Showing results for tags 'Lego Steam Locomotive'.
Hello Train AFOLS I am working on a new Lego Steam Locomotive in LDD. The Lego Steam Locomotive is based on the sole survivor of the SECR Class O1 Steam Locomotive - the SECR Class O1 No. 65 Steam Locomotive which is preserved at the Bluebell. My version will be a another SECR Class O1 Steam Locomotive - the SECR Class O1 No. 372 Steam Locomotive which used to run on the East Kent Light Railway between 1923 and 1949 which in 1949 was scrapped The Lego SECR Class No. 372 Steam Locomotive is still a work in progress, I hope to build it physically next spring once I have worked out how to motorize the tender. A couple of updates to the design. The first is I have done some more work on the Locomotive. the dome and chimney are now taller then the roof of the cab. The second update is I have worked how to motorize the tender, I have decided to use two Lego Power Function L Motor in the tender, each L Motor will drive a single axle. I now have to build the rest of the tender chassis and the build the tender body and add the skirting around the wheels. A small update to the tender, the leaf springs have been added to the tender.
- 6 replies
- Lego Trains
- Lego Steam Locomotive
(and 2 more)
Tagged with:
Just after my birthday las March 2013, I decided to buy the Lego Emerald Night Steam Locomotive Set as a late birthday present, but as the prices for the set were over £150 on Bricklink, I decided to buy the instructions for the Emerald Night Steam Locomotive instructions from Bricklink and build the model in LDD 4, Once I had build the locomotive in LDD 4, I decided to redesign the model in LDD to make it more like the LNER Flying Scotsman Steam Locomotive, and buy the parts I would need to build a physical model from Bricklink, including Shipping and packaging, the cost was 92.46, a week later after i had placed my orders in Bricklink, the parts arrived and I started to build the model. Below are some photos I have taken recently of my Lego LNER Flying Scotsman model, the front lights work, but the rear lights are just dummy lights, the model is 18 inches long,8 studs wide, 3.5 inches high, and has just over 900 bricks in the model. A nearly a year since I built the Lego Flying Scotsman model. I am now planning to rebuild the model with Big Ben Brick XL Wheels and custom coupling rods and finishing touches like the running number, LNER by using O Gauge Lining and lettering decals.
- 5 replies
- Lego Trtains
- Lego Steam Trains
- (and 4 more)
A Custom Lego Freelance 0-4-0 Steam Locomotive with firebox and cab controls inside the cab,The model is designed to fit a Lego 9 Volt Train Motor, the model is 21 studs long and 8 studs wide Couple of Images showing the insides of the 0-4-0 Freelance Steam Locomotive cab showing the firebox open closed and open and the cab controls with lever, dials, and wheels ( 2 x Lego 1x1 Round Tile) Three images showing how the Lego 0-4-0 Freelance Steam Locomotive Body fits to the Lego 9 Volt Train Motor, the purple parts are where the body connects to the train motor Modified Lego 0-4-0 Freelance steam Locomotive into a Lego 0-4-2 Freelance Steam Locomotive to include a coal bunker
- 8 replies
- 9 Volt Trains
(and 1 more)
Tagged with:
Hi, in June 2014 I designed a 16mm Scale Lego Steam Locomotive which was based on the Roundhouse Engineering Lady Anne Live Steam Locomotive, the 16mm Scale Lady Anne Locomotive was designed to the same scale of the Roundhouse Engineering Lady Anne and was designed to run on 32mm Track (Peco SM32 Track), since I did the original post the model has been improved with more details being added. The 16mm Scale Lego Lady Anne is powered by Lego Power Function XL Motor and the same gearing found in the Lego Emerald Night with both the receiver and battery box under the saddle tanks. The two photos below were taken last year before the Lego Model was improved (the date on the camera had been set wrong). The photos below were taken in early June after the 16mm Scale Lego 4 Wheel Coach was built. Below is the Roundhouse Engineering Lady Anne Live Steam Locomotive which my 16mm Scale Lego Lady Anne Narrow Gauge Steam Locomotive was based on. Below is a couple of photos showing my 16mm Scale Lego Lady Anne Narrow Gauge Steam Locomotive pulling the 16mm Scale Lego 4 Wheel Coach along the Peco SM32 track. The Black buffers are made by Brandbright, A online shop which cater for the 16mm scale. I am planning to improve the look of the exterior of the model so it looks more like the Roundhouse Engineering Live Steam Lady Anne, this will be done next year and replace the single Lego Power Functions XL Motor with two L Motors which will be place in the boiler of the locomotive. I move the spectacle windows, so they are over the front coal bunkers, moved the dome and added the safety value and put the steam whistle on the roof of the cab, I still need to redesign the cab interior,
- 7 replies
- Lego Trains
- 16mm Scale Lego Trains
- (and 5 more)
