Showing results for tags 'Bristol CHannel'.
Here is “Bumblebee”, a Bristol Channel style pilot cutter. She is based on no one vessel in particular but is more of an interpretation of the type from many sources. Some parts of her make up may seem a bit dubious to the trained eye, but such is the limitation of this scale. I started this one with the intent of entering it in BoBS. Though it may sound a touch arrogant (it’s really not) my motivation came from a general disappointment in what I had so far seen in terms of BoBS ship building. I saw few risk taken and little done in the way of trying something new. I thought to foster some more of that by presenting this as something to be one-upped. After all, isn’t the game supposed to be about growing as a builder, not just grabbing at points (or did I miss something?). In the end I find the learning curve of the game far too steep for someone who’s never been a role player. I also went over budget and would still need to apply sails. I had figured on 12 hours total for the whole build, but at 14 had only got this far. It’s not a new concept, I’ve theorized it on other threads before and even had a mock up on my desk for a while. It is the first practical application I’ve done though. Where it stands, I wouldn’t find this technique on such a small scale useful for anything but late period/modern boats. I simply couldn’t get the curvature any tighter as to make the bow any buffer, nor could I reliably twist the sides to mimic tumblehome either. The rigging is a marginal success partially because I cut a lot of corners but also because, had forgone internal support in favor of good sportsmanship for BoBS. My other ships are aided by having dowels in their masts and spars to add stiffness. This one is all Lego aside from the string, so too much tension has the opposite effect. It all has to be just right otherwise it’s prone to collapse. Only the one side is actually photogenic. The starboard side is still just mocked up from cast-offs and knock-offs as I only ever intended to show the larboard side for the game. It’s from one of these evil imitations that she draws her quirky name though. A sticker still stuck to one of the bricks bears the name of a particular transformer. I felt she was telling me her own name since the placement wasn’t conscious or intentional, thus “Bumblebee”. I think it works and besides; its bad luck the change the name of a ship. Tough she’s not quite finished I’ll still issue the challenge to anyone interested in rising to it. If I can do this in 14 hours what can you do?
- 25 replies
- pilot cutter
- Bristol CHannel
(and 3 more)
Tagged with:
