The Elf Battle Chariot - gift to the Forest Elves from their High born cousins - designed to both transport important leaders speedily across the battlefield and to add a bit more punch to their light cavalry. Often encountered when they are found fighting outside of the forests, it is very much the centre piece of their army and a rallying point for their kin. No Elven battle force of note is ever found without at least one in their ranks. And rumour has it that some of the more noble born elves are even using the same chariot frame to be pulled into battle by a mythical white lion!
What it looks like at home - High Elf Chariot with pure thoroughbreds and dark green caparisons, crewed by Wood Elves and a High Elf Envoy
Above and below show example of range of movement and articulation. Chariot pivots 180 degrees around horizontal (ie: hard left and hard right turns) as well as horses can rear up as well.
If any of this takes your fancy in any way I would be grateful for your support at: https://ideas.lego.com/projects/128555
Yes I know I only had the orc war boar approved the other day but I had no idea this one would be accepted in around 12 hours! (Especially since my first 3 projects were rejected)
Much love
D
