Showing results for tags 'bmw i8'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. After couple of years working on a not-car projects I picked up BMW i8 as my next project. This time I plan to post a work-in-progress pics here as well. Just for fun I think 05-May-2018Started with side. It has interesting door shape - both - the front and the end are sloped. Let's see how this construction will flow together with 75 degree inverted slope 06-May-2018Yep - it flows very nicely with 75 degree inverted slope. But - wow.. the struggle with the door end and the section around it. It has three different angles there in a small area. So complicated. I bet I'll return to this section 06-May-2018Continued with front grill. Those small neck brackets are really nice. They give the narrow gray line just above the kidney-grill section. And at the bottom the bumper will cover half of the plate, so the lines both will be as narrow as it can get. Also - a small update at door window line. Implemented the half plate increase (do not mistake that with half-stud offset). This gives the window line much smoother increase from front to the rear 07-May-2018Continued with headlights. There isn't much space to work within but somehow I managed to "break" the headlight in two angles and cover the side of it. 08-May-2018Something unusual. Normally - when I redo a part of my MOC, it gets more accurate shape, but at the same time it gets more fragile. Not in this case. The headlight outter section and the outter-bottom part of the bumper got nice curvy shape and is even stronger than before. 16-May-2018Changed the bottom of the grill section. Instead of half-covering the lower plate, I changed the entire supporting construction and implemented there headlight brick technique. This gives the desired grill look and the bumper fits there perfectly too. Now I'm struggling with the air intake and the small loop below the grill. Have tried like three or four different techniques, but nothing fits there like I want it to... 18-May-2018 After countless iterations I think I finally got the front air intake right. Turns out - I had to use the smallLEGO Technic panels. The connection is strong and easy. To be continued...
