Showing results for tags 'a_c'.
This MOD upgrades your CAT D11 as below: - increase the blade lifting speed by 67% (the Control+ app needs to be calibrated after this MOD) - close the gaps near the front panels - make the front linear actuators look stronger - replace the rear fake linear actuators with a real one; they can be controlled manually to tilt the ripper - add 2 fire extinguishers near the cabin 115 extra parts are needed. The most expensive parts are the 2 black linear actuators (43097). Replace them with the LBG one (61927b) is fine. Or just like me, sprayed the LBG one with semi-gloss black. Instruction available at https://rebrickable.com/mocs/MOC-91485 Enjoy and have fun!
LEGO did a great job in re-releasing R2-D2 as 75308, but there are still some parts not the same as the real one. So I've made the followings: - changed the outlook of the leg's fuel cells - flushed the third leg outlet panels (front and rear) by 1 plate - completed third leg outlet panels by adding the left and right sides - switched the position of the buttons and pillars of the legs (same as the 2012 version) - changed the outlook of the middle exhaust vents - moved the tools compartments further outward and made it taller - filled the gap between the head and the body - more SNOT outlook - push-to-open the lightsaber cover 195 extra pieces are required. Spare parts are also needed, about 80 original pieces will be left. Instruction available at https://rebrickable.com/mocs/MOC-85457 Happy building. Have fun and enjoy!
This is a compact RC Forklift. It's inspired by a China made Forklift set. It's a HOG set. I've changed all the functions to be remotely controlled, and improved the outlook. Features: - Total no. of pieces is less than 700 - Around 1/16 to 1/17 scale - FWD - Requires a SBrick or BuWizz 1.0/2.0 or CaDA or Mould King remote battery hub - PF Servo Motor for the steering - PF L Motor for the front driving - PF L Motor for the lifting - PF M Motor for the tilting - Gear ratio is 2.33 : 1 - Maximum lift loading is about 300g - Maximum lift height is about 16.5cm - Detailed cockpit and driver seat Any feedback is welcome. Instruction available at: https://rebrickable.com/mocs/MOC-78013/
As inspired by pg5200's Buggy and Tamiya's Fighting Buggy, I've built this RC Buggy MOC. It's simple, fast and stable. Features: - Total no. of pieces is less than 400 - Around 1/15 to 1/16 scale - Requires a BuWizz 1.0/2.0 or CaDA or Mould King remote battery hub (SBrick should be possible by placing the hub on top of the battery box) - PF Servo Motor for the steering - RC Buggy Motor or BuWizz Motor for the rear driving - Gear ratio is 1.4 : 1 - Transverse damper rear suspension similar to Fighting Buggy - Rear camber angle is about +1 degree - Optional 4 LED lights (instruction not included) Instruction available at https://rebrickable.com/mocs/MOC-76795/ Have fun and enjoy! It's not in Minifig scale, just give you an idea of its size. It has a +1 degree of rear camber angle.
Hi, it's my long time project. It's heavily based on the famous Plus-Size AT-AT by raskolnikov. I've changed mainly the outlook of almost everything. It's an on and off project when new ideas came out. Recently, a new idea: head movement was inspired by cavegod's new UCS AT-M6 ([Moc] [Instructions] UCS AT-M6 - LEGO Star Wars - Eurobricks Forums). Why not give it a try? Any comments are welcome.
Hi, of course I love Millennium Falcon. All the versions provided by LEGO are great. The only problem is the space to exhibit it. So I've built a micro version. Some of the features are: less than 700 pieces has a cockpit for 1 Minifig has a living room with the chess table smooth bottom mini-mf-01 by A_C, on Flickr mini-mf-03 by A_C, on Flickr mini-mf-02 by A_C, on Flickr
Hi, I've built a AT-ST MOC. It's the version appeared in the movie. Hope you like it. Some of the features are: total 716 pieces 2 seats for Minifig movable and modular head hinged roof top a bit bigger foot to increase stability leg is limited to move but can stand by its own with a simple inter-locking mechanism It's now posted on Rebrickable: https://rebrickable.com/mocs/MOC-57220 Change Log: 2021-1-17 v1.5 (716 pieces) - trimmed the head a little - stronger legs - overall added more details 2020-11-28 v1.2 (729 pieces) - changed the pose of the legs - more details added to the body 2020-11-25 v1.1 (726 pieces) - hinged roof top - changed the back of the head a little - strengthened the leg a little 2020-11-18 v1.0 Initial Release (724 pieces)
