Showing results for tags 'Lady Anne'.
Hi, in June 2014 I designed a 16mm Scale Lego Steam Locomotive which was based on the Roundhouse Engineering Lady Anne Live Steam Locomotive, the 16mm Scale Lady Anne Locomotive was designed to the same scale of the Roundhouse Engineering Lady Anne and was designed to run on 32mm Track (Peco SM32 Track), since I did the original post the model has been improved with more details being added. The 16mm Scale Lego Lady Anne is powered by Lego Power Function XL Motor and the same gearing found in the Lego Emerald Night with both the receiver and battery box under the saddle tanks. The two photos below were taken last year before the Lego Model was improved (the date on the camera had been set wrong). The photos below were taken in early June after the 16mm Scale Lego 4 Wheel Coach was built. Below is the Roundhouse Engineering Lady Anne Live Steam Locomotive which my 16mm Scale Lego Lady Anne Narrow Gauge Steam Locomotive was based on. Below is a couple of photos showing my 16mm Scale Lego Lady Anne Narrow Gauge Steam Locomotive pulling the 16mm Scale Lego 4 Wheel Coach along the Peco SM32 track. The Black buffers are made by Brandbright, A online shop which cater for the 16mm scale. I am planning to improve the look of the exterior of the model so it looks more like the Roundhouse Engineering Live Steam Lady Anne, this will be done next year and replace the single Lego Power Functions XL Motor with two L Motors which will be place in the boiler of the locomotive. I move the spectacle windows, so they are over the front coal bunkers, moved the dome and added the safety value and put the steam whistle on the roof of the cab, I still need to redesign the cab interior,
- 7 replies
- Lego Trains
- 16mm Scale Lego Trains
- (and 5 more)
