Showing results for tags 'Battle of the Wither Woods'.
For the story, see the first thread about the War of the Brothers The call for arms and the challenge are open to ALL guilds. PART ONE: A CALL TO ARMS – The Battle of the Wither Woods The battle of the Wither woods is coming. Dugal and Petera both need help to defeat the other. Which side will you choose? These battles will be fought in the same manner as the Battle of Queens Cross and the Battle of Khordeem. Meaning, you sign up your hero or squad, and I try to replicate them and get them into the battle. This Call to Arms is only for the first battle, the Battle of the Wither Woods. When you sign up, state the men you are sending and which brother they are supporting. Remember, Dugal fights for the Historica of present, while Petera fights for the Valkarian Order’s desire for a new stronger Historica. How this works: Basically, the battle will be fought out as a wargame, using rules that my brother and I have been working on for a LONG time. (This is also a playtest for us.) It will take a few days to get all the way through, but should prove to be epic. The plan is simple. The call has gone out by raven , magic and other means to the far ends of Historica. Help is needed at the upcoming battle in the Wither Woods. If you wish to join the battle, send your small troop by mage, boat, or land to either North Avalonia (Petera) or Eastgate (Dugal). Some may make it for the start of the battle, and others might join in the thick of it as reinforcements. Anyone that signs up while the battle is still going, we will try to get into the battle. All we need is a pledge of men (1-10, although 10 may be hard to represent on the battlefield; the ideal number is squads of 5). I will try to represent your figures as closely as possible, but it might be hard to accurately represent some heroes or your actual men’s uniforms. (we can always chalk it up to artist’s interpretation) We will then give your men (or women!) stats and bring them into battle. They will then fight in the battle to see if they can help win it for their side. If your hero or your men are known for a certain weapon style or ability, include it in your pledge. We will try to accommodate this in your character’s stats. You may want to also show us a picture of who you are sending, if you want us to try and replicate them. WARNING: The soldiers you send may die – if you send a hero, you might want to tell us you would prefer they fell wounded or are likely to retreat. It is all luck of the dice (much like the tournaments that have been held) The battle won’t start until Later in May, but I will keep checking the forums for new recruits and can add people all the way until the battle is done. So if you don’t make it before the battle, sign up at any point during the battle. Anyway, I hope some of you will heed one of the brothers calls, and join them to defeat the other. Post below your men and who you are pledging to help. ----------------------------------------------------------------------------------- The contest thread has been moved to here. The text is the same as below though. PART TWO: Bringing the pain We are going to try something new this time around; we are going to have other people “build” weapons of war that will be used in both battles. The builders will build LDD models that we can use the show construction mode on. (Alternatively, a builder could photograph “instructions” to participate in this battle). Then, we will build some of these models for the battles. This is what you have to do: Create a separate thread for your weapon of war, then link it in a post on the registry thread. The title tag for the LDD contest is {WotB} In your thread you should have a completed picture of the siege weapon. You should have the capability to email us the design or “print” it. (Links to this material in your thread are highly appreciated!) You can add story to your weapon (maybe what company / person built it, etc…) You can also tell us what side you hope will use your weapon (Petera or Dugal’s). Is it a one of a kind weapon that has special properties? Or could there be multiple on the battle field? There are two categories, and each builder can enter both up to three times. The first category is Field Pieces. These will be used at the Battle of the Wither Woods. This battle will most likely take place in a lightly wooded area, but overall very few fortifications will be present on the field. The weapons can range from catapult to ballista, from twirling death machine to cow crusher… the limits are endless, other than it really should not be a siege engine. The second category is Siege Engines. These should be the heavy duty battle machines that are designed to take down walls, assault fortresses, and get men in close to fight the enemy. The siege engines will be used later on in the year at the Battle for Eastgate. One caveat -- the portion of the battle portrayed at the end of summer will be an invasion from the sea... So, any siege weapons that fold up nicely, may have the upper hand in the judging. (MAY HAVE) Specifications: Since we are going to try and build these, we are going to set a 400 piece limit. You don’t have to use 400 pieces, you can use fewer. We just won’t be able to build anything larger than 400 pieces. The one thing I do not have in my collection is a lot of technic gears and pieces, staying away from these would increase the chances of seeing your weapon in built form during the battle. However, containing many technic pieces won’t hurt your chance of winning. Just like the call to arms, anybody in the Guilds of Historica can participate. Deadline: Field Pieces: May 15th Siege Engines: September 30th The winner of each category will be forever known as Artillery Captain of Eastgate or Siege Commander of Eastgate
- 318 replies
- LDD
- Call to Arms
- (and 7 more)
