Showing results for tags 'episode 2'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 7 results
  1. Hey everyone, I've been working on this for quite a while and I need to make a few things clear concerning this MOC. The model is basically a remake of LoRd AmUnRa's Slave 1 which I think looked very close to the "real" model. I built a replica on LDD then decided to change a few things up to make it look more up-to-date, which resulted in a mix between the old style and the new one, so let's say it's a MOD of a MOC. Anyway here it is: So here it is, I hope you enjoyed it, I spent a lot of hours on LDD recreating it and modifying it over the years, I could provide the LDD file but it does not contain my latest tweaks and modifications and I don't have the time to look into it currently.
  2. This is my version of khatmorg's incredible delta-7 model (which you should view here www.flickr.com/photos/95628537@N02/8735306298/in/dateposted/ and here http://www.eurobrick...2931&hl=delta-7) . I originally built their model as per the original build over a year ago but a few months ago I started fiddling with it and have now arrived at a point where I'm satisfied with it. It was difficult to find other ways to achieve some angles (the source is so good already!) especially in the back and as a result that area is quite fragile and use some illegal connections. Most of the changes are concerned with the bottom, spine and rear sections. I haven't been able to find a way to find a way to hide some little landing gears in the back of the wedge where it fattens out a bit yet so the ones you can see in the other photos are just attached externally. Also it is about 8 to 10 studs too long as a result of the angle of the 1x3 wedge plate, according to the rough scale I used. That isn't ideal for me as I like to scale it right to a degree, but the additional detail you can add on a bigger model is good as well. I also wanted to try an alternative solution to miniaturise the dual laser cannons, and add the other half on the bottom but haven't solved that issue either. I might pick this up again later and play with it some more but for now I'm content to reveal it. I hope all of you enjoy. Thanks to khatmorg for being so great about sharing their creation. The stand is based on sydag's method which you can see here (www.flickr.com/photos/sydag/16129935387/in/dateposted/). It's simple and ingenious. You can view the rest of photos in the album (www.flickr.com/photos/48109771@N05/albums/72157668258477972).
  3. things changed: -lowered cockpit down roughly 1 brick, changed build around cockpit region to slope into wings, taper into body, round out the rear to more accurately reflect the shape of the model in canon -filled in gaps with 1 tile width across whole body; requires some gaps in wing construction -replaced guns for accuracy; subject to further change to reduce conspicuousness -cut up stickers to apply across model -cut cockpit -nexo tile at front to hammer in the point :) working on instructions if anyone's interested. if ur curious on scale it works like this
  4. This is my rendition of the Geonosian Arena from STAR WARS Attack Of The Clones. This has always been one of LEGO's most glaring omissions from the Star Wars line, hence why I decided to test out this MOC. OK, it's not excessively massive or complicated, but I just think it makes a neat little playset. Comment your opinions. Also don't forget to check out my LEGO IDEAS page for more information on this, and please support! :) from there you can read all about the design plan, the history, and also see any other photos of the MOC. https://ideas.lego.com/projects/158217
  5. Villa Del Balbianello is a lakeside villa in Italy built in 1785 expanding on an existing structure from the 13th century. With later additions added throughout the years such as relics added from an explorer. It was also featured in films such as Star Wars: Episode II - Attack of the Clones (2002) and James Bond: Casino Royale (2006). Also a set on LEGO Ideas: https://ideas.lego.com/projects/85ec2902-0e20-40a8-9b18-4a79c9f560af
  6. *Your entry has earned 7 XP (S:3, T:2, A:2) Layout of Ryek's Riot Racer Racer: Ryek
  7. My Geonosis Arena model renders. It includes the three arena beasts (Acklay, Reek & Nexu), some geonosians, a droideka an orray along with a section of the arena. Project Links Lego Ideas Link: https://ideas.lego.com/projects/164837 (Some more Images & Support page) (Please support it if you like it lets get this to 10 K, If it's not accepted it could make LEGO consider making it a set for the official line) LDD File: http://www.mediafire.com/file/ae2for3qxgigwba/Geonosis_Arena_ThunderousBlade_Lego_Ideas.lxf (Uses non-existent colour bricks) Hope you enjoy it! Was interested in this scene since 2002.
