Showing results for tags 'Western Star'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 3 results
  1. My latest release, a rerelease and rebuild of a three axle detachable gooseneck lowboy trailer with liftable third axle. The truck that goes with it is worked on right now! Will be released March 2015. Not yet had the change to work on a new video, but one will be available soon. So for now I use the first edition video of this model. Model "Trailer Tr4 MkII” is build with LEGO® in scale 1:17,5 and motorized using LEGO® Power Functions. It is not build after a specific brand or type of trailer. This build represents a three axle detachable gooseneck lowboy trailer with liftable third axle. The trailer features: solid axle suspension on all axles, one set of lights, kingpin, mechanical parking break, gooseneck frame support, remotely controlled liftable third axle, remotely lowering and lifting of the deck and this model has many details. This newly design and engineered trailer utilizes the same suspension as both "US Truck T1 MkII" and "US Truck T2 MkII". It uses LEGO® rubber belts and LEGO® rubber axle connectors. Designing and engineering this trailer parts availability is checked. So it can easily be build in the color as it is, Yellow, but it can also be build in Red, Blue and Black. Attention!!!: Both "US Truck T1 MkII" and "US Truck T2 MkII" needs to be adapted to be combined with "Trailer Tr4 MkII”!!! Else could be used a so called dolly which acts as a convert to fit the trailer. For this dolly building instructions will be available soon. Attention!!!: LEGO® Technic set 8258 Crane Truck needs to be adapted and requires a modified gooseneck!!! Instructions for "Trailer Tr4 MkII” to go with LEGO® Technic set 8258 Crane Truck will be available soon! This model is another custom design by Ingmar Spijkhoven AKA 2LegoOrNot2Lego that comes with building instructions and inventory/parts list!. So, you can build it yourself! To do so you can buy the Building Instructions. Early in the building process you will see what it is that you are building. You will be very excited from the moment you start the build of "Trailer Tr4 MkII" till you finish it with a total number of parts of about 1450 pieces. With this type of lowboy trailer the gooseneck is removed to make the deck accessible. Because the front part of the trailer rests on the surface the truck with the gooseneck still attached can drive off. In order to keep the gooseneck elevated at the correct hight is as a support. This support rests on the trucks frame. The ramps can be lowered and any self propelled load can enter the trailers deck. With the trailer loaded and the load secured the gooseneck can be reattached. This is done by backing up the truck aligned with the trailer. With a support that rests on the trucks frame the gooseneck can be lowered of lifted to make sure it comes in place. Finally the deck can be lifted again and the gooseneck can be locked so it doesn’t go anywhere without the trailer itself. Cheers, Ingmar Spijkhoven
  2. Building trucks and trailers and occasionally earth moving equipment I switched a little. Not to boats or minifig scale or what so ever, no I build a race truck. My dark ages ended by an attempt to build a model equal to those available by Tamyia. Yeah, I know, this might sound weird, but at that moment I didn't have any clue. So I installed 4 RC Buggy motors in a single none steered 4x4 vehicle. Obviously all build with LEGO® parts, so don't be confused. All four RC Buggy motors hooked up to a single RC Race Buggy Battery / Receiver Unit, and that went totally wrong. First I had no longer forward motion and after a while no reverse either. Yes I burned out that Receiver unit. Never did I realize a single stalled RC Buggy motor requires 3A times 4 means 12A. Probably this exceeds the limits of the RC Buggy Receiver Unit. This I just share to give you an idea why I am interested in this RC Buggy electronics. I entirely let go of the idea I could build a LEGO® model as strong and fast as for example the Tamyia Wild Willy I had for many years. This "real" RC I bought with my saving money at the age of 12. Alright, now back to this model. It all started with an idea of building a race truck about two or maybe even three years ago. The initial design was supposed to be more "funny" then a serious model. In time this approach changed and I really looked into racing trucks. There are so many nice LEGO® build race truck models out there I had to compete :-) Model "Truck T10" is build with LEGO® in scale 1:17,5 and is motorized using RC Racer Buggy components. It is not build after a specific brand or type of truck. This build represents an imaginary race truck which is strongly inspired by Mike Ryan's "Banks Freightliner Super Turbo Pikes Peak Truck". Another custom design that comes with building instructions and inventory/parts list! Features: independent front suspension, drag axle rear suspension, propulsion by two RC Racer Buggy motors, remotely controlled driving and steering, openable doors, openable hood, modeled engine and cabin interior. This model is meant to be an appetizer for those who already own one of these original LEGO® sets: 8366, 8367 or 8475. For this model/project both the RC Race Buggy Battery / Receiver Unit and a truck design are combined. Basically the rear chassis consists out of two RC Race Buggy motors, a frame that holds them together. This frame also holds a wheely bar and the spoiler with its support structure. The front axle suspension is a double acting system with a mixture of the suspension parts used in sets 8466 en 8297 with a total of four soft shock absorbers. This model's detailed engine is based on Mike Ryan's Super-Turbo engine setup which is built around a 14.0L Detroit Diesel Series DD60 six cylinder inline semi truck engine. Introduced in 2001 this 14 liter (854 cu in) engine has a power output up to 575 hp and a maximum torque of 1,850. These numbers where not enough to label it as a race truck, so it had to be souped up and that is where Banks Power came in. Cheers, Ingmar Spijkhoven
  3. My latest release, a log trailer with three axles of which the last one is liftable. It comes in two color schemes to match both "US Truck T1 MkII" and "US Truck T2 MkII". Model "Trailer Tr3 MkII” is build with LEGO® in scale 1:17,5 and motorized using LEGO® Power Functions. It is not build after a specific brand or type of trailer. This build represents a three axle log trailer with liftable third axle. The trailer features: solid axle suspension on all axles, one set of lights, kingpin, remotely controlled landing gear and parking break, remotely controlled liftable third axle that simultaneously extends or retracts the rear impact guard and this model has many details. This newly designed and engineered trailer utilizes the same suspension as US Truck T2 MkII which uses LEGO® rubber belts and LEGO® rubber axle connectors. This model is another custom design by Ingmar Spijkhoven AKA 2LegoOrNot2Lego that comes with building instructions and inventory/parts list! You can build it yourself! To do so you can buy the Building Instructions. Early in the building process you will see what it is that you are building. You will be very excited from the moment you start the build of "Trailer Tr3 MkII" till you finish it with a total number of parts of about 1000 pieces. Simultaneously with lifting the third axle the rear impact guard is retracted. So with the third axle down the rear impact guard is fully extended, this to increase safety when hauling loads. Unloaded the total length of the combination is reduced with the third axle lifted and the rear impact guard in. As with most log trailers this model has so called bolsters or bunks. Those are the U shaped frames on top of the trailers chassis. Bolsters are obviously necessary to keep the logs in place. Even though the bolsters on this specific model are fixed they can easily be re-located if wanted. The number of six can also be altered to your own needs. Give this trailer the setup you want it to have. Cheers, Ingmar Spijkhoven
