Showing results for tags 'Ackermann steering'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Warning: The suggested solution may not be regarded as perfectly 'legal' by some of you. Find out for yourself whether you want to go as far as this when it comes to fine-tuning your build. Everyone who has ever played around with custom steering setups with realstic features such as caster angel and/or camber angle knows the hassle of finding the most optimal tie rod and tooth rack position. Optimal in a sense that effects like toe-in, toe-out and bump steer are avoided as much as possible. And when you have found the optimal placement, there is still so much slack in the ball joints that your build is always left with a certain amount of toe-in or toe-out, When all seems fine when driving forward, there will be some toe-in/toe-out when driving backwards. It may not be the most aesthetic solution but I found a very effective way to reduce the slack in the tie rod / ball joint connections. Simply tie one or more rubber belts around the ball joints, just below the ball part of the joint. In my case the combination of a red rubber belt (24mm) and a white rubber belt (15mm) worked out perfectly, see image below. Note that in a standard steering setup with all ball joints perfectly aligned on a 1-stud grid, this approach will prove hard to apply, as it will pull the pivot points slightly away from their ideal position. It is particularly useful in custom setups that try to obtain non-standard features such as caster angle, camber angle or Ackermann steering.
