building a Targa version too :)
  12. Hi everybody! Thanks to the organizers for this contest, I will participate for the first time! I chose the Porsche 911 RSR We are waiting for a detailed car with high detail. Doors and engine compartment open Rear independent suspension HOG and I will try steering control Mid-engine Maybe stickers Wheels 49.6
  13. Hi, I've been working on this project in recent months, and I felt like sharing it at its current state. The majority of the design is based on my favourite car, the Porsche 911 964 RS 3.8. However, as I find it difficult to replicate the front of the 964, I've added a bit of the 911 997 GT3 RSR into the mix. At this point, the content of this post is only related to bodywork as I've always found it very difficult to develop. I've also worked on the chassis in parallel, which contains steering (maybe HoG should be added), suspension, a flat 6 engine, and a manual 4-speed gearbox with linkage. Maybe I will include the chassis in the next post. The front and rear axles are 25 and 27 studs wide respectively. Obviously the A-pillars are still missing, and some parts of the bodywork are still floating. I'm currently considering if the roof should be narrower and tilted slightly, but I guess it will be more clear when I start to design the A-pillars. I'd be very happy to hear some ideas for improvements, things that seem out of proportion and general feedback. Also, I installed BrickLink Studio to make the renders, but I found it difficult to make the 19L flex axles around the wheel arches look natural. Do any of you have some good advice on use of the flex tool in Studio? Best regards, Jens
  14. Hello everyone, I’m new to LEGO technic, just started building early this year. My first set was Porsche GT3 RS and I got hooked immediately. Today, I would like to share images of my very first MOC - 1:10 scaled Porsche 911S in the late 60s early 70s. I’m not yet familiar with gearbox or power functions so the technical aspect of this MOC is rather limiting. However, I’ve tried to make the shape as close to the real thing as possible. Hope you like it. Suggestions to improve it are welcome! 3BAFAACA-249F-45BC-9CE5-2AAA3F964455 by Linh Nguyen, on Flickr BB1D66DC-F53A-4043-8CB7-75B2CC569293 by Linh Nguyen, on Flickr F60B2C88-C6E2-453B-97B4-BD0D05A6573D by Linh Nguyen, on Flickr 18362AD6-958C-4E1C-8E62-935DB3D281FF by Linh Nguyen, on Flickr D262E23D-8ED5-46CF-B73C-622BAB65542D by Linh Nguyen, on Flickr 7F2832D6-E0D5-4B5E-8F20-093BC788D67D by Linh Nguyen, on Flickr 105170B6-7B4F-4EBD-AC8F-0952722147DD by Linh Nguyen, on Flickr E1FA7BBC-3A8F-4DB3-9C3B-7E86280721B2 by Linh Nguyen, on Flickr 77A019B7-4CC0-44E7-B80F-70A22DABD165 by Linh Nguyen, on Flickr - the car has independent suspension on all 4 wheels - a working steering wheel, no HOG but that may be added later on - a fake flat six air cooled engine, the “fan” spins as the engine pistons move - manually operated doors, boot, and engine cover - no gear box but a fake gear stick ( which can move up down or left right) is included - a small boot, able to fit a “bag” as shown - two toned simple interior with 2+2 seats, the front seats can be folded/adjustable, a rear view mirror is included as well And in case you are wondering, I did paint the mudguards from Porsche RSR set to be used in this MOC. The rest are standard LEGO parts, except for some strips of black vinyl tape I use as bumper strips to match the real car. Let me know what you think :)
  15. Baby Porsche or VW Beetle tuning? This is a fictitious race car, I hope you like it :) You can support it on Lego Ideas: https://ideas.lego.com/projects/68cb5ef6-6e2c-40fc-9dca-0e4b7f3fe64a It is a studless build in Speed Champions scale, but with City wheels. I used only standard LEGO elements, the slopes with stickers are part of the set called 1968 Ford Mustang. Baby Porsche 01 by László Torma, on Flickr Baby Porsche 02 by László Torma, on Flickr Baby Porsche 03 by László Torma, on Flickr
  16. Alright, so this is my second post on Eurobricks, and my 3rd alternate of the 10220. Here I have a custom Porsche rallycar with some additional features. The "costum" stuff is a huge spoiler and rear seats. If you didn't know, most Porsches don't have rear seats. Functions Opening hood with trunk space Opening doors with nice interior With doors opened, the seats fold down to access the rear seat Opening trunk with flat 6 engine Soon to be on Rebrickable for $2.50 for instruction, search "a1i2d3e4n5" and find this model. Enjoy!
  17. REVIEW - 42096 - PORSCHE 911 RSR INTRODUCTION Not too long ago, 2016 to be precise, I wrote a review about a big orange Technic Porsche. Only 2,5 years later a new Porsche is added to the Technic range! This new Porsche 911 RSR uses the same wheel arches as the 42056, but slightly smaller tires. It's hard to qualify the exact scale, but for roughly half the price, we can expect less detail than the previous one. At first glance I am very happy with the looks and especially the color scheme. Looking at the name of the set, the color scheme wasn't a surprise, since this is how the actual model looks like. That diffuser means serious business. Edit: The wheel arches are a different size than the ones we already know. They are two studs shorter. Thanks to @LvdH for pointing it out. This review might be less detailed than usual, but time was limited. Sorry about that. I do hope you enjoy it anyway! PICTURES Pictures can be clicked to view hi-res versions. More pictures can be found in my Flickr album. DISCLAIMER This set has been provided by the CEE Team of TLG. It's not my goal to promote this set. It's my goal to give you an honest opinion about it. Therefore, the opinion in this review is my own and is in no way linked to TLG. SET INFORMATION Number: 42096 Title: Porsche 911 RSR Theme: Technic Released: 2019 Part Count: 1580 Box Weight: 2266 gram Box Dimensions: 47,7 cm x 37,2 cm x 9,0 cm Set Price (RRP): € 149,99 Price per Part: € 0,095 Links: Brickset, Bricklink THE BOX CONTENTS OF THE BOX The box contains: 1x Sealed booklet 2x Sticker sheet 4x Tires 13x Unnumbered bag BOOKLET STICKER SHEETS Two sticker sheets, with loooooots of stickers. There is even a completely white sticker, without a print. Seriously?! TIRES BAGS HIGHLIGHTED PARTS WHEEL ARCHES Okay, let's get the big black-red-grey-white elephant out of the room. If you know a bit about TLG's sticker policy you will know that TLG avoids applying stickers to curved surfaces. And by curved I mean curved in multiple directions. So, it wasn't (or rather should not have been) a surprise that the wheel arches are printed. But man o man....are you kidding me?! These look like stickers I applied after a couple of brewskies....several brewskies....lots of brewskies! I totally understand the difficulty of printing these parts, but I expect more from a company claiming that only the best is good enough. Two thumbs down for these arches. These wheel arches are slightly smaller than the ones on the 42056 by the way. I somehow missed this when I was building the model and writing the review CANOPY Clever use of the Windscreen 6 x 4 x 2 1/3 Bubble Canopy with Handle. 7 x 3 CURVED PANEL I almost missed this one, but it's the first time we get this one in white. 3 x 13 CURVED PANEL Thank you TLG for finally providing this part in white! BANANA GEARS We have seen these 11x11 Curved Racks in the Rough Terrain crane, but they are cleverly used in this set too. PINS AND CONNECTORS Not all of these connectors are new, but the Pin with Ball Joint has never been released in red. And the Pin with Pin Hole has never been released in white before. And the Axle with Pin Hole has never been released in black before. PART LIST The part list for all of the 1580 parts. THE BUILD Unsurprisingly, we start building the chassis, with the rear suspension. Here's the front suspension with steering rack. The chassis with front and rear suspension. The single seat and steering wheel have been added. The water-cooled six cylinder 4.0 liter boxer with 510 hp (375 kW) has been placed behind the driver's seat. Wheel arches and doors have been added. The car is taking shape. Yes, there is a sticker with track information applied to the inner side of the door. In case you get lost hehe. The front of the car looks spectacular. I love the usage of the "banana gears" and curved panels. I also like the canopy parts. I know they make the car look like a frog, but I still like ' em. They work for me. Like the front, the rear of the car looks stunning too. I absolutely love that big bad-ass diffuser. The hoses and panels complete the package, along with the big spoiler. Thumbs up for the rear. These are the left-over parts. COMPLETED MODEL We proudly present the Frog 911 RSR. I'm just joking, because I absolutely love the looks on this car. The color scheme is spot on. Maybe it's because I am working on a Mindstorms project with the same color scheme The gap behind the front wheel is actually present on the real car as well, so it's by design. Obligatory picture of the chassis. Isn't she a beauty?! I love this shot. What I don't like is the abundance of white stickers. And by white, I mean actually white. The color of the stickers don't match the white on the panels, at all. A very simple solution would have been to print the stickers off-white, instead of pure white. Printing the stickers in pure white even resulted in the need to apply a totally white sticker to one of the roof panels. A white sticker to match the other roof stickers, otherwise the color difference would have been even more obvious. I can't get my head around this approach, because a very simple solution seems to be available. Another approach would be transparent stickers, but I haven't seen those in a while. The doors and the engine cover open up. Combined with fake engine, steering and suspension, that pretty much sums up the functionality in this car. There is no HoG (Hand of God) steering, which is a huge let down for me. I can imagine the people at Porsche had a say in this. Makes you wonder whether the licensed approach, over proper functions, is the right path for TLG to take. The wind shield wiper is fixed in place by the way. The side view shows that the wheels are slightly too small for the car. Or the wheel arches are slightly too big hehe. The size of the wheels just doesn't feel right. Of course, there is limited choice in wheels, so I understand this choice. No biggie. All things considered, the car is eye candy! A final view of the rear, because this is most likely the part of the car that you will see most, unless you are a really good racing driver COMPARISON WITH 42056 This review would not be complete without a comparison with the 42056 - Porsche GT3 RS. When you are building this model, you get the feeling that you are building more or less the same scale, maybe because of the wheel arches. But looking at the comparison images it is clear that this model is indeed a different scale. This obviously explains the lower part count and price. Both fronts have that distinctive Porsche look. I like the canopy style headlights. This picture from the rear clearly shows the difference in scale. The orange one has a much bigger ass I do think the RSR's rear design is much cooler than the RS3's. I know it's not fair to compare a street-legal car with a circuit racer. I would love to see someone give a go at an RSR version in the same scale as the 42056. Actually, I am surprised I haven't seen one made by @JunkstyleGio in LDD yet, but I might have missed it B-MODEL Like the previous Porsche, there is no official B-model for this car. I'm sure some fan made B-models will pop-up. SUMMARY To be honest; I am torn between two opinions. My first opinion is that this is a stunningly beautiful car. I absolutely love the color scheme and looks on this baby. I can't stop looking at it and it looks so much cooler than the 42056. My second opinion is that the printed panels and stickers look horrible. This may sound confusing, because I just said it looks stunning. Well, it looks stunning from a distance, in a cupboard or something. You can see a lot of flaws from close by. The lack of HoG steering is also a bit let down for me. Basically, there is zero playability, so yet another display piece. The 42039 had some simple functions, which made the car fun to play with. Like the 42056, this is just another display model. A display model depending on lots of stickers. Would I recommend it?! You bet I would. Why? Because it's reasonably priced and I can't stop looking at it. I will probably get a second copy and have a go at a Porsche 911 EV3 PROS Color scheme Stunning looks Price (you can get a big Porsche for a reasonable price) CONS No hand of God steering No playability whatsoever Awfully printed wheel arches White stickers too white Too much stickers SCORE How do I rate this set? 9 DESIGN I love the design and color scheme. 7 BUILDING EXPERIENCE Plain build. No interesting functions. 6 FEATURES Which features?! 6 PLAYABILITY Push the car back and forth. Hard to steer. 7 PARTS Finally, white wheel arches! Oh wait...they are printed...badly. 8 VALUE FOR MONEY You get a cool Porsche for a reasonable price. 7,2 GREAT LOOKING DISPLAY PIECE...FROM A DISTANCE FINAL WORDS Thanks you for reading this review. All pictures can be found here.
  18. Hi everyone, i'm new to the forum. I've known eurobricks as a resource for content for some time now and Jim asked me to make an account. What do you think about my custom made display?
  19. I present my 1987 Porsche 911 Turbo Slant Nose. I went for form over function on this build. It has opening doors and engine compartment. I followed a blue print for this model that I blew up to 155% on the copier at work. It translated to 14 studs wide by 36 studs long. I pride myself on making sturdy models (no large pieces held on by 1 stud here) and this one is no exception to my standards. I am very happy with how the Mixel ball joints worked out on the window framing, as they are fairly new pieces and I haven’t seen it done before. I hope you enjoy it as much as I do!
