Showing results for tags 'high speed'.
This Blacktron 1 colored passenger train is modeled after the General Motors Aerotrain concept of 1955. I modified the engine to have two bogies (one of which can be replaced with a 9V motor to power the train) instead of the one bogie and one fixed axle of the original. The passenger cars were lengthened from 16 to 24 studs and Jacob's bogies placed in two spots to lessen the part count. (Yes, it bears more than a passing resemblance to a certain other space train of mine... let's just say some espionage was involved concerning the CS design plans for that train!) The train will be used on my Blacktron space base, shuttling VIP's around on tours of my base. Alternatively, it could be used to get personnel to / from the base and the off-site living quarters. (you can read more about my Blacktron fleet in it's own thread in the Sci-Fi forum.) The windows in the train were difficult to get right, but I managed to attach them. Inverted trans-yellow 2x2 slopes that would make this way easier are coming in a set releasing in March, but I'm not waiting that long! (The tail car is currently missing a few parts for the roof.) The cab roof is removable and a driver can be placed at the controls, but the coaches are totally impossible to get into due to the construction techniques used. (Also, two control panel double-cheese slopes, two 1x1 number tiles, and two radiator donut tiles are missing from the model, among a few other parts.) As for when this will be built in the real world, it will be soon. The last few parts for the train were ordered 1/14/25. Update 1/15/25! This space train station (named 'Base Terminus') is to be used with my retro-futuristic Blacktron passenger train to get staff and VIP's to and from the space base. (Some printed parts are not in the picture, but they will be when it's built in real life.) Thoughts?
Hello everyone! I think it’s time I shared something over here I’ve been working on. This is RENFE’s AVE S-102 (Talgo 350) made out of Lego. You might already be familiar with this Spanish high-speed train since other talented builders have shared their own wonderful versions in this forum. Here’s a picture of the real thing if you’re not familiar with it (photo by Adrià Pàmies on flickr). If you didn’t know, you won’t be surprised to learn that this EMU has earned itself the nickname “Pato” (Duck) due to the shape of the head. Very reminiscent of Japanese Shinkansen as a result of following the same aerodynamic principles. These trains are composed of 2 tractor heads at each end and 12 Talgo coahes. In Lego form I decided to shorten it to just 6 coaches, enough to feature one of each unique variation. The Talgo 350 is employed by RENFE for both its AVE and Avlo services. The Avlo brand, which stands for “alta velocidad low cost” (a bit of Spanglish there for you), being the equivalent and direct response to SNCF’s Ouigo. Originally, I intended to build the Avlo version because I find the livery very striking and unlike anything running in Europe, let alone Spain. I got as far as designing every coach, but as soon as I got to the heads I realized that the magenta brick palette is too limited to achieve the shape, so I turned it into an AVE instead. Turning it into an AVE brought its own challenge though. In order to achieve the not quite boxy look of the coaches and keep the magenta stripe running all along the length of the train I had hinge the lower section of the walls at a very gentle angle to get it just right. It’s almost imperceptible, but in my opinion, it makes all the difference. Unfortunately, as much as I’d like to have the entire train brick-built, I just don’t have the space necessary for it. That’s why for now I’m happy to only have one of the heads (the unpowered one) and only three of the coaches as a static display. Of course, this being a Talgo train, it features their signature single pair of wheels between coaches (rodal). Thanks to @Hod Carrier's brilliant rodal design this train can navigate pretty much any track geometry (with some restrictions) while maintaining a distance of barely more than a stud between coaches. I don’t rule out building the rest of the coaches and the other engine in the future, as well as motorizing the entire train. However, the remaining head’s final design is still pretty much a work in progress. For now, the intention is to power both bogies with two geared-up PF L motors and a BuWizz 2.0. I’ve never tackled a project of this size before, so there are many things I’m not sure of yet. I’m worried the two PF L Motors won’t be enough to pull the entire consist. Or even if it has enough pulling power, I’m not sure the rodal design can handle the weight of so many heavy coaches. In that case, I suppose restricting the train to wider radius curves would help it run better.
For some time I'm working on a 2.4GHz RC controlled LEGO car. Trying to create maximum speed with a LEGO-based car using standard RC-components (sorry, not for purists). To make this work, I introduced some rules. The car must be build using LEGO parts, except for the battery, motor, speed control, steering-servo, remote-control and receiver (and optionally a car-body). Fully agree with comments regarding LEGO not being able to match RC-performance. But, nevertheless, I enjoy pushing the limits to see what speed can be achieved using (mainly) LEGO. It has been a great journey. Lots interesting problems to solve: reducing wear-out, maximizing traction, optimize direct steering, increasing control with suspension, etc. Happy to share the results so far. Haven't done a proper speed check, but some rough calculations show a speed above 50+ km/h. Please check the video: LEGO RC Car video. LDD available on request. Open for comments, suggestions, improvements.
Hello and God Bless I have started my first train MOC, in LEGO Digital Designer because I don't have the funds to build real LEGO trains. This is going to be an 8 wide long distance high speed train making use of the large airplane parts from Lego City Sets such as 7893: Passenger Plane, 7894: Airport and 7734: Cargo Plane. I have completed my first car, which is a dining car, this dining car will be attached behind a baggage car which also contains an on-board kitchen. The train contains 6 tables with 2 chairs each (I wish I could it more), opening external and internal doors, at each and of the dining car, there is a soda fountain and a sink as well as a set of drawers. I want to include: Locomotive Baggage car with kitchen Dining car (this car) Lounge car (possibly double decker) Normal sitting car Sleeping car observation car If you want to build in real life, no credit is needed, just have fun. I hope this inspires you, may Christ be with you all. God Bless. diningcar.lxf
- 21 replies
- train
- high speed
(and 5 more)
Tagged with:
One of my first posts on Eurobricks was of a Metroliner inspired high speed train I designed on LDD nearly 5 years ago. It has existed with minimal revisions for years, but something that always bothered me was how jagged and pointed the nose was. This actually lead me to nicknaming it "The Metro Dagger", which is a rather silly name if I'm being quite honest. Here are some before shots with the ones in actual bricks sporting some custom stickers. Either way, I felt the design needed some revision. For the moment, I just wanted to focus my attention on the locomotives, though I may change the passenger cars later on. In addition, I wanted to still keep the simplicity and durability of the locos intact, as well as use that long windscreen piece, so those would factor into the redesign as well. I think the old cars and the new locos work well together, though the club car striping could use some work, now that I'm looking at it. Also, when I've run the current full train on track, it tends to move quite slowly. I'm thinking of making a dual motor mod to the power car later on. Old design is on top, new one on the bottom. The new loco is nearly 3 studs shorter, so hopefully this fixes its ridiculous overhang on R40. I would love comments and suggestions on how to improve the locomotive, cars, (Or name!). Especially curious to hear @Murdoch17's thoughts on it as he helped me so much in my original design. If anyone wants to tinker in the Stud.io file, here is the link to my folder. This file is under the name "MD21" https://bricksafe.com/pages/Legownz/legownzs-train-mocs
- 1 reply
- metroliner
- high speed
(and 6 more)
Tagged with:
Hi everyone! This is my MOC for the real life high speed train Frecciarossa 1000, a train made by the Bombardier-Hitachi consortium, which they call the “V300 Zefiro”. It currently runs in the Italian high speed network (operated by Trenitalia) and on the Spanish one too (operated by Iryo). The train itself is simply a well designed and made high speed train, with an operational speed of up to 360 km/h (although they never reach those speeds commercially) with a maximum designed speed of 400 km/h. The Italian national railway operator names it the “Frecciarossa 1000”. As of the MOC, it’s a 7 stud model. The nose was pretty challenging but with some very interesting techniques I managed to make it work. Sadly though, I cannot make the full livery on the nose (with bricks) as its design doesn’t allow it.
- 7 replies
- trenitalia
- iryo
(and 5 more)
Tagged with:
Hi everyone! This is my recreation of the Spanish high speed train Renfe AVE 102 and 112 series, manufactured and designed by the Spanish rolling-stock company Talgo (which they name Talgo 350). The train is nicknamed as "Pato", which literally translates to "Duck" due to its characteristic nose design, which resembles the one of a duck, apparently it highly reduces air noise. About the train, it was introduced into service in 2005 and is currently the star of the Spanish high speed network (soon to be joined by the new generation train Talgo Avril 106 series) with Renfe having 46 units of them, reaching speeds of 360 km/h with an operational speed of 330 km/h. Amazingly, the train weights very little for it's size and, as with every Talgo, it enables low-flow boarding meaning the door is at the height of the floor, without extra stairs needed inside to access the main cabin, making it very accessible thanks to the special single independent bogie design. As of the MOC, it's a minifigure scale recreation and 7 studs wide. The nose was quite a bit of a challenge, but I think the result was pretty accurate to the real thing. The characteristic bogie system by Talgo is quite hard to make in Lego, with the single wheel configuration, so I can't say the way it is on the model will work perfectly, but doesn't seem to have any issues. It is based off Ferro-Friki's version for the Renfe Talgo S130. Hopefully I can build it one day and test it out! Here some more close-up images of every part: (Ignore this last image, it won't delete)
Two great trains are dueling on 12v gray track: the British Railways HST 125 vs the Deutsche Bahn BR403 "Donald Duck"! Two big countries with high expertise on trains,two different power sources (Diesel vs Electric), same speed (above 200km/h or 125mph). Who will win this Lego contest? None of them, since they both are built on the same Lego platform and shape - I created first the "Donald Duck" in Lufthansa colors and then I modified it a little to recall the HST125. So same power cars ,and same wagons, only with a different paint scheme . I've always focused on standard trains, and this is my first experiment with fast ones. After all , during "gray Era" we've seen a lot of steamers, diesels, electric trains...but only one example of fast train. So here's a shot of the DB403, with an applied sticker on front "window" to simulate double windscreens... ...and one of the "Screaming Valenta" - here the sticker is a bit different, but you can easily tell it is only a bigger one! Both are using parts available in the last years of "Gray Era" (so they could have been made starting from 1987). The HST could be a bit older than the 403 - since it's using the old style blue window in the cabin. I could also recreate a yellow sticker to cover the outer part of the trans-clear headlight, but I preferred to keep it as it is (just imagine the sticker detaching when the glue is old...I HATE that sensation ) Both could have working headlights, the DB403 can use a 12v light brick on top headlight. For the HST125 the problem is how to diffuse light from light brick to transparent slopes. But both trains could also leverage on 9V lights, which were already available at the time. The 9v Battery box fits easily in both bodies. Finally the 7745 has some internal competition!!! Hope you like these two! Ciao! Davide
For my first post I'd like to share something I built a few months back. This is my first actual post so please do be gentle :P I decided to design a much more fleshed out version of the 60051 High Speed Passenger Train by adding various types of new custom passenger cars and locomotives. I implemented some ideas from the 10233 Horizon Express, which is quite noticeable from the pictures below (such as the all-black 10233 inter-car bogey). Firstly I wanted the design to be much more detailed and to use more advanced building techniques such as those seen in 10233 than what is standard for a City set. For instance, I wanted my passenger cars to be intermodal articulated (cheers Duq :P) to really catch that high speed train vibe. Additionally, it had to have functioning doors and fairly detailed interiors. However, common limitations prevented me from doing particular designs such as a restaurant car as an interior four studs wide simply would not be enough for me to create a bar/lounge that didn't look like it was being choked by the walls of the car. If anyone wishes to build/use the designs, I'm more than happy to upload relevant .lxf files for you all :) just be sure to credit me properly. So without further ado, have at it! 1. Inter-car bogey (10233 design in all-black) Express2 - Bogey by Bartybum, on Flickr 2. Short end coach Express2 - Coach End Short by Bartybum, on Flickr 3. Short coach middle Express2 - Coach Short by Bartybum, on Flickr 4. Short locomotive Express2 - Engine by Bartybum, on Flickr 5. Long coach middle (No end coach as of yet, as I'm yet to design one) Express2 - Coach Long by Bartybum, on Flickr 6. Long locomotive Express2 - Engine Long by Bartybum, on Flickr 7. Super locomotive (uses inter-car bogey and is therefore inseparable from the rest of the consist) Express2 - Super Engine by Bartybum, on Flickr At this point I asked myself, why stop at one storey? Why not follow the footsteps of the Metroliner and go double decker? Naturally I did :) 8. Two storey coach Express2 - Two Storey Coach by Bartybum, on Flickr 9. Two storey transition coach Express2 - Two Storey Transition Coach by Bartybum, on Flickr Obviously since this is Lego, you can switch around cars if need be, so you can make whatever configuration you want. Two examples: Express2 by Bartybum, on Flickr Express2.1 by Bartybum, on Flickr Since LDD doesn't do stickers the abrupt disappearance of red and dark grey from the nose looks just a bit jarring. Keep in mind that these designs are built with the implication of the stickers on the nose already being there. Now that all's said and done, just hit me up in the replies if you'd like .lxf files, more than happy to give them out :) EDIT: .zip files in reply section
Ok, after figuring out some video problems I am going to post about my final satisfaction out of my Four chassis builds. While V4 may be slower (slower output), It is extremely robust, simple and has the best handling out of the Four . It is powered by four Buggy motors and steering uses the servo motor. Electronics-wise it uses the same hobby-grade motor controller, receiver and transmitter that I have mentioned before and my custom battery. These are the only non lego parts Performance is great, and a couple days ago during some play I managed to barrel-roll it, only knocking the project box containing the electronics a bit loose For now I only have the video to show, but I will upload pictures soon
- 30 replies
- Radio Control
- buggy motor
(and 2 more)
Tagged with:
