Showing results for tags 'delta-7'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 8 results
  1. After this years (underwhelming) release of one of my favorite ships, I thought I'd give it a go and make my own. I was inspired by khatmorg's & atlas_er's versions, and I borrowed some ideas from them and also did some things that make mine unique. I actually built khatmorg's version and really enjoyed it, but I thought it should be a bit larger and a bit more detailed. I also wanted to have retractable landing gear and a realistic underbelly. Enjoy! - Gumbinger fullsizeoutput_6f8 by M G, on Flickr fullsizeoutput_6e7 by M G, on Flickr D728 by M G, on Flickr fullsizeoutput_6ea by M G, on Flickr fullsizeoutput_6fd by M G, on Flickr fullsizeoutput_6ef by M G, on Flickr fullsizeoutput_6e4 by M G, on Flickr fullsizeoutput_6ee by M G, on Flickr fullsizeoutput_6ec by M G, on Flickr fullsizeoutput_6e1 by M G, on Flickr D716 by M G, on Flickr fullsizeoutput_6f1 by M G, on Flickr fullsizeoutput_6e8 by M G, on Flickr
  2. Hi, Since I have the 10215, I want a ring for it. So I decided to create a ring : (I just miss 1/4 circle tiles in white) Album Filckr of the MOC : https://www.flickr.com/photos/138759056@N05/albums/72157688085836894 Last version : The support : IMG_20170903_151900 IMG_20170903_151941 Ring only : IMG_20170903_152113 IMG_20170903_152159 IMG_20170903_152236 IMG_20170903_152256 IMG_20170903_152348 Ring with ship : IMG_20170903_153056 IMG_20170903_153209 IMG_20170903_153322 IMG_20170903_153400 IMG_20170903_153538 All critics are welcome !
  3. This is my version of khatmorg's incredible delta-7 model (which you should view here www.flickr.com/photos/95628537@N02/8735306298/in/dateposted/ and here http://www.eurobrick...2931&hl=delta-7) . I originally built their model as per the original build over a year ago but a few months ago I started fiddling with it and have now arrived at a point where I'm satisfied with it. It was difficult to find other ways to achieve some angles (the source is so good already!) especially in the back and as a result that area is quite fragile and use some illegal connections. Most of the changes are concerned with the bottom, spine and rear sections. I haven't been able to find a way to find a way to hide some little landing gears in the back of the wedge where it fattens out a bit yet so the ones you can see in the other photos are just attached externally. Also it is about 8 to 10 studs too long as a result of the angle of the 1x3 wedge plate, according to the rough scale I used. That isn't ideal for me as I like to scale it right to a degree, but the additional detail you can add on a bigger model is good as well. I also wanted to try an alternative solution to miniaturise the dual laser cannons, and add the other half on the bottom but haven't solved that issue either. I might pick this up again later and play with it some more but for now I'm content to reveal it. I hope all of you enjoy. Thanks to khatmorg for being so great about sharing their creation. The stand is based on sydag's method which you can see here (www.flickr.com/photos/sydag/16129935387/in/dateposted/). It's simple and ingenious. You can view the rest of photos in the album (www.flickr.com/photos/48109771@N05/albums/72157668258477972).
  4. As my exploration of Prequel ships continues, I'm trying to shift my focus to Minifig-scale more, and decided to give a crack at Obi-Wan's sleek Delta-7 from Episode II: Attack of the Clones. At exactly 400 pieces, this compact and angular ship was full of technical challenges, especially with the constraint of making a proper interior that could accommodate a full Obi-Wan Minifigure without ending up with a bulky design. Following my "wings must be as thin as possible" philosophy (like the Eta-2), I used a combination of plates & tiles for the outline of the wings, and bricks on their sides for the rest: this resulted in 2-plate thick wings, which give the ship all its slenderness, especially seen from lower angles. At this scale, and given how compact the ship is in-universe, I wanted to respect the slim and sharp look of the original design. Making a functional cockpit with comfortable space was the most daunting task as I needed to securely attach the fin section and both angled fuselage parts that surround the cockpit without using any vertical space, where Obi-Wan sits. I also managed to incorporate a dashboard that doesn't obstruct the pilot's view and depicts the screen fairly well. The model features detachable landing gear to be displayed on the ground, as well as a canted stand for a more dynamic pose. The model is very stable overall and perfectly swooshable. ► Instructions for the Delta-7 are available on Rebrickable! More pictures on my Flickr page.
  5. things changed: -lowered cockpit down roughly 1 brick, changed build around cockpit region to slope into wings, taper into body, round out the rear to more accurately reflect the shape of the model in canon -filled in gaps with 1 tile width across whole body; requires some gaps in wing construction -replaced guns for accuracy; subject to further change to reduce conspicuousness -cut up stickers to apply across model -cut cockpit -nexo tile at front to hammer in the point :) working on instructions if anyone's interested. if ur curious on scale it works like this
  6. Hello ! Here is the second iteration of (kind of) my delta-7 model. You ought to see where this all started on khatmorg's page here: https://www.flickr.com/photos/95628537@N02/8735306298/in/dateposted/ And the eurobricks thread: http://www.eurobricks.com/forum/index.php?/forums/topic/82931-moc-obi-wans-delta-7-aethersprite-class-light-interceptor/ The previous eurobricks thread: http://www.eurobricks.com/forum/index.php?/forums/topic/132852-moc-delta-7-aethersprite-class-light-interceptor/ plo's delta-7 album on flickr: https://www.flickr.com/photos/48109771@N05/sets/72157675717316394 obi-wan's delta-7 and the rest: https://www.flickr.com/photos/48109771@N05/sets/72157675717304614 This time I photographed it mainly because last month I finally finished painting the livery onto the necessary pieces for plo-koon's whip from the order 66 montage in episode III. That was a protracted process because I was working off only 1 piece of reference material (http://vignette2.wikia.nocookie.net/starwars/images/9/94/Plo_Koon's_Jedi_Starfighter.jpg/revision/latest?cb=20061207163510), and it took a long time to begin placing important marks on the model so that the rest of the design would follow the source material as closely as possible. I haven't done much painting at all, so doing this was a learning experience. Some of the edges are cleaner than others, due to some amateur masking, but I'm pleased enough with the final result. I have a series of progress photos documenting the project basically from start to finish. (warning: ~30 images will pop up) Not much has changed from the original version, but most of what has concerns the rear section. I also managed to include retracting landing gear inside the bulbs of the engines, which in hindsight was a no-brainer for how simple it was to incorporate. I was forced to paint some parts dark red, dark blue, and white simply because they aren't currently available, but I tried to restrain doing that too much to keep myself in Lego territory and away from modelmaking. The build itself is pretty solid and "swooshable" I guess. My main issue with the build, which I gave up on correcting when completing the revised versions, is that the cockpit section rises up higher than it should (ie, it's too fat). Using the 12x3 wedge plate made that impossible to fix (for me), but I think it's not too bad. The other thing I'm not sure about is the angle of the wedge from the tip of the nose backward - to my eye, it seems like the ship itself is a little bit too narrow. I haven't been able to find much blueprint or schematic-style reference to look at this so it will have to do for now. A word about scale: the real thing is listed as 8 meters long so I used that as a starting point (well, retroactively). Using a scale of 4 studs = 1 meter, it should be 32 studs long. The build is 36 long. I'm going to pin that down to the angle of the wedge - if the tip of the nose was warped back 3 studs, that might fix the angle. But i have to call it a day on this one I think so I finish other things. I have left notes on some of the photos on my flickr profile, please do take a look. Feedback,criticism, and comments are much appreciated!
  7. Hello there! Here is my second iteration of one of my favorite ships of Star Wars -- the Delta-7 Aethersprite Delta-7 Jedi Starfighter. @khatmorg & @atlas_er are big influences on this design -- especially the cockpit area of @khatmorg's, and the wings by @atlas_er. Biggest difference in mine is the overall length; it's shorter by two studs (which I think is more accurate). Making it a little smaller in comparison, but still has a lot of detail. Overall I'm really happy with how it came out. I tried my best to eliminate all gaps, and make it smooth as possible. I've very proud of the green accent on the back wings, and how I was able to keep the front wing/hood area smooth. The only thing I'm bummed about is that I couldn't squeeze in rear landing gear, but I love how the smooth underside came out. And the little bit of stickering on the back section to better convey the curve of the green. It's quite sturdy, but it does have some weakish points in the design. Thanks for checking it out! Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr Delta-7 Jedi Interceptor MOC by GUMBINGER, on Flickr
  8. A long, long time ago I started working on a micro scale Millennium Falcon. To begin with all I wanted to do was add detail to the Microfighter but I kept tinkering and before I knew it I had a growing collection of micro Star Wars freighters and fighters, and here they are! Instructions for all these little builds are on my Rebrickable page. Since this all started with that Falcon Microfighter the cockpit piece (a light blueish-grey 2x2 truncated cone) became my yardstick for scale. Luckily trans-black 1x1 slope pieces work as fighter cockpits at the same scale so all the ships are, and will continue to be, as close to scale with each other as I can manage, at least based on these pieces and whatever reference images I can gather from Google. My Blockade Runner (April 2021) is the last ship on my micro Star Wars to-do list, although it’s hardly micro! The size and weight were a new challenge for me, I’ve never had to worry about a moc falling apart under its own weight before, but I enjoyed the challenge and managed to make it pretty easy to pick strong. I’ve put together instructions for the Tantive IV as well as the Liberator from Star Wars Rebels, which I couldn’t resist building for myself. Rather than doing new posts for each new ship I’ll edit the very long post below. All the instructions are on my Rebrickable page and there are photos and Studio renders some photos of the ships in this post, plus a few more on Flickr and Instagram. Thanks for looking!
