Showing results for tags 'creator expert'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
  1. (Putting this together rather hastily) There has been very brief mention in the Creator thread of a new 18+ Titanic model for 2021, rumours having been leaked in the last 24 hours. Considering that the last ship LEGO made in an expert style was the Maersk one, which I missed, I'm particularly excited about this one. Thanks to @VanIslandLego for this one. No other info is known. Discuss below.
  2. TLDR: Super-detailed fully-modularized Creator-scale 16-wide MOC build of beautiful 1999 Le Mans-winning FIA LMP prototype. 903 pieces (including 3 round-plates-with-strings, 6 whips, and 8 “non-Lego” custom wheel parts). 1/15.2 scale: 16 stud wide, 38 stud long, 23 stud wheelbase Winner - with a bit of luck - of an exceptionally rough and tumble 1999 Le Mans in the hands of Joachim Winkelhock, Pierluigi Martini, and Yannick Dalmas. The LMR was the second iteration of BMW’s LMP car, designed and constructed by BMW with Williams F1, powered by a development of the BMW S70 V12 which the McLaren F1 had used to win Le Mans a few years prior. Longtime BMW racing partner Schnitzer Motorsport ran the team at Le Mans proper as well as in the American Le Mans series. The low and sleek car looked like a ufo compared to the competition. The LMR has a fairly simple and compact shape, but it’s not a brick… the subtle lines are quite refined and put up a challenge to capture smoothly in Lego. The entire nose build is a circus of surfaces all at slightly different angles, their mountings dotted here and there in precise positions over the tub structure. The roll-hoop and engine hump cowlings are jammed full of more angles and curves. The rear fenders tumble and taper back to those extremely compact multi-directional-snotted wing mount and taillight assemblies. The sidepods look simple but are full of some connections voodoo for their multi-hinged lower surfaces. The car's so slim there's really nowhere to hide much supporting structure. Wheel inserts and brake discs are designed in Cinema4d and fit into the back axle tubes of Lego's Icons wheel #42716. The spoke shape, offset and hub proportions were refined through a sequence of paper prototypes to dial in their scale, then the final design was high-resolution SLA resin printed and sprayed with Tamiya TS38 gunmetal (as are the backs of the Lego wheels). Graphics are a mix of printed stickers and cut vinyl. It's not quite perfect: the indigo color-shift blue vinyl turned out a bit too dark - needs a much larger surface area and strong light to really sparkle - and those delicate air-flow pinstripes need to be metallic on transparent substrate so the different white materials aren’t as noticeable. The open cockpit captures various details; Pi/BMW M digital dash, switches panel, electronics boxes all carefully studied, drawn in Illustrator, and shrunk down to scale. (I forgot to do the Emergency markings, so these are swiped from a 1/24 model and comically small) The rear bodywork is a large single assembly that lifts off, revealing that glorious V12. The rear wing and trailing edge of the bodywork (with those complex little taillights) is cantilevered off the end of the transmission. The intake airbox assembly lifts off to reveal 12 intake trumpets, the oil tank and engine ancillaries. Getting the radiators attach at angles flush with the wing plates on the ends of the sidepods was a triumph of Lego maths... A few stickers for the radiator faces and the cam covers provide some texture. The sidepods, splitter, and engine drivetrain are all separate from the tub following the construction and design typical of these cars; the bare chassis of these masterpieces of design and packaging is one my favorite views… The tub itself has a raised footbox with a rounded 'boat prow' profile which helped to channel airflow from the upswept nose underside out through the open sidepods. The remaining flat floor continues back to under the rear axle where the shallow diffuser tunnel kicks up. As always, thanks for looking and thanks for the inspiration, Prototyp These photos up at Flickr: https://www.flickr.com/photos/prototyp/ Stop by and say hi: https://instagram.com/prototyp_brickworks
  3. I was just on the 'Everything we know so far' page for 2021, which I check regularly, and realised that despite I having known about both these sets for at least a month, I've seen almost no discussion of them Eurobricks. If there has been, can a mod please merge or delete this post. Just for the details: 10280 Flower Bouquet 756 pieces US$49.99 / EUR49.99 / £44.99 10281 Bonsai 878 pieces US$49.99 / EUR49.99 / £44.99 These are the first two unbranded small 18+ sets. The PPP seems pretty good. 10281 is listed on Brickset now, but with no info. 10280 is not. Interestingly, 10281 has been put under 'Sculptures' - the fourth in this category, after Statue of Liberty, LEGO Minifigure, and LEGO Dragon (all released 20 years previously). Both sets are scheduled for release January 2021. A leaked image of the Bonsai was posted on Instagram today, probably resulting in Brickset adding it to their inventory. What do you think of these sets? Is the small size a good thing? Do you see many more being released in the future? If so, what? Discuss below.
  4. According to Promobricks, one of the LEGO 90th anniversary set's will be a Castle set, inspired by the 1984 set 6080. Set number: 10305 Name: King’s Queen's Lion Knights' Castle Piece count: 4514 Release date: August 8 2022 (August 3 for VIP's) Availability: probably LEGO exclusive Price: 349.99 399.99 Euro Size (closed up): W = 44.5 cm, H = 38 cm Nr. of minifigures: 21 (Queen, Majisto, 9 Lion knights, 3 Black Falcon knights, 2 Forestmen, a young female forest ranger, maid, farmer, baker, boy) + 1 skeleton Animals: tan horse with Black Falcons barding, dark orange horse with Lion Knights barding, dark tan cow, white lamb Accessories: A variety of swords, axes, maces, lances, bows and shields, various helmets and breastplates, as well as a trumpet, a lute, a drum and several flags. LEGO Designers: Mike Psiaki & Milan Madge *castle seen in the DeLorean commercial is only a prototype version of the castle Official images:
  5. Dodge Viper - 10265 c-model I made my first attempt to the Viper before building the Hummer. I wanted to use the white stripes offered by the 10265 set. I must admit that the Viper is one of the most iconic cars that use these painting. The problem is that it has an extremely slim silhouette, and the Mustang parts are much more suitable for the construction of an angular body. The final model is the result of 5 approaches. On the fourth, I had the model almost finished and all I had to do was construct a rear diffuser out of the scraps. It was not without a slight remodeling of the rear bumper, which left me with a few additional parts, which I knew would be very useful in the front. This way I demolished half of the car and it was a good decision. Thanks to this, the model has definitely gained stability. There are a few delicate details, but there is no risk that any of them falling off when you grab onto any part of the vehicle. The fairly low profile of the whole and the desire to reproduce the engine dummy in a decent way, eliminated the possibility of installing a torsion axle, which takes up so much space on this scale that it would have a negative impact on the appearance. Technical info Rebuild of the set 10265 Ford Mustang Model: Dodge Viper Parts: 984 - also used extra parts Height: 10,5 studs (8 bricks and 2 plates) Width: 16 studs (17.5 studs with mirrors) Lenght: 38 studs Functions: Opening doors and hood. Instruction: 298 steps on 189 pages. Flickr Brickshelf Instagram Rebrickable
  6. Hey guys, I decided to create this topic and the main idea came from this and this post (so special thanks to @danth and @Digger of Bricks!). I would like to highlight three things before I start to post inspirational MOCs: I’ll post three staff picks everyday! Please feel free to post your favorite MOCs! Have fun admiring and taking inspiration from those great MOCs Top three MOC’s IMO in Baroque architecture: 1. This incredible Baroque Church by @Jellyeater! 2. This amazingly detailed MOC by @pj_bosman! 3. This greatly shaped modular by @cimddwc! Here are the three best Baroque MOC’s IMO! What do you think about them? Would you buy modulars like those if TLG made? Here are the Steampunk ones: 1. This incredible layout made together by @castor-troy and @domino39 (they also made one MOD of the PR and the MS and two MOD’s of the CC included in this layout. But they look so different that they are more MOC then MOD). EB topic here and Flickr albums with more photos here, here, here and here. 2. These great Steampunk modulars by @adde51! 3. These very interesting modulars by @Zilmrud who as well made great MOD’s of the PC and the BB! Here are the three most gorgeous Steampunk MOC’s IMO! What do you think of them? Would you buy modulars like those if TLG ever made?
  7. Here is my latest Modular MOC, a Tiki Bar & Restaurant with a townhouse next door. I completed this MOC in the spring but just got around to photographing it this past week, so I thought I would share it here. This will be a very image-intensive post, so if you want to see all of the images on Flickr, check out my album here! Here's the full front view, with both buildings side by side. A closer view of the facade of the Tiki Bar. I named the bar HAU after the Infected Bionicle mask that adorns the entrance. Now to look inside! The A-frame Archway clips on and can easily be removed in order to access the individual floors. The A-frame Archway, Disassembled from the main structure. Top floor of the Tiki Bar. The chef prepares Polynesian-inspired chicken and seafood recipes in the kitchen. The best seats in the house are at the banquet table on this floor, giving diners a unique experience. The second floor of the restaurant and the bottom floor of the townhouse. More townhouse pictures are coming up. This floor of the restaurant has an opening that overlooks the bar below. The dining tables on the second floor. The walls are adorned with traditional Polynesian-inspired Tiki decor such as nautical paraphernalia and seashells, and globe lamps light the restaurant from above. Overlooking the bar below is a loft area with a giant Tiki idol and a colorful banner. The stairs leading to the top floor have some hidden skulls beneath them. All of the great Tiki bars have lots of hidden details. The bottom floor of the restaurant, with the bar and additional dining areas. The bar area has lots of traditional Tiki mugs lining the shelves made from an old boat hull. Another large Tiki statue looms from the archway in the back. The front door from the inside, showing the torches that help to create the appropriate level of lighting. The lavatory is hidden off in the area behind the bar. After getting past the Tiki idol on the ground floor, patrons will find the stairs to the upstairs level, along with a door to the outside... ...where they can find cozy outdoor patio with intimate seating for two. And now, for the adjoining townhouse: The top floor of the townhouse, with a loft-style bedroom and bathroom. The townhouse bathroom. The open kitchen on the first floor, with a small dining nook. A cozy living area allows the resident to watch their favorite TV shows or relax with a good book. The back of the apartment has a small porch with flowerbeds and seating. Thanks for looking! Again, the whole gallery can be located here!
  8. Hi everybody, I'm new here (link to my presentation), and to introduce myself to all of you I'd like to share some of my creations. Some of you may already have seen the mods I showed early today in the SW forum, but now I'd like to show something completely original, and probably my favourite digital moc so far. I am a lover of the Winter Village Creator Expert series and I decided to create something myself to expand my town. I thought that in the winter village line were missing a market to feed the poor cold minifigures, so I started LDD and I created a small grocer! The name clearly isn't casual. I decided to make a tribute to the famous modular building, the green grocer, and working with this idea in mind I realized some details in a similar way to the original building! I leave to you the game to find all the similarities! I haven't actually built a real model since some parts are not existing in the colors I choosed, but I guess in the future I will find a solution to replace them. Those are some renders I made: Winter Green Grocer by SpaceBrick, on Flickr winter grocery stairs by SpaceBrick, on Flickr winter grocery well view by SpaceBrick, on Flickr My goal was to create something similar to the existing winter sets, so the Grocer isn't so big in terms of pieces (around one thousand) and is completely open on the rear, just like the Toy Shop or the Santa's Workshop: Inside Winter Green Grocer by SpaceBrick, su Flickr inside winter grocery 2 by SpaceBrick, su Flickr inside winter grocery upper floor by SpaceBrick, su Flickr The ground floor is the actual shop, the first floor is a sort of a warehouse and a office for the grocer's owner. The roof is quite simple by choice, in this way is more similar to the other winter buildings. Outside there are a couple of more details. There's a well, a snow covered tree and a lamp, that always come with Lego winter sets! I also created some minifig to complete the scene, in particular there are the shop owner, a customer and a mailman, useful to deliver new daily supplies. winter grocery well 2 by SpaceBrick, su Flickr Winter Green Grocer accessories by SpaceBrick, su Flickr I submitted this project also to Lego IDEAS, and it has been selected in those days to appear in the Staff Picks in the Ideas homepage.I honestly do not think that the project will go much further, because unfortunately winter village is not a click-catcher theme, but if you like my project I leave here a link to the related page: WINTER GREEN GROCER If you wanna take a look, in the page there are also a few updates where I tried to combine more than one shop, just like that: LEGO Summer Green Grocer - double, tiled roof by SpaceBrick, su Flickr And this is it, I hope you enjoyed my modest moc! Thank you for watching, if you like my creation please leave a comment!
  9. According to Promobricks, the new Fairground Collection set will be 10303: Loop Coaster, a giant roller coaster with a double looping and track segment elevator consisting of 3 coaster wagons that run on yellow bright light orange track. Also included are a hot dog stand, a pretzel stand, a clown with bike-stand selling balloons, a bench for minifigures to rest on and an amusement park plan. The elevator is operated manually, but the set is "Ready for Powered Up" and can be fitted with a battery box (88015) + motor (88013), similar to 10261. Set number: 10303 Set name: Loop Coaster Pieces: 3756 Release Date: July 1st 2022 Price: 359.99 Euro 399.99 € / $ (PPP 10.6 Cent) Nr. of minifigures: 11 (7 visitors, 3 vendors, 1 coaster operator) Size: W=85cm, H=92cm, D=34cm
  10. Full RC Conversion of 10269 Harley Davidson Fatboy After many hours of trial and error, broken bits and gray hair I have finally a working Remote Controlled Harley. And it actually works wery well and are not more fragile than the orginal set. My goal was to create a slower motorbike that you can play with in your living room, so self balancing was not an option as this requires high speed to work. My bike runs on "training wheels" all the time that leans at the same time as the handlebar stears. Have tried my best to hide the electronics an keep it as close looking as possible to the orginal set. Motorized wtih Buwizz/CaDa battery to save space and Power Functions motors. Youtube Video Instructions available at Rebrickable
  11. According to Promobricks, this will come in April 2022! HYPE https://www.promobricks.de/lego-delorean-erscheint-2022/131071/ Lets discuss!!!
  12. With the year end only a couple of months away, it is time to look towards 2022 for some of the new sets that will be launching once spring rolls around. According to a multiple sources, the next vehicle to get the LEGO Creator Expert treatment will be none other than the quintessential scooter brand, The Vespa! From what we gather, it would not be a current model but the classic one without the side mirrors. It is rumored to be given a mint green paint job and will come with brick built accessories like helmets, flower, a newspaper tile and a bag. It is pegged to be €99.99 but the piece count has not been confirmed yet. The launch date is slated for February which means we should see some official images at the turn of the new year. (Source: https://www.brickfinder.net/2021/11/05/lego-creator-expert-vespa-10298-first-details/?fbclid=IwAR0j5MEHXPzITPLsWYBg1RBdUXUZpL6rnZTH2m5iou9diEgYMhM_54XNrbw)
  13. From: brothers-brick.com EDIT: @VBBN posted a review for this set, so I suppose this topic is redundant now .
  14. Hi everyone! After a brief 'dark age' spanning a few years, I've now designed and built a new cargo train locomotive. I wanted something that exudes a sense of 'heavy industry' and initially created a prototype that didn't quite meet my expectations (see image bellow). This model takes inspiration from both the Lego Creator Maersk train, incorporating most of its general structure, and the Polish SM31 shunter locomotives. The locomotive showcases a sleek, black exterior accented with yellow and white details. Because of the primary color, I affectionately named it the "Coffin" locomotive, akin to the real-life SM31's nickname (Trumna). The locomotive closely resembles parts of the the distinctive SM31 train, and the cabin is designed for a minifigure operator, complete with a control panel. Additionally, it's equipped with Power Functions, including a battery box, a train motor, and an IR receiver. Before settling on the black color scheme, I explored various digital iterations, considering options like yellow, red, blue, and green. Ultimately, I chose black for its cost-effectiveness, leveraging parts I already owned.However, it did result in the photos having slightly lower quality due to the darkness of black. The digital model is readily available for download using Lego Studio: https://rebrickable.com/mocs/MOC-158217/Brickviller/coffin-heavy-shunter-locomotive/#details The prototype version, mostly based on an elongated version of the red cargo train 3677. Please take note: Although the digital model featured a light bluish-grey windscreen piece, I discovered that no such part exists in that color when I started building it. I sourced the piece from a custom vendor, and it's not an official Lego component. In the future, I plan to replace it with an original Lego piece in white, which is readily available.
  15. Hello! I'd like to present my newest modular, which I completed late last year. This is my biggest Modular MOC to date and features three different business all under one roof: A book store, an ice cream parlor, and a music shop! Here's the overview of the building. At the street level, there is a music store facing south and an ice creamery facing east. Next to the ice cream shop is the entrance to the upstairs bookstore. A street level view of the south side of the building. A close-up of the music store facade, with an interior view. A street level view of the east side. Ice cream shop facade close-up. Top-down view of the ground floor. Inside the music store. "Weird Al" Yankovic is looking for a new accordion. Inside the ice cream shop. The hippie was disappointed that there were no vegan options available. Inside the bookstore, where the mechanic is looking for a nice book on Eastern philosophy while the old man gets sucked in to his favorite spy novel. ] The employees are always helpful for those searching for that perfect book or to froth some milk for a nice hot latte to go with it. Some of the customers prefer their books to be read to them by a celebrity. The upstairs reading loft comes out to give access to the area below. After completing his purchase, the mechanic asked the bookstore girl out for ice cream, and they seem to have hit it off. "Weird Al" Yankovic was a little disappointed that the shop didn't carry accordions, but he did find a good deal on a new guitar. Meanwhile, the old man just can't put down that spy novel. I do have one minor confession! I used a non-Lego part (The BrickWarriors Spartan Shield) as a building decoration. I didn't realize it was a custom piece at the time of the build, having acquired it in a large bulk purchase a few weeks before. Being a purist when it comes to my MOCing, I've since removed and replaced it, but I just had to get that off my chest. Whew! There are plenty more pics in my Flickr folder! Thanks for looking!
  16. As a camper van, the 31052 Vacation Getaways set is far too big for my taste. But as an exception to the rule (the rule being that alternative 3in1 models are uninspiring and poorly made) the Hillside House style small building looked sort of nice in the pictures, and the sand blue windows and door frame were enticing. So in all the places of the world, I found this set for a good price in Switzerland, which otherwise must be the most expensive country in Europe... €41 for one set. I got one and built the house. It felt even smaller than I had thought, but with another set, it could be expanded... So I bought a second set, but didn't end up expanding the house. Instead, I started playing around with LDD. The result is a 16-wide three-storey modular building based on the idea of using the sand blue windows. The back side is very plain, as are the sides of the building. There is no interior, save for steps that take you from floor to floor, apart from the ground floor, which doesn't have any steps... I'm not too fond of creating interiors for residential buildings, since they are all more or less the same, so this will most likely remain empty. I hope you like it!
  17. Welcome to the Jackal Staff Oasis! Deep within the sands of a long lost desert, the glittering oasis beckons. Rising amongst magnificent date palms and tranquil, lotus-covered pools, is a fabulous temple containing the vast treasures of the surrounding kingdoms. Young Amata has been sent to retrieve the fabled, powerful Jackal Staff contained within this lush paradise, to bring back to her kingdom in need. I built this MOC digitally about a year and a half ago, with the intention of using it as a contest entry, but then ended up not using it. Later, I revived the design and built it in physical bricks. The model has 1522 bricks total, and measures 12" long, 15.6" wide, and 8.9" high. My favorite part about the whole build is the garden in the front with the water features and the palm trees. A close second would have to be the columns for sure! More pictures can be found in our Flickr album! https://www.flickr.com/photos/orientexpress24/ This MOC is currently up and running on LEGO Ideas! Any support would be greatly appreciated! You can support it here: https://ideas.lego.com/projects/4dbf14ab-a99a-4252-9949-e59d34fc6616 https://www.youtube.com/watch?v=sItTWTtWhjk https://www.youtube.com/watch?v=towPSgd78t4
  18. Hi everyone I'd like to present my latest MOC, a new modular building called Bricks & Blooms. I hope you like it. Bricks & Blooms is a modular Garden Centre built over 3 levels on a 32 x 32 base plate. in total it uses 2587 bricks. The facade is supposed to give the impression of being 2 buildings side by side but it is of course just one single building. The front to back measurement of the building is quite narrow, similar to Parisian restaurant. This is because I wanted to maintain plenty of space at the rear of the building for the main outside garden centre / plant sale area. THE MINIFIGURES I've included 6 mini figs and a cat with this MOC. Left to right they are: 2 customers (a father and his daughter), The garden centre shop keeper and gardener, the chef and the Aquatics shop assistant. THE GARDEN CENTRE AND GROUND LEVEL DETAILS The main garden centre area of the store is situated on the ground level. Outside on the street, I've included a tree, bench and lots of plants and flowers for sale. The garden centre also has a fruit and veg stall that sells it's produce directly to passers by on the street. Inside the shop I've included the cashier desk and more plants and gardening tools for sale including a little lawn mower side-build. Here is the interior of the fruit and veg stall that is accessed through a door at the back of the cashier desk. A door at the back of the shop leads out in to the main outdoor gardening area. Here I've included a large glass canopy covering rows of tables holding bedding plants. There are also more flowers, pots and other gardening products including a water feature. The stairs at the back of the building lead up to level 2. LEVEL 2 - CAFE/RESTAURANT No garden centre would be complete without its own cafe/restaurant. The cafe on level 2 has a fully equipped kitchen with serving desk and tables and chairs for the minifigs. There is also a small balcony in the cafe that looks out on to the street below. LEVEL 3 - AQUATICS Many garden centres here in the UK also have departments that specialise in pet fish and Aquatics. Bricks & Blooms is no exception and has it's own dedicated Aquatics section on level 3. The Cat below seems to have its eye on the goldfish. The door behind the desk leads out on to a small roof terrace area. FLOWER CART The model also includes a flower cart. THE FINISHED MODEL The picture below shows Bricks & Blooms combined with my other modulars and vehicle MOC's. Left to right they are. The Queen Bricktoria Convenience Store Brick Square Post Office Bricks & Blooms The Old Workhorse - Traction Engine LEGO IDEAS I have submitted Bricks & Blooms as a LEGO Ideas project. If you like the model I'd be really grateful if you'd be kind enough to head over to LEGO Ideas and give the model your votes. You can find the project at the following link. Many thanks! http://bit.ly/bricksblooms I hope you like my newest MOC and thanks very much for reading. As always, there are many more pics on my Flickr page and feel free to leave comments and let me know what you think.
  19. I noticed recently that there's been no topic for future landmark buildings (mods please merge/delete if I'm wrong) so I thought I'd better make one. There have been 6 landmark building sets made by TLG so far: 3450 Statue of Liberty (2000) 10181 Eiffel Tower (2007) 10189 Taj Mahal (2008) 10214 Tower Bridge (2010) 10234 Sydney Opera House (2013) 10253 Big Ben (2016) The Statue of Liberty is technically not part of this line but of the 'Sculptures' line that also includes 3723 LEGO Mini-Figure and 3724 LEGO Dragon, but I have included it here as the only Creator Expert set not officially of the 'Buildings' line that is a building known worldwide. The Taj Mahal was rereleased in 2018 as 10256. But the big question is.... what next? The building has to be something that can be sold and recognised globally, and would be a very large set (the smallest so far is the Statue of Liberty with 2882 pieces). It would also probably need to be something of architectural interest - not just a big glass skyscraper (the Burj Khalifa falls into this category). Towers are possible, but as the last one was a tower, I think it's unlikely. 10253 also had a large extension to the side which made it far more interesting. If you ignore the Taj Mahal entirely (or at least the rerelease) there have been buildings in 2007, 10, 13, and 16, so it would make sense to have one in 2019. The Taj Mahal rerelease is now the only one available, as Big Ben and Tower Bridge have both just been retired from LEGO’s range. It would therefore make sense to have one this year, with no others available apart from the Taj Mahal. So what is it? Share your thoughts in the comments below - but please no 'I want' or similar.
  20. Hello, Forgive me if I'm posting this in the wrong forum, I'm only familiar with the technic forum. I wanted to ask, would 10295 ultimately be available from retailers? I live in the Caribbean and have to order my lego from Amazon US, but I've noticed that 10295 is yet to appear for sale there. Is it that it would only be a lego store exclusive? The US lego site won't ship to me. If anyone can advise me I'd be most grateful. Sorry for being a bit off topic.
  21. Here it is! Refinished and redone, with a couple of added bits and bobs, the Mountain Oracle! Ascend the steps of her mountain sanctuary, and just maybe she'll speak to you of the future. This is a MOC I created a while back, I've made some upgrades since the first version. The fountain down in front, as one, as well as that waterfall coming out of the mountain. And a second partial tools up on the hillside to the right. And yes, that staircase is a lot more sturdy than you'd think. It's supported from underneath the platform landing as well as by several clear supports that are hidden behind the staircase itself. This is the original MOC, that's been improved. This MOC (the resubmission) is now gathering support with blazing speed on LEGO Ideas! If you like it and wish to support it, please consider doing so! Thank you! :) https://ideas.lego.com/projects/f31174e5-f828-4ea8-858b-9014d457cbfc You can check out more pictures here on the Flickr page!
  22. 10283 is a listed set on this site. I saw a similar mention of the same set on Instagram recently. The info has also come from stonewars.de The given information is: 10283 Space Set? US$199.99? July 2021? The recent expert-style sets (Creator Expert/Ideas/18+) have been: 2010: 10213 Shuttle Adventure (Creator Expert) 2011: 10231 Shuttle Expedition (Creator Expert (Rerelease of 10213) 2014: 21104 Curiosity Rover (IDEAS) 2017: 21309 NASA Apollo Saturn V (IDEAS) 2017: 21312 Women of NASA (IDEAS) 2019: 21321 International Space Station (IDEAS) 2019: 10266 NASA Apollo 11 Lunar Lander (Creator Expert) 2020: 92176 NASA Apollo Saturn V (IDEAS) (Rerelease of 21309) So... 2021: 10283 ????????????????? (Creator Expert / 18 Plus) Discuss below.
  23. This is Assembly Square 10255 but slightly reduced to the scale of micro figur. Micro Assembly Square is my newest MOC but my first micro scale construction. I added as much detail as I could into the build. I think this is the most cheerful set of all high street sets. Nice shops with many play options. Not only did I make the building in micro format, but I also reduced the interior and street details to micro format so that you can really play with it again on a small scala.
  24. Hello Everyone, I'm new to Eurobricks, so let me present my first ever LEGO car design, which is a 1:13 scale model of the iconic Land Rover Series II 88" from 1958. The design was made using Studio 2.0. Originally I wanted to build this car in an authentic Land Rover colour (LEGO colours sand blue/green or dark red/green), but many parts are unavailable, and therefore this remains a dream. Luckily, all parts are available in red, and therefore the model can be built. The model fits in the Creator Expert car series. It consists of 1477 parts, the doors and the hood can be opened. I designed some custom decals (front grill and dashboard) to capture some characteristic features of the car. Most of the chassis is built in an unusual way, which made possible to build a smooth curved lower edge. The canvas holding frame is easily removable, and you can find a simple engine under the hood.
  25. After my 2 pick-up alternates, I returned to set 10265 twice more but this time to create 2 vehicles heavily inspired by iconic and classic sportscars from the 1960's in which Ford also played a key role, the GT40 and the Shelby Cobra which both fit perfectly with the 1967 Mustang. First the GT40 famous for winning Lemans. The GT40 was first built in England, but the later version in the US. GT04 main by Nathanael Kuipers, on Flickr The model features working steering wheel, opening doors, and engine cover with an engine that can be removed and displayed separately. GT04 open by Nathanael Kuipers, on Flickr Next is the Cobra Roadster, also a car that originated in the UK, but which Shelby with the help of Ford imported to the US. There it was equipped with a much larger engine that also required other changes to the chassis and suspension. I built this specific model for the TLCB Lock-down competition Cobra Roadster by Nathanael Kuipers, on Flickr This was a tricky model to render in bricks due to all its curves. Cobra Roadster rear by Nathanael Kuipers, on Flickr As with the GT40, this model features a working steering wheel and opening doors. Both front and rear open too. Cobra Roadster open by Nathanael Kuipers, on Flickr If you're interested to read more about the development or would like to see more pictures of either vehicle, please consider to have a look at my website NKubate.com. Thanks for looking!
