Showing results for tags 'f1 car'.
So here's the latest project I have been working on. I am actually waiting for 5 parts to arrive (4 tiles on the "boomerang" at the bargeboards and the exhaust in flat silver instead of LBG), but otherwise it is finished. I tried to recreate a F1 car with 2019 specfications with "typical" Red Bull stuff in mind (rake and pullrod in the rear for example). I took some liberty here and there. All the freaking winglets on these cars in real life+Technic=meh. So I went for a pretty basic flow of panels and wings. Another reason I also took some liberty was because trying to find blueprints or other good images for size reference of the 2019 or even 2018 cars were hard to come by for any of the teams. Or I just suck at searching, but I'd find it understandable if it is actually hard to find, since teams wouldn't want that stuff public. 20190921_135837 by Appie NL, on Flickr Functions are: - 8 speed gearbox (used didumos' and JB70's revised Chiron gearbox again, that I made 3 studs shorter again) with V6. - HOG steering through the T-cam and working steering wheel - Pushrod suspension front, pullrod in the rear - Had to sacrifice the driver's seat for a very basic gear selector mechanism due to lack of space elsewhere. 20190921_135940 by Appie NL, on Flickr 20190921_140038 by Appie NL, on Flickr The point at which the nose goes from angled to flat is too far towards the front of the car compared to real life, as the curving point tends to be right above the axle of the wheels. I am aware of this, due to the suspension setup in that section this was the best I could do. 20190921_140228 by Appie NL, on Flickr The diffuser isn't looking too good from this angle, the only good angle is looking right into the rear of the car. Couldn't figure out a better one with the limited mounting options in that section and the diff+suspension. 20190921_140301 by Appie NL, on Flickr 20190921_140342 by Appie NL, on Flickr In case you were now going: This belly shot sucks! Got you covered! (pun intended :D) 20190921_140422 by Appie NL, on Flickr I wanted to make a similar floor at first for my Rolls too, but dropped it because I am not going to be flipping that model very often to show the belly. And having to uncover it too after flipping, would be troublesome on that model. 20190921_140610 by Appie NL, on Flickr Close-up of the pullrod suspension in the rear and my crappy DRS system. Due to lack of space to route some controls for DRS to the cockpit with a diff, suspension, V6 and gearbox blocking alot of the way, I opted for this instead. 20190921_140645 by Appie NL, on Flickr Should have angled this pic more on the cockpit, but oh well. T-cam for HOG, yellow knob gear in the headrest is to flip the gears. 20190921_140956 by Appie NL, on Flickr Since Red Bull is known for the rake they have on their cars I had to mimic that too. It's a small angle, but it's there and pretty close to real life I think. In case you wonder, the car weighs about 1.7kg.
