Showing results for tags 'echo base'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 8 results
  1. Not one to start small for a few weeks now I've been working on flushing out the Echo Base Hanger display I want to build for my UCS Millennium Falcon. I've been planning this since the set was announced but couldn't really start till I had the set in hand to base everything off. It will be in a glass coffee table I'll be building to display it. The planned layout is currently 47.5" by 41.75" but I may go to 47.5" x 47.5". I'm going to use Stricklybricks 50x50 baseplates with one set getting trimmed down. I'm trying to be as accurate as possible and get all the little details I'm finding as I research that I haven't seen before. This will also display some of the rest of my collection so the ships inside will be a mix besides the Falcon. My 99 X-Wing and probably one of Cehnot's beauties and 4 different official speeder sets spanning the years. I'm using Migui94's Falcon as a placeholder as I work to confirm sizing in addition to the physical test layout I have set up. I see that last week Cehnot also started basically the same project with similar goals but he is going for the whole hanger while I only have room for some of it with size limitation. Can't wait to see his take shape and maybe collaborate on a few elements. I'm building in Stud.io first since I don't have the money to start buying all the bricks and figure it out by physical trial and error. So to get started with where I am at here is an over view of the layout. I have a lot of detailing to do on the walls but I've been waiting till I had the structural strength and sizing dialed in first as I kept tweaking. I originally had 2 full bays but they wouldn't hold an X-Wing so I widened it and also ended up raising them to fit the vents. This top down view with the yellow fence shows the 41" width. and the potential space if I expand to 47". I'm going to curve the wall behind the Falcon some more but I'm not going to go all the way around to keep the sides of the Falcon visible through the sides of the table. This front view of the bay shows the vents in the top of the bays. My current thought was stickers to detail the vents but i will probably revisit them to look ate a brick based option but scale is a limit here. The Cat Walk for the X-Wings is an item that has been done but lacking in detail. I used Enderman eye plates for the side detailing. The current support beam X cross braces are temporary. After much thinking and tinkering I decided to design and print custom pieces to go there. The 3L bar on top will be cut in half to finish the top rail on the ends. I do like Cehnot's top rail better though and may try to rework mine based on his. Some small detail builds I have are the (quite silly) Treadwell 1016 droid briefly seen twice (somehow it gets on top of the Falcon with treads...). I also have a fuel tanker cart seen between the Falcon and the X-Wing. The floor light took days to get the scale right and try to be easily lit from below. The plan it to get vinyl stickers for the sides to cover the trans-clear plates then put an LED under them trough a hole in the baseplate. Not shown here is that the front 1x2 plate is clear while the 2 under the slope grills are trans med blue to get the right light out the back. I have lots more to do but finally felt I had enough to start sharing. Any suggestions on how to improve something are welcome! I will also be overhauling the Falcon itself to be more ESB accurate. Haven't yet decided on adding an interior since it will be in a closed display. -JF140/Cody
  2. I always feel for the rebel ground troops in the Battle of Hoth. Hopelessly outgunned and vehicle-less, being served as cannon fodder for the AT-ATs. So I wanted to give them somewhat of a fighting chance. Hence, my MOC of Hoth Rebel Combat Speeder/Universal Carrier. This is the same vehicle featured in 8083 Rebel Trooper Battle Pack. The vehicle is dubbed "Rebel Combat Speeder" by TLG. But this model, which I once thought to be one of TLG's imaginary vehicles, actually existed as described in Star Wars Wikia as "laser ice-cutter". Source: http://starwars.wiki...aser_ice-cutter A 1980 ESB making documentary features the following. It has been suggested the vehicle was edited out becaue it rode too much like a 'snow mobile' rathe than a 'speeder'. A photo of the set shows the followng. Now, the vehicle can actually be seen in SW Ep.V as follows. Upon frame by frame analysis, I've found the following. IMO, the description that this vehicle's primary purpose is as an "ice-cutter" for the excavation of Echo Base is not correct. It is obviously a combat vehicle much like the Universal Carrier/Bren Gun Carrier or M16 Multiple Gun Carriage or FLAK halftrack. Hence, my design of that mystery rebel vehicle. .
  3. Here is my MOC of Hoth Generator Defense. This set features the following: - DSS-02 Shield/Power Generator (791 pieces) - Rebel Troop Carrier (RTC) (102 pieces) - Perimeter Defense Trench (787 pieces) - DF.9 Anti-Infantry Battery/Turret (131 pieces) - 1.4 FD P-Tower Anti-Vehicle Laser Cannon (90 pieces) - Medium Repeating Blaster / Heavy Repeating Blaster (46 pieces) - Brick-built Tauntaun (113 pieces) - Ice Mountain (432 pieces) This MOC is intended to be a big playset with the total piece count of 2553 (including minifigures and props). Photo source: the force.net Added tripod mounts to repeating blasters for standalone use. Photo source: rebelscum.com Photo source: stardestroyer.net This is now also my Lego Ideas project: https://ideas.lego.com/projects/121776 Also check out my bigger Echo Base MOC v.1.0: http://www.mocpages.com/moc.php/421468
  4. I'm finally ready to introduce a new, originally-designed speeder to you straight from the classic trilogy: --Rebel Troop Carrier-- Based on the speeder used by the Rebel Alliance at Echo Base on Hoth, this speeder isn't the most recognizable among Star Wars fans, but as a vehicle from the films, as well as being featured as a design element on the Hoth maps of Star Wars: Battlefront, it is still a valuable icon of our appreciation. To date, LEGO has only released one version of this speeder. Included as a supplement in their newest hoth set, 75098, it wasn't my favorite. To me, little-to-no detail was put into the build, as it was a very simple build and, surprisingly, much smaller than I'd previously hoped it be. Needless to say, I took it upon myself to create a much more, highly-detailed rendition of the speeder. Using namely the photos of the speeder from The Empire Strikes Back and Star Wars: Battlefront, as well as inspiration from other LEGO customs designers, I think this speeder turned out great. The scale is perfect for this build. It includes spaces for 4 rebel troops and a driver, as well as 5 spots for easy blaster housing. The front of the model is a very sturdy assembly which houses the different lights seen on the original speeder. It's also built at an angle, just like the real thing. The most challenging aspect of this model was the rear side, as there is a LOT of detail to consider. In the end, I was able to synchronize detail and functionality/playability together, rather than have detail be the "sacrificial lamb: for functinality's sake. The center end opens up so there is more access from the rear side of the speeder for troop entrance. MOCpages Comments welcome. God bless.
  5. My Battle on Hoth display from Brick Con today. Credit to various people, Gol for the AT-ST (who says they won't stand up properly, that one has been stood for 8 hours being wobbled all over!), Anio for the original AT-AT and Snowspeeder build (though I've completely rebuilt almost all of it I would have struggled without the originals to work from). I've been building it for around 5 months and in total have used around 30,000 bricks.
  6. This is my Echo base Moc done without any part of the official lego sets of the echo base. I tried to capture the essence of the scene with the small details that can be seen in the movie. I hope you like it :) Figures i have used: -sw460 Carlist rieekan -sw726 Toryn farr -sw728 Major derlin -sw734 hoth rebel trooper -sw725 K-3PO -sw113 Princess leia -sw708 Hoth rebel trooper The closet in detail I don't know what machine is this, can't do it better whit lego pieces XD Toryn farr shooting up the ion canon. The cables and the snow in the floor: Featuring my Hamster Lando as a Wampa attacking the base
  7. Finally, my Hoth Echo Base diorama is done (currently being exhibited at Brickorea Convention 2018, 15~23 December in Pangyo, S. Korea). I'm a big fan of the original SW trilogy and my favorite one to watch is Ep.V. I love the look of the Echo Base and the Hoth Battle despite the boneheaded strategy put on by the Rebels (apparently hasn't improved through to Ep. VIII). (Photos updated 2018.12.21) This set focuses on the base itself and depicts the time just before the start of the Battle of Hoth. Dimensions: 160(W) x 256(L) Studs To me two of the most important features of the base are the cave entrance/exit (with heavy shield doors) and then the air/space craft bays. I've tried to replicate the shape of the cave and shield door dimensions as close to the studio model as possible. I figure the London studio just was not big enough the fully feature the original desiger's concept, and thus the makers had to squeeze everything into a modified set. Yes the cave entrance/exit is too small for the Millenium Falcon to fit through. That is why in the scene where the Falcon escapes Vader's troops, the Falcon actually shrinks in size via photographic trickery. I was just happy to stick with the actual studio set (and more economical). Although there are no real accurate maps of the base and the surrounding areas, I always figured the approach to the front of the base would be pretty well hidden by the mountainous terrain of Hoth (as Vader's shock troops are supposed to have blasted their way into the top or side of the base). Thus the front of my base is protected by relatively few troopers (as in the film) armed with some MK II Repeating Blasters. There are only a couple of DF.9 Anti-Infantry Turrets and a 1.4 FD P-Tower Anti-Vehicle Laser Cannon guarding the front (my original plan was to build the MOC in two parts: the base itself and a forward Echo Station). My DF.9 Anti-Infantry Turret design was initially featured in '[MOC] Hoth Generator Defense' with the LDD design link. https://www.eurobricks.com/forum/index.php?/forums/topic/117121-moc-hoth-generator-defense/&page=2 [/img] My newest MK II Medium Repeating Blaster uses a black ice cream cone and a spanner wrench. Its LDD will be released in a series along with the rest (LEGO may have come up with a new receiver part for the Overwatch series which might work well). I thought of various places to put the Ion Cannon and finally settled here as I didn't want to fill that side with just lots of bricks :-) The Ion Cannon has an LED bulb embedded. You also see a Viper Probe Droid next to the Ion Cannon. The Probe Droid has lots of new design elements which LDD I'll be happy to share with you soon. A shield/power generator with four disks! Also you see a Rebel Combat Speeder in its AA role. You can find more information about the Combat Speeder below. https://www.eurobricks.com/forum/index.php?/forums/topic/117938-moc-rebel-combat-speeder/ Han Solo returning from a recon mission. I think this is also a signature scene from the movie. Updated 2018.12.21. Now onto my command center. Updated 2018.12.21. There is that Toryn Farr whose popularity I can't quite follow. A little cramped 'Blue Room' but you have to work with what you have. Han Solo and General Rieekan having a discussion. Oh that stare! Your worshipfulness! <An acknowledgement here to Frank Diorio at dioramaworkshop.com for his wonderful command center and other decals which I've adopted here> Although a bit cramped, my command center seems to be quite close to the film set. Medical center which has been done to death. Han Solo: "Alright, don't lose your temper. I'll come right back and give you a hand." Chewbacca: "Grrrrrr!" Updated 2018.12.21. with Jerac's X-Wing Snowspeeder bays follow after actual design changes made to the studio where the base was filmed. Updated 2018.12.21. I thought the shadows over the X-Wings were the essential points. Updated 2018.12.21. You also see three GNK "Gonk" Power Droids to the right. They are really fun designs and I'll release the LDDs soon. Comparison photos. Obligatory mission briefing scene before the sortie. Updated 2018.12.21. Jerac's X-Wing is a perfect match ;-) https://www.eurobricks.com/forum/index.php?/forums/topic/166523-moc-star-wars-the-x-wing-story/&tab=comments#comment-3017567 YSDWDY's T-47 Airspeeder (Snowspeeder) https://www.eurobricks.com/forum/index.php?/forums/topic/138237-moc-incom-t-47-airspeeder-snowspeeder/ Also here's my service gantry model which looks good and definitely works.Updated 2018.12.21. One of two Treadwell droid models I know. This also has a nice LDD which I love. The Rebel Troop Carrier is featured in detail below. https://www.eurobricks.com/forum/index.php?/forums/topic/117121-moc-hoth-generator-defense/&page=2 Miscellaneous: Singing in the Rain trooper. This base features some complex cave networks which cannot be fully shown. It wouldn't be pleasant trying to recover some parts dropped in there! Not the best angle, but this is how a probe droid should look. A 'blue milk' breaktime. Updated 2018.12.21. Updated 2018.12.21. One last shot. Updated 2018.12.21. Well, there you have it. This diorama set has been started in 2011 and finished only last week. That was one long project!! Hopefully now I can go on to something else - only what? ************************************************ <Photos updated 2018.12.21. with lots more goodies>
  8. Hi, I have been displayed my version of the Battle of Hoth at shows in Ireland over the last few years. It's mostly using models from sets, but each time I try to add some new custom details. For the latest incarnation, I've added the medical lab, complete with Luke thawing out... Echo Base Medical Lab by James Shields, on Flickr Echo Base Medical Lab by James Shields, on Flickr This shot shows the complete model: Echo Base Medical Lab by James Shields, on Flickr Here's a view from around the back. showing how it's held together: Echo Base Medical Lab by James Shields, on Flickr Here's the rebellion's newest recruit: Echo Base Medical Lab by James Shields, on Flickr The lighting is a set of 50 LED lights powered by 3 AA cells. It set me back €3 in my local discount store. In addition to the medical lab, here is the latest version of the command centre. I've tried to do this a couple of times, but never really felt I captured the atmosphere of the movie. I think there's still room for improvement, but I'm much happier with the latest version, below: Echo Base Command Centre by James Shields, on Flickr Echo Base Command Centre by James Shields, on Flickr Echo Base Command Centre by James Shields, on Flickr This is on display in Athy in Ireland tomorrow. I'll post photos of the whole display soon.
