Showing results for tags 'gaz 66 trial truck'.
Hello! After a while, I'll post mocs again, and for starting, I choosed one of my latest creations, a Gaz 66 trial truck. This is my third Gaz66 Lego trial truck, now with 108 mm RC4WD custom tyres, as many technic vehicle has. Equipped with two RC buggy motors for propulsion and one PF M motor for steerig, built in the front axle. The two RC motors are linked together with a central axle, however, they are located separately near to the front and rear axle. With this technique, they can help each other to move this truck over obstacles. I tried to get close to original Gaz66 with the body, but angles and others, like ground clearance were also important. It can be precisely driven, thanks to the RC throttle with 3 levels and linked pendular suspension. This was made first of all for a Lego truck trial competition, organized by HUNLTC in Hungary: Gaz66-024 Gaz66-023 Gaz66-022 Gaz66-021 Gaz66-020 Gaz66-019 Gaz66-018 The RC unit is also part of the frame: Gaz66-016 Gaz66-015 Details: Gaz66-013 Gaz66-012 Gaz66-010 The power transmitter axle between the two motors: Gaz66-011 Gaz66-009 Gaz66-008 Gaz66-007 Gaz66-006 Yes, some scratches appeared after a long run on rocks and others, but I don't care, it's an outdoor built moc. These angles can be done by suspension: Gaz66-005 ... and steering: Gaz66-004 Gaz66-003 Top view: Gaz66-002 Nowadays I have a new semi-pro camera, so from now, you can watch 1080p good quality videos, in my new creations. (but for old mocs, which are waiting for publicizing, I still only have the 480p videos). The slow motion parts were filmed with 1080p60fps and 320x240 at 240fps. Video:
- 25 replies
- lego trial truck
- gaz 66
(and 8 more)
Tagged with:
