Showing results for tags 'New sets'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 3 results
  1. I went down to my local Lego store to buy the new Halloween seasonal set, and they had the 2015 Advent Calendar sets on the shelves already. I picked up 2 for gifts later this year...just a heads up if you are interested in getting them. BTW, the Halloween set was already cleared out on the shelf, I got them to bring me out one from the back room though...get them while they're hot! LOL
  2. I was at my Lego store today, and got another print copy of the February 2015 calendar. It shows for 17-28 February, for VIP's, early access for a new Lego exclusive set. I usually see a lot of ideas or rumors on these events, but haven't seen any yet here. Or maybe I have missed something? Does anyone have any ideas on what the new set is going to be? I would love to know!
  3. Okay, this is something different. If anyone remembers, 42000 was leaked on Ebay a couple of months before the set was actually released. Well, something similar has happened. I was browsing on Ebay earlier today, and I came across an auction for a lot of Lego Technic vehicles that the seller claimed to be prototypes for the 2017 lineup. This is given credence due to the fact that pretty much every model had some parts in colors that are not currently available, or have new pieces. At this point in time, it is unknown how this fellow got his hands on them, whether they were stolen, or sent to him by mistake. I downloaded the pictures, because the auction was taken down not 10 minutes after I checked it out. My phone is out of batteries, and is not really useable while charging, so I can't upload pictures quite yet, so for now, have some descriptions. The auction consisted of four vehicles, which I will detail below. #1, Forklift. The first vehicle was a forklift, maybe a little bit bigger than the one Mahjqa recently posted, but the machine is yellow, and all functions appear to be manual. The lifting of the forks seems to be done by using the 1x11 pneumatic cylinders, but on this model the cylinders are black, and not yellow. There also appears to be a pneumatic tank piece on the back, standing in for a propane tank. I can't tell if this is a new piece or not, it does appear to be a bit smaller than the old tank, and appears to be light bluish gray. There is also a black pump beside the tank, probably the same one used on 42053. Also in the picture was a pallet made out of tan plates, with some kind of brick built equipment on top. Functions are unknown for sure, but it has at least 3 valves, so it has to have at least steering, fork raising, and fork tilt. The second model is much, much larger, being a six wheeled motor grader, again in yellow. It is a medium set, but the cab is small, indicating it is meant to be large. There is a mix of black and yellow pneumatic cylinders, and the blade appears to be made out of some kind of new curved part, like the 3x11 curved panel, but like 4 or 5 studs wide. The tires also appear to be new, like the tires on the Unimog, but smaller.There also appears to be a PF battery box on the back, just ahead of where the engine would be, so there is probably a motorized compressor in there somewhere. There is also a large number of valves, at least three on each side, so there are therefore at least six functions. There also appear to be two knobs on the cab, possibly for front axle and articulated steering. The third model is... Well, I'm not quite sure what it is. It appears to be some kind of spaceplane, given that it what appear to be rocket boosters, although it does not resemble any current spacecraft. What we probably have here is something like 42038, where the set looks plausible, but ultimately is a nonesuch. The set is almost but not quite like a B-1 Lancer,, with a long nose, and swept wings. At the rear are three engines, which are side by side in a row, and above them a split tail. I'm not sure if the engine bell nozzles are new parts or not, but they appear to be new. The model is black and white, and is the only one out of the lot with any stickers, which look rather crude. Under the cockpit is "Orion", and under the tail fin "42067", which we can presume is the set's number. There appear to be new parts that act as the payload bay doors, although sadly the seller did not open them. As for functions, there are two yellow levers on either side, just behind the cockpit, function unknown, as well as a bevel gear on each side, which might connect to a switch. Just in front of the tail is a joystick, similar to 42025, with another yellow lever ahead of that, which might control the rudder. The set appears to be roughly on the level of 42025, but may have some pneumatic functions, as there are some hoses protruding out the underside. All of these models had some weird areas that looked like they came apart due to rough handling. In addition, this set has the new L shaped panels in white, just behind the cockpit. As well, the model has some new panels in the nose, of uncertain dimensions. The final model was by far the biggest, and is the only one that I can definitively identify, a Gottwald AK-912 crane. It has ten axles, using the wheels of 42009, and is quite big. It had no stickers, but was in the yellow and black colors of Shcmidbauer, one of the companies that operated the real crane. Unfortunately, the seller did not know how to put the model together, so the lattice boom and the outriggers were set to the side. The lattice booms appear to use some kind of new part, a beam with holes offset 90 degrees from each other, to make the sides and allow the diagonal beams to connect. Those parts appeared to be rather rough, possible 3D printed? This model was the only one to be flipped on its side, allowing the underside to be seen. It had 4 differentials on it, allowing an accurate number of wheels to be driven, but oddly, the wheel hubs appear to be new, almost but not quite like the 42000 hubs. Those parts appeared to be 3D printed as well, but the actual shape is kind of hard to discern. This model, unlike the rest, has no pneumatics, but there is definitely a PF battery box in the superstructure, just ahead of the first winch. The outriggers are interesting, as they use mini linear actuators, and it seems that at the base of the outrigger is some kind of spline piece to connect to the main truck. Well, that's all for now, let's hope my phone charges, so that I can give you some pictures. In case you haven't guessed by now, April Fools!!!!
