Showing results for tags 'art deco'.
Hi EB followers. I've finished my most recent build. Predictably its another Art-Deco/Streamlined hotel building but I figured its been a few years since the last so I've had time to refine my ideas! It's called the Deluxe hotel and it's taken a couple of months to finalise due the constant changing of ideas in my mind in how I wanted it to look. It's not directly based of any paricular hotel but incorporates elements of many ones found in South Florida. Only a couple of images to show, the interior is quite shallow so I didn't bother with an interior this time. Anyway, comments and questions as always welcomed! You can find the images on my flickr here if you prefer. Regards! Andrew
Fill 'er up! My latest build is a jump into the glory days of gas stations, when full service and free oil changes were the rule and the local station was a gathering place for neighbors. My brick-built gas station is inspired to the Shell one located in Tucson (Arizona) and it’s packed with every details you’d expect to find. It showcases an elegant Art Déco architecture completed with curved corners, a tower in the middle, a red outline all around the station and the inevitable Shell writing on top. The build is three in one: the diner on the left, the garage/workshop on the right and the fully-equipped store located in the middle of the building. A look at the back of the station reveals the three locations with many details and the different characters. Outside there are two period gas pump with a beautiful Lego shell on top under a curved canopy. All around you can find tanks, signs, tyres and other stuff. To complete the work I've built a red stepside pick-up truck, a tan Hot Rod and a reddish-brown roadster with some troubles (it's housed in the garage indeed). It was on my wishlist long since and finally I've found the time to built it as I had in my mind. I'm sorry for posting my gas station here with a little delay Thanks for stopping by. More pics and info: flickr
- 20 replies
- gas station
- hot rod
(and 8 more)
Tagged with:
For this build I wanted to combine the classical Ralph McQuarrie desgin with some dieselpunk aesthetics from the 1930s and 40s, giving it an elegantly curved and streamlined look. Just think of the wind-tunnel designed cars and trains – and of course airplanes – of that era. It was also pretty clear to me from the beginning that the only possible colour this fighter can have is red. It just works so well with emphasizing its lines and gives the whole build a vibrant dynamic I wouldn’t have gotten in – say white or grey really. Oh, and my affinity for the biplanes of the great war played quite a role too. So see it as the Red Baron in space basically! I see the landing gear as provisional, so it can be easier put on display (and to make it easier to find a place to land^^) I really want to make it more elegant, while not sacrificing its stability. Sadly there isn't really much space where it is - but I'm sure there will be a decent solution coming up Anyway, apart from that I am very happy with it. It is stury and very swooshable and is a nice display piece For more pictures and musings about its design and stuff feel free to visit my blog!
This station was inspired way back in 2013 by a long since expired Ideas project (link to my inspiration: https://ideas.lego.com/projects/34642 ), which was doubled in size and now features a double tracked platform + canopy and quad-sided clock tower. NOTE: You may want to cut two base-plates to a 8 x 40 size where the gaps are at the end of the platform. The station proper has removable upper roof and second floor sections. The top floor "floats" on tiles, and is removable to reach the sales counter on the main floor. Also removable is the platform and train canopy, as it is connected to the station via Technic pins. The double track train canopy was inspired by CITY set 60103, Airport Air Show, while the clock faces are supposed to feature this print: http://alpha.brickli...0pb024#T=C&C=11 The street side of the station has space for 8 printed 1 x 1 letters, allowing you to name the station what you want. If i ever did build this, which I probably won't, I would name it Glenncoe, after the location of a 12 inch ride-on real steam railway, The Wabash Frisco and Pacific Rail Road at Glencoe (spelled with only 1 "N") Missouri. (See their pretty cool website here: http://www.wfprr.com/default.htm ) The second floor has the switching control room and station managers office while the lower floor has the ticket desk and inside waiting rooms. By the way: the upper floor floats inside the walls on some tile-topped pillars, and is not connected to the build by studs in any way. NOTE: This train station most likely will never be built by me as I already have 3 stations as of now. But it IS build able in real life, so if anyone of you guys want to take a stab at this station, be my guest and please post the pictures both here and in your own thread. As such, here is the LDD file to the whole model, grouped so you can edit the station as you please: http://www.moc-pages...1463871791m.lxf Once again, questions, comments, and complaints are welcome!
NOTE: As some of you might be able to guess, the loco was inspired by pictures of @SavaTheAggie's original streamlined Hudson locomotive from 2007... no instructions were used to build this engine. See the inspiration here on Flickr. So you think I'm building a streamlined passenger train too, right? After all, it's a streamlined locomotive... ..WRONG! Yes, I know the streamlined Hudson's never pulled freight in the real world. HOWEVER: The Iron Giant animated film has a New York Central streamlined Hudson pulling a coal train that is badly wrecked (accidentally) by the robot. As I have the Iron Giant model already built, this was a no-brainer to make. Along with the engine and tender, there are going to be four coal hoppers, as you will see. Front view of the loco. This Dreyfuss-style streamlined 4-6-4 steam loco is numbered 5448 and is mostly modeled after a real, long-scrapped New York Central engine. The tender really should say the railroad's full name of New York Central instead of its initials, but I don't want to shell out the money for all those 1 x 1 tiles, so I'm using fewer 2x2 tiles instead to spell out NYC, as it's much cheaper that way! The cab of the loco is actually unable to fit a mini figure inside. (It's a brick too short.) These four heavily modified copies of the 1991 set 4536. (Blue Hopper Car) They lack the drop--bottom dumping feature of the set, as I made it much simpler (and cheaper!) by removing the playability from the cars. As you can see, I also had to shorten the train by one car from the original five down to four. This was because I ran out of room in the box to store them with some other freight cars. Now, if the train gets wrecked by a big metal man, I obviously need to add him to the post too! This is not my MOC: I bought the instructions for the model from B3 customs back in 2021. I found them on my hard drive again in late July 2023 and decided to build him in LDD. Then, in mid-August, I built him in real life... and promptly forgot to take photos of the completed model for over four months until November of last year. (whoops!) The rear of the robot. The original models' rotating hip joints (as used in the Build Better Bricks instructions) were removed from this version of the model because it was not strong enough. If the parts were worn even slightly, then the robot would not stand up under his own weight, breaking at the hip. Thoughts, comments or questions welcome! Updates: 1/30/24 real world photos added of everything, including Iron Giant!
- 33 replies
- coal
- locomotive
(and 10 more)
Tagged with:
This ship was designed to replace my original micro scale ocean liner from 2011. It's not intended to represent any real liner per say, though I was inspired a tiny bit by the Queen Mary (located out in Long Beach, CA) and a lot inspired by the Olympic / Titanic / Britannic sister-ships that were sadly scrapped / sunk by iceberg / mined in WW1. Here we see the RMS Allemann at sail at night in the mid-Atlantic sometime in the late 1920's. (this LDD picture was edited to give it a night-time feel. If only the portholes glowed!) The font of the ship (also called the "bow".) features three printed 1 x 6 tiles should spell out the name ALLEMANN on the left and right sides, and along with the stern. The light gray "hatches" at the fore and aft sections of the ship are for loading cargo into the various holds. Statistics: Ship Name: RMS Allemann Ship Type: "Gigantic" Class passenger Liner Owner: Red Star Line Ship Built: 1919 – 1921 Capacity: 400 Crew, 270 First class, 630 Second class, 1,000 Third class Lifeboats: 20 regular boats / 4 collapsible boats with 80 people per boat each (1,920 people total capacity) Builder: Strong & Steele Shipbuilders of London Propulsion: 24 Boilers, 2 turbines, 4 steel propellers Top Speed: 30 Knots Fuel: Diesel (originally Oil) The rear of the ship. (also called the "stern".) The raised portion of the deck is for the docking bridge when the ship is backing into port. The ship features a modular approach to it's construction, allowing for separation of bow and stern for storage ease... and in case I want to build a wrecked version in the future, I just disconnect the four Technic pins to remove the desired section from the rest of the vessel. Also, I thought about Gateway LUG holiday displays, which usually include light-up models in some form, usually modular buildings. These potential lights are now addable via the open bottom of the ship for a neat effect through the portholes. The pennant flag of the Red Star Line as originally used on the RMS Allemann. The RMS Allemann was first proposed in 1914, but World War One prevented it's construction by Strong & Steele Shipbuilders to start until 1919. The ship was modified from it's original proposed engine design to burn oil, and was completed in February 1921. The ship could hold 1,900 people total, with 400 being Crew, with 270 being First class, 630 in Second class, and 1,000 being the steerage, or Third class. The ship sailed it's maiden voyage in July 1921 from Southampton to New York City. The ship was English-owned, and as such, was immune to the new American anti-alcohol laws of Prohibition. The ship took off-peak season sailings (informally known as Liquor Cruises) around the Atlantic, returning to the American port of origin within a couple days. The ship managed to hold a steady service record, and remained relatively full-up until the Great Depression really took hold in 1931. The ship's owners, the Red Star Line, managed to stay financially afloat long enough to get the ship through the worst of the Depression, until the ship was requested by the English Navy as a troop ship in late 1939 for use in World War Two. The Allemann's fancy woodwork was put in storage and the ship was turned into a troop ship relatively quickly. The ship was strafed several times by enemy aircraft during the war, and narrowly missed being torpedoed in 1943, but it survived the war not too much worse for wear. When it was handed back over to Red Star Line, it was given a complete overhaul mechanically and electrically. The whole ship was rewired, and the oil burning engines converted to diesel. The Acadia's woodwork was painstakingly restored to it's original grandeur, and she was ready for for sailing by 1948, almost a year after being handed back to it's original owners. In the early '50's the ship began sailing luxury cruises to the Mediterranean from England and the United States, in addition to it's usual scheduled Atlantic crossings, and had it's third class re-designated as Tourist class. This was because the decline of the Atlantic immigrant traffic pattern was nearly complete. The ship began showing it's age by the late 1960's, when it's original glass dome began to leak badly. A handful of cracks in the reinforced glass caused the ship to be dry-docked, but before it could be fixed the huge dome collapsed in on itself, causing the grand staircase to be heavily damaged. Luckily, the accident happened in the middle of the night, and no one was on board at the time to get hurt by all that broken glass. The ships' dome was replaced, but only because the ship's owners knew of the ship's heritage and couldn't bear to see the old girl scrapped. (Not to mention it would have cost more to scrap the ship than fix the dome) By 1975, she was last four-stack ship in existence, and the owners were planning the grand lady's 55th Birthday for the next year. The Allemann celebrated July 1st, 1976 as her fifty-fifth birthday, and as part of the celebrations she was given to a preservation group dedicated to keeping the ship sailing as an "ambassador of history", as a peek into the way things were and how the men and women visiting and working on the Allemann went about their lives through each period of this ships stoic history. Many former passengers and crew detailed their experiences on the ship in writing or on film for the beginning of what later became known as The Allemann Living History Museum. Today, the ship features a feature-length film that chronicles the story of the ship and it's many passengers and crew through out the ships commercial and wartime lives. The film is shown in the Second Class movie theater, built into the ship in 1947 after World War Two, flowing seamlessly into the 1920's flavor of the ship. The ship still sails, making stops in New York and London (substituted for Southampton) at least twice a year. NOTES: The bow is either a bit too long or the stern too short, but I can't seem to fix that correctly to be "in scale". In fact, it's pretty much assured there is NO scale used with this ship, as I just built what looked good to me. The model will have to be bought sometime in Autumn of this year, as even though it has most of the parts from the 2011 ship inside it, (these have been removed the from the parts list to save money) it still will cost almost (US) $200 to purchase the remaining needed parts to have it done by the Christmas-time show later this year. Any thoughts, comments, suggestions, or complaints on this ship?
I redesigned the LEGO logo in an Art Deco theme for LOLUG’s October Competition. Website | Flickr | YouTube
EDIT: Instructions are now available on Rebrickable: https://rebrickable.com/mocs/MOC-102718/NonsenseWars/148-pennsylvania-railroad-t1-duplex-v3-power-functions You can see some new footage and an updated explanation in the following videos. Also cleaned up dead links from the original post.
- 14 replies
- streamlined
- steam
(and 7 more)
Tagged with:
A little urban renewal to transition the Detective Office part of town with the more classy modulars... my latest modular is "Chop", a small Asian fusion bistro in an Art Deco storefront. Oddly enough, I've wanted to use fish as an architectural element for a long time. 1st floor interior: Decorative wall panels. 2nd and 3rd floor feature a nice but somewhat cramped 2 bedroom aparment. Next to a couple of my other mocs. Thanks for looking! (Sorry the photography isn't great.)
