Showing results for tags 'T-65'.
Hello everyone!!. So i´ve been an X-Wing fanatic since i was 5. And when i got my 9493 about 3 years ago i was pretty happy,but since i bought it something felt wrong. I started doing Mods when we first saw 75102,one mod lead to another and well here it is thus far. I did Luke´s X-Wing since his color scheme it´s my favorite,also some mods are not my ideas i took a lot of inspiration from marchetti36´s X-Wing so credit to him.I won´t use this background since i don´t like it,i´ll take proper photos when it´s finished. So most of what i´ve done are color changes(some of the pieces here are temporary,and will be changed) and some other one´s for example it has the structural changes to use 75102 Windshield. This color scheme is based after several models that seem accurate to the Movie-Prop.Unfortunally i wasn´t abble to brick-built the gray line next to the Tan marks,if i found a way to use bricks there i´ll use that but for now it´s painted :/ The cocpit has been modified to look a bit more accurate,it has more controls & a control stick,also has storage for the lightsaber hilt. The back was one of the ugliest parts IMO so i cover the Technic holes(in a pretty cheap way) and made the back of the main body accurate,The mechanism is fully functional. The R2 unit now sits horizontally !! Also re-did the greeble( i didn´t knew you could fit a stud beetween two hinge bricks). That´s the reference photo i used for the greeble. Here´s a Break-down of how i did the greeble for those of you that want to built it. And i added an UCS style stand. Hope you like the MOD´s so far,i´ll be updating this topic everytime i do some progress so stay tuned. If you have any suggestion i´ll be happy to hear it. Regards. -Prime.
Hello everyone here´s a project that took a while but it´s finally here´s Luke´s personal X-Wing based after the 9493 set As you can see a lot has changed since it was 9493, i tried to get the most accurate color scheme to Luke´s Red Five, i couldn´t make all the details on this scale so i had to paint the blue lines on the blasters & the gray line next to the tan one on the nose. Some of the most hevy MODs are located on the cockpit so let´s go there This is how all started i wanted to get a nicer cockpit so i did a nicer looking seat,a place to hold the light saber and some other controls. One of the sections i´m the most proud of is this,one of the things that always bother me on 9493 was that R2-D2 was in a vertical position instead of a horizontal one so i changed that and i heavely moded the greebles to be more accurate over all. Here´s a look on the back, it looks way nicer and accurate IMO (i originally had a Technic disk instead of that black nob but it was really hard to lock the S-Foils so i used the black nob instead) Here´s a look at the other side as the color scheme changes. I also added an UCS style base for display Here´s the X-Wing on all it´s glory. Thanks for taking the time for reading this i hope you like this thing as much as i do. I´ll also be happy to answer any questions you may have. Hope you have a fantastic day !! -Prime
I set out to create a more screen-accurate minifigure scaled X-Wing, and this is my result. The model is built to accept the canopy used in the new Poe's X-Wing Fighter set (75102), but it is not yet available to use in LDD so I created a stand-in for now. I am collecting the pieces to build the model, which is 1471 elements total. It features a geared S-Foil wing system controlled by the wheel on the back, opening canopy, and positionable landing gear with doors. Please visit my Mocpages to see more of my work. Comments/feedback appreciated!
- 15 replies
- Star Wars
- Incom T-65B
(and 3 more)
Tagged with:
Hello everyone. After a long time I have returned with a “new” MOC. The idea came some years ago, when I noticed the several inaccuracies in the official X-wing models. I already had the first two sets, but at some point I realized that the official models have enough inaccuracies to justify upcoming re-releases. So I started to think how a proper LEGO X-wing should be for me. I began with a simple LDD file which I showed two years ago here in EuroBricks. But after that I noticed my model was really unstable, so I decide to redesign the entire MOC until I was happy with it. And was very hard to be happy with the WIP, because that redesign took me a lot of time, and the final result has almost nothing in common with that first .lxf file. After delaying more than two years, that amount of time even looks wasted if you take in consideration that I still have the official versions. And the MOC is nothing new due the high number of great T-65 MOCs around the internet. Here are the pictures: -The cockpit can be opened and you can sit a minifg inside. There is also a targeting computer adapted for minifigs. -The S-foils can be opened manually like the first LEGO X-wing. -The landing gear can be retracted from the nose and the wings, like the “real” one. -The cargo bay door can be opened, although there’s no so much space inside. Thanks for your time, I hope you like it. As always, every comment is welcome. Gallery: Version 1.0 (2010) Version 2.0 (2012)
