Showing results for tags 'Minifigure-scale'.
The Head - No, it is not the understated as just another AT-AT, because it won’t be, but for the matter of this topic, it is, momentarily, just a head. Though merely a head, it makes a rather astonishing display piece by itself. Aside from the towering height and lumbering movement of this terrifying machine, the head is quite formidable in appearance, resembling that of a fearsome beast. - In the course to build my original creation of the greatly revered imperial walker of the grand army of the empire, I amass a wealth of reference material concerning studio models, replicas, on-screen images, artwork, etc., to meticulously build the perfect LEGO incarnation that is indubitably authentic to the movies. I have been building this minifigure-scale AT-AT for quite some time—I recall since 2012 with the start of the body section. However, as of recently, since early 2015, I have built the head for this admirable tool of destruction. - Furthermore recently, I have been constructing the infrastructure of the body, acquiring additional parts & correct colors, making considerable amount of alterations, but I have postponed most of this to venture off and design my original minifigure-scale T-47 Airspeeder (Snowspeeder) in LDD, which turned out into a successful MOC and will be a great companion. I planned after that to resume progress with the AT-AT, but after I was inspired by anothergol’s innovative use of paint rollers and mudguards for the waist of his articulated AT-ST, I was just motivated to jump ahead and create my own creation of the imposing “chicken walker” beforehand. Mine, which will implement those techniques of his that I mentioned early, but also the 5 x 5 Scala dish. Interestingly, my own creation first turned out MF-scale, then evolved into UCS scale, then separated into two projects: a MF-scale and UCS scale! A considerable amount of progress has been completed on both projects, with the MF-scale almost finished and the UCS scale having feet and the waist finished. However, for concern of the UCS model, I have postponed its progress to focus on the MF-scele—to complete that and finally resume progress with the MF-scale AT-AT walker. - Regarding this MOC of the AT-AT head, you should notice that I deliberately took some liberty in the greebling located at the bottom. This was a compromise due to the thickness of some elements and from the lack of elements that could properly represent those tiny details, in this scale, authentically. I was as well tight on space for building the main cannons. I originally wanted to attribute a sliding action to them, as if they were in action, but this was unfortunately omitted due to a number of things, which includes: space, structure, scale, parts, etc., which also brought them closer together than intended. Along with other things, like the lack of other small details on the face and others things, that is practically as far as inaccuracies go for it. Nevertheless, one extra detail I have included, which I have not seen previously before represented, are the light fixtures atop the medium support blasters mounted on the cheeks. Then among other characteristics, I can grasp the head by the neck and jerk it around without any parts coming undone, with exception to the roof because it is not fixed together (kinda like other @@ heads I know of ). That rigid likability is attributed to the infrastructure constructed exclusively with Technic & modified plates (w) Technic elements, which also clutches the sides securely in place and almost seamlessly with other aspects. For this fact of such a packed, robust, complex infrastructure, there is no interior, likewise for the whole body—I never had intentions to include such luxuries anyway, but I congratulate those who did. - To determine the dimensions of a MF-scale AT-AT walker, I first acquired theorized dimensions of the actual walker from an in depth survey of its structural components, capabilities, practical role, and tactical uses: here. Wookieepedia is informative in some areas, but it claims the walker is taller than it is longer, which it is clearly not. Besides the overall dimension of the walker’s height and length, this technical commentary also provides a reasonable measurement of its width, diameter of the footpads, and other aspects like the height of boarding hatch. I also found this useful: here. To find the MF-scale, it took some little conversion of average human being height, minifigure height, dividing, multiplying, then more multiplying, but it came out to be around 20in/50cm. Some time on, I took the actual height of my model from toe to the main section of the body and acquired the measurements around 21in/53.34cm, then rework some steps back to get the plausible measurements of 85ft/26m. For the footpads, each are 12 studs in diameter and its height a few measures above a minifigure's chin. So the model is rather on scale for minifigures’ height, as well other aspects in general scaling, as according to the probable height of an actual AT-AT walker. - If there is any misconception about the visor of the command viewport being transparent red, I have some valid reasons to put those to rest. At first, if you notice the moment when five imperial walkers are advancing towards echo base, only the lead walker exhibits a red visor. During the scene, where General Maximilian Veers oversees the battlefield through the viewport the visor is transparent clear. Logically, if the visor was transparent red it could not beam as so bright as it did in a cloudy, snow filled day—not even in a sunny day. Though it appears black this is due to the overcasting shadow from the outside portion of the viewport. Therefore, the red lighting is believably a system for operations in low light periods or environments, to preserve the crews vision in these circumstances, while still being able to function about in the walker. - Well, if you are still reading, I am done for expressing this MOC, for I believe I have covered everything concerning the model and relating to it that was on my mind to say. So, you can finally enjoy the photos and express your own thoughts, criticisms, questions, etc. below. However, bear in mind that I will not be giving out any form of direction that will describe or depict how it is built—I appreciate that this is understood in advance of your comments. Much appreciated, LiLmeFromDaFuture
