Showing results for tags 'Crawler Crane'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 3 results
  1. Hello fellow Eurobrickers, I would like to present my possible TC8 entry and WIP of a Liebherr LR 1300. Link to reference image (Way too large for eurobricks); http://c-bceasncc.la....d6hxJTXEZS.jpg Functions so far; Motorized through a distribution gearbox, 5 winches Slewing Drive (hopefully through a subtractor) Manual, Cabin rotation from transport mode to operating mode. Pneumatic cabin elevation. On the to do list, Complete opposite side and counterweight area. Design main and rear booms, and luffing jib. Build base and crawlers, while hopefully maintaining the ability to separate crawlers from chassis. Build wheeled super-lift. Any advice is greatly appreciated. Thanks, ~John P.S. Please excuse any typos/incorrect words, I am completely exhausted from work today.
  2. Hey All, Here is my new MOC based off of the Liebherr 1750 LR Crawler Crane. I won't rehash all the details, you can find all the details on my mocpages @ http://www.moc-pages.com/moc.php/425498. It is a little bit of a read but hopefully worth it. Really fun build..... here are pics and videos.
  3. Rottermannen / tv2mustdie posted this of his fully-functional Lego Technic Crawler Crane which can lift 4 kg (8.8 lbs.) at 50 studs distance -- "4 kg (7 x 3.5" Hard disks) at 50 studs radius. Slewing and crawlers working. 5.2 kg ballast + 1.8 kg central ballast." It can lift 7 kg (15.4 lbs.) at a closer distance. His Flickr photoset has 13 pictures with descriptions of how his various load tests developed over time. He description of his MOC: "LEGO Technic Lattice Boom Crawler Crane Lattice boom crawler crane with 9 kg lift capacity made from LEGO Technic. max. lifting capacity 9 kg at 200 mm (25 studs) max. load moment 18 Nm Main boom 432 to 1152 mm (54 to 144 studs) Lattice jib 420 to 1120 mm (60 to 140 studs) Crane weight (base + superstructure) 2.7 kg Central ballast 1.8 kg Superstructure ballast 6.2 kg The superstructure is mounted to the base through a turntable powered by 1 small power functions electric motor enabling slewing under full load. The superstructure is equipped with 4 winches and 6.2 kg of counterweight. The base is equipped with 1.8 kg of ballast and crawlers powered by 2 small power functions electric motors enabling the crane to move with full load. The lattice boom consists of 2 to 5 sections (54 to 144 studs length) and is connected to an A-frame which is raised and lowered by 2 times 12 falls powered by 2 winches each with 1 large power functions electric motors. The hook is lifted with 2 times 12 falls powered by 2 winches each with large power functions electric motors. T he jib is raised and lowered by 1 winch with 1 small power functions electric motor (12 falls) and the jib hook is lifted with 8 falls powered by 1 winch with 1 small power functions electric motor. Non lego parts: 2 axial steel roller bearings are fitted to the turntable to allow slewing with max load moment. The crane will have similar load capacity without them but slewing will not be possible. 1 mm braided ropes are used on all winches."
