Showing results for tags 'Movie Poster'.
Hi everyone! I just wanted to share with you my latest MOC and one that has been a real passion-project for me. I'm a huge movie fan and Jaws is probably the film that I love the most. So creating a Jaws MOC is something that I've been thinking about for quite a while. The poster measures approximately 15.75" (40cm) tall, 13.5" (34cm) wide and 5.25" (13.5cm) deep. I estimate the finished model is likely to be in the 3300 – 4000 parts range. It took about eight hours to put it all together and about 20 hours to design in LDD. The water effect is achieved by pouring 1x1 round transparent clear plates in between a solid brick wall and a wall made up of Transparent-Clear panels. The gap between the back wall and the Trans-Clear plates is a single stud. The gap on the left and right is four studs wide. A view from the side where you can see how it sits inside the black 'box' A view from the other side. Dinner time? You can view the full set on Flickr at THIS link UPDATE I have made a couple of tweaks to this piece. The first was a minor change to the top of the 'W' in 'JAWS'. I had capped it off with two 2x2 red tiles but they did not go all the way to the edges, so I replaced the 2x2s with two 1x3s and this makes the 'W' look better. The second modification was more significant and is based on some feedback I received below from Clone OPatra. I was never truly happy with how the shark's nose jutted out over his top lip. To solve this, I made the shark's head one brick wider but kept the nose where it was. This leads to a smoother transition from lip to nose. Finally, whilst I had the camera out, I took the top off to allow for a 'cross-section' view, showing how the various 3D elements look when viewed from above.
- 21 replies
- MOC
- Movie Poster
- (and 4 more)
